Question about Samsung Televison & Video
I have a Samsung DVD/VHS player and now the video does not work on the VHS. The sound is there and the DVD player works fine.What can I do? Ed
  • 458 Answers
If you have sound on playback & the picture is snowy then I think it appears the video heads are dirty. Try a video head cleaner or better still, get them cleaned by a service centre. You can try to clesn them yourself but you need to be careful you do not damage the heads.
Posted on Jun 29, 2009
Insert a VHS tape, hear sound, no picture? DVD working fine, both sound & picture. What am I doing wrong?
Likely a damaged video tape got in the unit and blocked the video heads--once blocked no picture but sound will be the case---the heads can be manually cleaned if you know how---The real issue will be to locate which tape was in the unit when this happened--clear the heads and put it back and right back to no image......
Cleaning tapes are only slightly effective--most shops (if you can find one who even works on this gear) will not charge much to clean the heads.
Nov 04, 2012 | Samsung DVD-V5500 DVD Player/VCR
How to tune up dvd player
  • Plug the power cable of the Samsung VHS/DVD player into an available power outlet near the television.
Connect a set of RCA audio and video cables to the color-coded outputs on the back of your Samsung VHS/DVD player. The colors of these cables are yellow (video), white (left audio) and red (right audio).
Take the other end of the RCA audio and video cables and connect them to the color-corresponding inputs on your television. When plugging in these cables, look for a label for the input, such as "Video 1" and "Audio 1." This will be important in Step 5.
Turn on the television and the Samsung VHS/DVD player.
Tune your television to the video input channel that you noted in Step 3. If you did not take note, you can also tune through your television's input channels until you find the one displaying the signal from the DVD/VCR player.
Insert a VHS tape or DVD into the Samsung player and press the "Play" button to verify that the unit is functioning properly.
Component Video
Connect a set of component video cables to the color-coded outputs on the back of your Samsung VHS/DVD player. These cables will look similar to composite audio and video cables, but they are instead color-coded as red, blue and green.
Plug the other end of the component video cables into the color-corresponding inputs on your television. Take note of what input number you are plugging the cords into, as it will be useful later.
Connect a set of RCA audio cables to "Audio Out" jacks on your VHS/DVD player, then connect the other ends to your television. These cables are color-coded as red and white and must be plugged into the same input number as the component video cables.
Tune your television to the component video input channel where you connected the Samsung VHS/DVD player.
Insert a VHS or DVD into the Samsung player and press the "Play" button to verify that the unit is functioning properly.
Jul 10, 2012 | 2005 Toyota Caldina
My JVC DR-MV150B plays prerecorded VHS tapes fine.
Try opening the front hatch of the tape by pressing the small, square button on the right or left (short) side of the tape. Check the black tape inside for any marks, dirt, scratches, tears, etc. If the tape is fine then your unit needs to be cleaned with a tape cleaner available at any electronics specialty or retail store. Good luck to you!
Jan 02, 2010 | JVC DR-MV150B DVD Recorder/VCR
Have a samsumg 4600 combo dvd/vhs plays vhs with good sound and picture, dvd only has sound and no picture
need to check the video audio output connectors sounds like it hooked to and output that is only for the vhs
Jul 07, 2009 | Samsung DVD-V4600 DVD Player/VCR
No sound when playing a tape in the rca vcr player
If it's connected with a scart cable, then there may be a bent pin or broken wire.
Jul 06, 2009 | Samsung VR8460 VHS/S-VHS playback VCR
Sound but not picture
I have the same problem. I pushed the EZ View button to see what it would do and I lost all picture to the DVD but the VCR worked fine. I searched the WEB ALOT.... and there seems to be alot of this but no help! Well - GOOD NEWS- I have your rescue - if you haven't thrown the dang thing out yet. I went to the Samsung website and here is how to reset the V4600. Turn the unit on, then press the Fast Forward AND the Rewind buttons at the same time and hold down for 15 seconds. WHala... It's all back! Here's a link so others can view it. It gives the reset for all machines. They ARE different.
Good Luck!
Sparky
Aug 10, 2008 | Samsung DVD-V4600 DVD Player/VCR
Cannot play VHS
Combo DVD/VCR players don't output the VHS with Component Video. Most of the time, it won't output over the S-Video either. The high end outputs are ONLY for DVD output. You must run a yellow wire, or use coax cable to get the video. Same goes for the optical digital sound out. It's only for DVD use.
Feb 28, 2008 | Samsung DVD-V6700 DVD Player/VCR
No picture while playing DVD or VHS tape
Your unit has it seems to have developed a video problem. it could be in the video switching IC or the video processor. Its going to need a trained technician, who knows how to use an ocilliscope to find the video problem.. Good Luck
Aug 02, 2006 | Insignia IS-DVD1001 DVD Recorder/VCR
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
