Question about Asrock K7VT2 Motherboard
ASROCK K7VT2 rev.2.01 manual
I need the motherboard manual for a ASROCK K7VT2 rev.2.01 can you help me?
  • 1 more comment
  • Anonymous Nov 07, 2007
    I need to know which direction to put the audio jumpers JR1 and JL1 on my ASROCK K7VT2 rev.2.01 motherboard, can anyone send me a link for the right manual?
    I require the manual ver.2.01 not ver.1.01 for my K7VT2 motherboard .
  • Anonymous Dec 05, 2007
    need motherboard manual/asrock k7vt29, ned jumper settings, bios
  • 34 Answers
Hi mate
use this link for your manual (acrobat format)
http://www.asrock.com/mb/manual.asp?Model=K7VT2&s=
Posted on Nov 07, 2007
  • simon philips
    simon philips Nov 08, 2007
    just checked the website again, it does only list ver 1.01 with that being the official site for your board, it would be difficult to source another website with a newer version of it
    have you tried swapping the pins around in differnt orders, (trial and error)
    if i personally would install a new sound card, for less than a tenner, you can get a new one,
    headache over ;)
Hello, I want to know, if the motherboard Asrock K7VT2 can support DDR2 memory.
No, it supports DDR, SDRAM...front side bus speed 266/200 MHz...you can max out with 2GB's of PC3200...1GB in each slot. I hope this helps.
Aug 06, 2011 | Asrock K7VT2 Motherboard
I hear 1 beeps then 8 then 2
CHECK VIDEO CARD, MEMORY AND PROCCESOR.
May 11, 2011 | Asrock K7VT2 Motherboard
Just bought and installed AsRock K7VT2 and CPU Athlon XP 2200plus XP Pro SP3 512 MBytes Synchronous DRAM GeForce 2 /MX400 AGP x4 The computor starts but i can't get into BIOS only got a black...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
May 05, 2011 | Asrock K7VT2 Motherboard
How i reset the bios
There should be a battery on the motherboard. Remove the battery for about 30sec then replace will remove the password.
Apr 18, 2011 | Asrock K7VT2 Motherboard
RAM Slot does not recognize more than 512MB ( 184 )
Consider updating your motherboard bios.
http://www.asrock.com/mb/download.asp?Model=K7VT2&o=BIOS
Also make sure that your memory is correct for this system:
- Max. capacity of system memory: 2GB DDR or 2GB SDRAM
- DDR x 2, DDR266/200 non-ECC, un-buffered memory
- SDRAM x 2, PC133/100 non-ECC, un-buffered memory
Jun 26, 2010 | Asrock K7VT2 Motherboard
Image problem
It not your motherboard . If you had issue with Video card you wouldn't be able to display anything . Try doing what it is your doing on another monitor .
Use DVI ( white ) plugs if you can for a much better image display
Please don't forget to rank my responce to your question .
Thank you
Aug 06, 2008 | Asrock K7VT2 Motherboard
Monitor problem
Hello soltaino, your board (K7VT2), did not come with a video card. (New). If you have a video card in your PC it was added. I'll need to know the name of the card to advise you regarding a cable to connect to the monitor. My guess is it's like the pictures listed below.
The Asrock does have an AGP 4x video slot. If your board has a video card installed it's connector would connect to a standard VGA connector at both the monitor & at the video card.
Whick looks like this.
The picture above shows a female VGA port, (like on a monitor).
b9662ed.jpg See the bue cable. That's a standard SVGA cable connector.
If you can not connect to the PC you need a new video card, not a new monitor. http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3667003&CatId=876
Suggest this card. It has both VGA & DVI connectores.
Best Regards!
Mike
Apr 01, 2008 | Asrock K7VT2 Motherboard
BIOS
You did not mention what problem you have! Either way it's an old board, if the bios is messed up all you can do is flash your bios with the latest firmware from the link below:
http://www.asrock.com/mb/download.asp?Model=K7VT2&s=
Or is it a setting issue?
Jan 13, 2008 | Asrock K7VT2 Motherboard
K7VT2 with a AMD Duron 1.30 GHz CPU.
Depends on which AMD processor you would use. If Duron you could go to 1.8Ghz. If you use Athlon XP you could go to 3200+. Athlon MP 2.1Ghz and regular Athlon 1.4Ghz.
Nov 13, 2007 | Asrock K7VT2 Motherboard
Does not power up
I think you've done a good trouble shooting job, and proved that the board is dead.
Oct 20, 2007 | Asrock K7VT2 Motherboard
Asrock K7VT2 Motherboard Logo
505 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
