Question about KitchenAid KSM90 Ultra Power Series Stand Mixer
When it was mixing, something broke, you could hear the snap inside. Now the beaters do not turn around. We were going to take it in and they asked if was made in CHina?
    President:
  • 3,433 Answers
Braun Coffee Grinder Mill Part - theEssentials.com Shop theEssentials.com for a wide variety of
Posted on Jul 14, 2009
Beater is stuck
I had this happen on my Kitchen Aid mixer. There is probably a build up of dough/cake mix etc inside the hole where the beater fits into. Fill a mixing bowl or a jug deep enough to fit over beater with very hot or boiling water. Immerse the stuck beater in the water up to where it connects in to the mixer and hold for about minute. Once the hot water has melted the build up you should be able to remove the beater. Hopefully this may work on your brand of mixer.
Apr 14, 2014 | Blakeslee DD-60 Stand Mixer
Kitchenaid stand mixer 5SSWH 325 watts. How do I adjust the bowl height? Beater is too far from bottom of bowl. Thanks! Cas
There is a screw at the bottom of the motor head (flat head) you usually can't see it because of the top rim of the mixing bowl. hard to see and hard to reach, it may also be hard to turn due to "gunk" from mixing stuff (egg butter flour sugar) turn the screw counter clockwise to lower the motor head clockwise to raise it, you may also have the wrong size beater, it is not an uncommon problem, if you are the original owner and you have the original beater it should fix your problem with the adjusting screw, however I am not clear as to your model a 5SSWH would actually be a K5SSWH, which stands for kitchenaid 5 quart solid state white mixer, if this is your model number and you have the correct beater size then the adjusting screw will work to lower the head down, adjust it down using the stir or slowest speed just untill you can hear the beater "Ding" against the bottom of the bowl, then back it off a quarter turn to adjust properly. Hope this helps, let us know
Apr 17, 2013 | KitchenAid K5SS Heavy Duty Commercial...
Professional 600 575 watts 6 qt. beater stem is loose and lets beater drop onto bowl.
b68be83b-c0cb-45d6-8d74-337f1cf098bd.jpgThe part you see is called the planetary, it has two shafts, the long one is called the center shaft and if it is falling off you need a new planetary, the second shaft (shorter) is called the agitator shaft (the beater attaches to it, if this is the culprit then1 you are not attaching the beater correctly2 the locking pin that the beater attaches to to hold it in place is missing3 you have way too much "gunk" build up on the agitator shaft and the beater is not attaching correctly4 if the beater falls into the bowl with the agitator shaft still attached you have three additional problems a) the snap ring a top the agitator shaft has broken off or come off which in turn means that
b) the gear at the top of the shaft has come off and may very well been knocked around and possibly damaged beyond future use which means that you will need a new one and also
c) the shaft pin that holds the agitator gear in place has come out or been broken also
the fix is easy and your parts cost $ will be from $30.00 to $80.00 dollars depending on which parts you need. Now before you get palpitations, cost are listed as a possible need
1 new planetary $30.00, you may not need
2 new agitator shaft and gear assembly $27.00, pretty sure that you need but maybe not
3 new gasket $6.00
4 new gear grease $6.00 KA says 2 oz. (don't buy a 2lb (26.00 bucks) can when you only need 2 oz).
Without more clarity or a picture I can't help further. but before you start tearing you machine apart go to the KA website and get a parts list for your mixer
http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD
let us know how you fare on this or better yet get us a little more info and we can help more.
Apr 17, 2013 | KitchenAid KP2671 Professional 6 Series...
Hi there, I was doing cake mixing and turn off
If you can hear the motor spinning and the beater does not spin, the worm gear has probably failed. These fail frequently, specially after using them beyond there designed limits. The motor heats up and the gear, which is a type of plastic or nylon, melts.
Feb 18, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Its bouncing when mixing
The head unit is not locked in place. If the lever is in the lock position and it still bounces, the cam lever inside has either snapped off or became loose.
Jan 18, 2011 | KitchenAid Food Mixers
MY KITCHENAID MIXER MODEL # KSM5 TURNS ON BUT THE BEATERS WONT TURN. I MIXED UP SOME PIZZA DOUGH AND GUESS I BROKE SOME GEARS OR SOMETHING. PLEASE HELP!!!!!!!!! THANK YOU
The most common part to fail in this mixer is the worm gear:
http://kitchenaidmixerspares.co.uk/Home/tabid/36/p/Mixer-Part---Worm-Gear-and-Bracket-240309-2/ProductID/103/CategoryID/17/Default.aspx
Oct 31, 2009 | KitchenAid K45SS Classic Stand Mixer
Mixing attachment for stand mixer is stuck
I had this happen today. I took a towel and covered all of the beater except where it attaches. I sprayed WD-40 on it. This loosened it and it came unstuck. Then I washed it thoroughly with hot water and soap. It had some dried batter stuck inside which caused it to stick. Guess I better pay better attention to how clean I get it inside. PS Don't spray WD-40 anywhere else - this is something you make food with!
Mar 28, 2009 | KitchenAid KP2671 Professional 6 Series...
Mixer turns on but the beater doesn't rotate
Remove the metalic ring around the mixing head. Push down on it with a flat head screwdriver...
Remove the pin from the mix shaft.
Pull down on the mixer head. Inspect the gears.
If nothing wrong here, disassemble completely and inspect drive gears. Something is broke and needs replaced. You need to find it first, then take that broken part to the dealer to get a new one. Good luck
Feb 24, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Mixer runs, but will not turn beater.
You are correct, in the mixer head above the attachment hub is a gearbox, and there is a fiber gear meant to do just that should something similar happen, it can be replaced, I don't know price, but if you are careful, and fair mechanically, it is a straight forward replacement.
Dec 30, 2008 | KitchenAid K45SS Classic Stand Mixer
Just get clicking sound . . . beaters don't move
you snapped one of the drive gears. Your gonna have to get someone whos mechanicly inclined to take apart the drive motor assy and see whats broke. You should be able to get the parts at http://www.repairclinic.com good luck
Jul 15, 2006 | KitchenAid KSM5PS Heavy Duty Stand Mixer
KitchenAid KSM90 Ultra Power Series Stand Mixer Logo
133 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
