Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Convergence problem... My television is more than likely convergence as you have spoken of, the colors are separated, the picture is bowed or warped, but I don't have my original remote. It died years ago and I have a universal philips remote. Can I still try to fix it with the remote? I did use the menu on the tv but it got to where it says press m on the remote. Thanks.
  • 767 Answers
Even if you had the original remote you
could not adj the pic for the failing convergance
chips. have a shop swap the chips . its
takes me about an hour + .price should be
no more then 175.00 part/labor. ps you
will may need to order the original remote.
to set up the convergance , wait have the
shop do that for you.
Posted on Jun 29, 2009
RCA 52WM24 COLORS SEPARATED, AND PICTURE IS BOWED IN MIDDLE
Yes,convergence is dead,U know how to solder right?Buy the convergence kit,replace what in that kit.Also buy a DVD for instructions,never done this before,for safety reasons.Tries these websites Tv Repair World.com Or Ebay.com.
Sep 29, 2009 | RCA R52WM24 52" HDTV Projection Television
The colors are seperating and screen picture is bowing in?
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 26, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Warped picture = can't seem to adjust with advanced convergence menu
Ur convergence it dead.U know how to solder right?Tries this websites for the convergence kit.Tv Repair World.com,Shopjimmy.com,Ebay.com or Partstore.com
Sep 25, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Colors far out of convergence, and image is warped (bowed)
it sounds like bad solder connections on the convergence IC's if you do not resolder them right away the IC's will blow out then you wil;l have to replace them. Good luck
Larry Dillon
Aug 14, 2009 | Sony KP-57WV600 57" Rear Projection...
Picture doubles and looks like 3d
Your TV most likely has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 21, 2009 | JVC AV-56WP74 56" Rear Projection...
I have a 42'' where the color in the top left corner seems to have separated, or shifted. The picture is ghosted in red and green in this area. It happened all of a sudden.
  • Screen looks 3D
0667c5f.pngSOLUTION
Jun 19, 2009 | Akai PT4298HD Rear Projection Television
Off colors in picture
Your TV most likely has a Convergence Chip Failure ( common problem )
  • Screen looks 3D
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
May 14, 2009 | JVC AV-48WP74 48" Rear Projection...
Picture double an inch from the left side
Your TV most likely has a convergence problem.
Nov 12, 2008 | Sony KP-51WS510 51" Rear Projection...
Picture Problem , Sony Projection TV
Your TV most likely a convergence failure. ( common problem )
  • Screen looks 3D
0667c5f.pngSOLUTION
Oct 01, 2007 | JVC AV-56WP84 56" Rear Projection...
Warped Picture, Separated colors
Each color (red,green & blue) has an amplifier IC (STK-).
When there is a convergence issue,the first step is change both
IC's for reliability. Then check for open fuses devices,usually
pico fuses.Then re-check convergence alignment.......T.
Feb 07, 2007 | Philips 60PP9352 60" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
169 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
