Well despite this i cant see anything else due to my monitor turning off every 5 seconds.I've tried turning it on and off a lot,and also switching some cables around but nothing seems to work.I can only see a faint image barely visible to me so i need help
Normally problem is dry solder on invertor pcb.
If you can see the backlight ,white 2pin connectors connect to invertor pCB.Look around these two connectors you should see 2 brown/yellow/red transformers with a ferrite core.These are the inverter transformers , resolder all pins and power transistors around it.
That should solve your proble.
Please provide feedback and rate this solution.
Samir.
