Question about Amana ARGS7650SS Gas Kitchen Range
I have an amana arg7102w my hsi glows but my oven will not ignit
My top range works and my brioiler works
  • jerrytosa Jun 29, 2009
    my ignitor is glowing and im getting 120 v to the gas valve
    hi i have an amana arg7102w stove ... my range and broiler work, the ignitor for the oven glows but the oven will not ignite
    President:
  • 2,923 Answers
Ignitor can become weak and not draw enough current to open the gas valve properly.
Please check the link below:
http://www.applianceaid.com/gas.html#glow
Hope this helps and have a great day!
Posted on Jun 29, 2009
    Sergeant:
  • 175 Answers
Hi..the reason to this problem is the ignitor.It might
have gone bad.
check this out..
thank u..
kindly rate my response..
Amana arg7102w gas range broiler works fine but regular oven doesn't heat up, viewed igniter from the back while turned on and see igniter glow but no gas flowing, can't find service manual online...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 12, 2011 | Amana Microwave Ovens
Amana Model ARG7102W ERROR F02
Hello, Thank You for using FixYa. I will be helping you today.It means runaway temperature. Test oven sensor for 1100ohms if out by more than ten ohms replace sensor.
Thank You and please rate my answer if it was helpful..
Jun 14, 2011 | Kitchen Ranges
I have an Amana ARG7102W P1143347NW gas range that the oven will not light. All other functions work including the broiler and the oven ignitor glows brightly. I don't think it is getting gas to the...
most likely it will be the ignitor,even though it glows it doesn't mean the ignitor is good.it works on amps.a flat ignitor takes 3.2 amps to open the gas valve and a round ignitor takes 2.5 amps to open the valve,the only way to check it is to replace it and i would or if you have an amp meter with a clamp on it you just stick one of the wires going to the ignitor inside the clamp and it will tell you how many amps are coming out of the ignitor.buy a new ignitor and you should be fine.it calls for ignitor part number 31940001 and it's around 50 dollars.
Jun 12, 2011 | Amana Ovens
Amana stove, oven igniter works but oven wont light
although the bake ignitor appears to be glowing, it probably does not glow with the intensity it needs to open the safety valve assy, VERY common problem, go aheadand replace the ignitor, this will correct your issue
Feb 09, 2010 | Amana ARGS7650SS Gas Kitchen Range
Amana gas oven not working
SOUNDS LIKE U HAVE A WEAK BAKE IGNITIOR REPLACE THE BAKE IGNITIOR IT WILL SOLVE THIS ISSUE
Aug 31, 2009 | Amana ARGS7650SS Gas Kitchen Range
The ignitor may be too weak to open the gas valve. If you have a volt/ohm meter capable of reading AMPS you can hook up to a ignitor wire and turn the oven ON. If you read less than 3.5 amps replace the ignitor. If 3.5 amps or more are read,replace the gas valve.
Aug 30, 2009 | Amana ARGS7650SS Gas Kitchen Range
Amana broiler problem
Each burner manifold in the oven has its own igniter. If the igniter is defective, the burner assembly will not light. The igniter has to be functioning properly in order for the gas safety valve to open. This is a designed safety feature that prevents free flowing gas from entering the oven cavity without ignition. This reduces the risk of explosions.
There should be a flame spreader metal plate covering the access over the broiler. You will need to access the broiler so you can view the broiler manifold and igniter. Turn the oven setting to broil and make sure the igniter begins to glow. If the igniter fails to glow, replace it. If the igniter does glow, but you still do not have ignition after 90 seconds, the igniter may be weak and still require replacement. The following link explains oven igniter types, their current potential, and how to replace them:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
If you have questions, or require additional assistance, please let me know before you rate the solution. I hope this helps you.
Jan 29, 2009 | Amana RanARG7302 Gas Kitchen Range
I have a Westinghouse Freestyle 472 gas oven that wont light. The igniter seems to start glowing, the fan runs and the grill works but no gas seems to flow.
remove burner see if a hole is melted on glowing ignitor end repair with s/s welding if ok replace ignitor hsi assy w/o old 1 may appear ok but resistance values are out gas valve wont open if still dont work replace valve thermal hsi single should replace both these item anyway.this is assistance advice only do at own risk it worked for me madog cheers.
May 14, 2008 | Kitchen Ranges
Amana ARGS7650SS Gas Kitchen Range Logo
261 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
