Question about Toshiba Satellite A105 Notebook
I thought I had Bluetooth in my computer...
I have a Toshiba laptop and I have a ConfigFree. In the control panel I have "Bluetooth Local COM" . When I click on that a box shows up that says:
"Existing COM ports: COM 3 TOSHIBA Software Modem System"
Do I have the ablility to use a Bluetooth device with my computer?
  • DEYA Mar 27, 2008
  • doodlehill Apr 22, 2008
    I have a Dell Inspiron E1705 it had Vista loaded onto it and I did not like vista and had it removed and had XP Pro SP2 loaded onto it......I have an Internal Bluetooth Adapter which worked with vista but when the guy took off vista and loaded XP Pro SP2 since he did that I can not see my bluetooth nor find it to use it. How can I get the bluetooth to work with XP Pro SP2? Thanks,
How do i find bluetooth in my laptop
Posted on Jul 25, 2008
Yes, you can use bluetooth mobile devices. COM 3 os the port that the bluetooth uses to connect to a device. You can think of it like a wireless modem. You can also configure other COM ports for communication with bluetooth devices using the connection wizard. I would suggest not to do this unless you know what you doing. From my experiences with bluetooth devices they can b a little touchy, and you have to careful you don't want to pick a port that another program is already using. ConfigFree is capable of configuring this bluetooth connection, but there are also other programs out there that you can use as well.
Posted on Nov 13, 2007
Toshiba configfree
This may answer all of your questions;
Nov 04, 2013 | Computers & Internet
How to install a free bluetooth device on toshiba satellite L505D-GS6000?
Hi. You can install the bluetooth Driver/Utility or ConfigFree Utility from this Toshiba support site. Just go to Downloads and look for the right utility or driver you need.
Hope this helps!
Jun 20, 2011 | Computers & Internet
I am owner of a Satellite A135-S4467 notebook that should have the bluetooth technology. When I run control panel --> bluetooth local com, it is detected the TOSHIBA Software Modem in PORT COM3. I...
first make sure that you have Bluetooth on your computer and working fine /.
go to device manager (right click on the computer icon and select properties - hardware tab and select device manager - right pane check for Bluetooth -if found you will find whether ur computer has BT or not and what state is in (disable/drivers/working or not ))
Oct 01, 2010 | Toshiba Satellite A135-S4467 Notebook
Configfree problem in Toshiba L300
go to network connections and look for the wireless connection and start it that way
Oct 18, 2009 | Toshiba Satellite M45-S265 Notebook
I have a Toshiba loptop and I try to connect to the internet some times give me error 769 ,other times error 651, this machine come with internal card. Can you help me to resolve this problem.
Use the Toshiba configFree software which is installed along with the operating system.
Start--->All Programs--->Toshiba--->Ntworking--->ConfigFree.
Hope it helps
Sep 11, 2009 | Toshiba Satellite A100-S8111TD Notebook
I turned something off. my network connections are gone
Try downloading and reinstalling the driver:
Link to you model below:|PSM40U
Mar 20, 2009 | Toshiba Satellite M45X-S331 Notebook
Wireless Error
more than likely windows will be controlling the wireless adapter....go into control panel and find wireless network setup wizard...follow prompts
Oct 08, 2008 | Toshiba Satellite M55-S3512 Notebook
if the bluetooth is not available in the configfree menu check to see if you have the driver installed for it , you can download the driver from Toshiba's website.
Bluetooth is an option on most of Toshiba laptops, check if your laptop has the module installed, and if you need to press a button or a function key combination to activate bluetooth.
Sep 02, 2008 | Computers & Internet
NDSTray.exe Application Error
The process ConfigFree(TM) Tray or Network Device Switch (Tray) belongs to the software ConfigFree(TM) Tray or TOSHIBA ConfigFree or NDSTray.exe by TOSHIBA CORPORATION (
Description: File NDSTray.exe is located in a subfolder of "C:\Program Files" (common is C:\Program Files\Toshiba\ConfigFree\). Known file sizes on Windows XP are 892928 bytes (27% of all occurrence), 978944 bytes, 962560 bytes, 704512 bytes, 458752 bytes, 929792 bytes, 933888 bytes, 888832 bytes, 139264 bytes, 1372160 bytes, 974848 bytes.
There is an icon for this program on the taskbar next to the clock. The program has a visible window. It is not a Windows system file. NDSTray.exe is able to monitor applications. Therefore the technical security rating is 18% dangerous, however also read the users reviews.
External information from Paul Collins:
  • "NDSTray" can run at start up. ConfigFreeT Tray on a Toshiba laptop. Tray utility for their network switching application which permits switching network devices and settings with a click on the tray icon. While it is not required, for people who span multiple networks and want an easy way to go from wired to wireless and change addresses and other network settings, it's a must have
Important: Some malware camouflage themselves as NDSTray.exe, particularly if they are located in c:\windows or c:\windows\system32 folder. Thus check the NDSTray.exe process on your pc whether it is pest. We recommend Security Task Manager for verifying your computer's security. It is one of the Top Download Picks of 2005 of The Washington Post and PC World.
Feb 11, 2008 | Toshiba Satellite M55-S135 Notebook
Toshiba Satellite A105 Notebook Logo
1,287 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
