Question about Epson Stylus CX9400 Photo Printer
Prints in wrong colors and makes grinding noise while printing.
    Sergeant:
    Champion:
  • Epson Expert
  • 387 Answers
Check cartridges if colors installed properly. Print heads can be damaged. If still under warranty Epson will exchange if free, if not call tech support.
Posted on Jun 30, 2009
Kyocera 250ci making grinding noise
First you have to check the counters to see how many pages were printed or copyed. It may be a problem with some of the color drum units. At this model you need to change the units near to 100.000 A4 prints with 5% coverage. If the coverage is greater, then you'll need to change them sooner. There might be another cause for the sound, like the Transfer Belt Unit. This unit has a "waste toner path" that might be jamed. The unit is not able to get rid of this waste toner and some gears produce that noise. The transfer belt unit is working separatly for black prints and color print. You will have to remove the Transfer Belt Unit and clean the toner path with a vaccum cleaner.
Oct 23, 2014 | Kyocera Mita Office Equipment & Supplies
Why does it make grinding noise when printing?
Check the toner cartridge and the fuser unit for worn gears.
Apr 01, 2014 | Dell C1765nfw Multifunction Color Printer
Grinding noise
I just chatted with Dell support about this since I have the same problem of the grinding noise on my C1760NW Dell printer. I have it plugged into an APC backup battery which acts like surge protector (unless power goes out then battery kicks in). He said the printer needs more power and that surge protectors and battery backups are not good for this printer since they restrict the power which sends less power to the motor and fuser than what it was designed for. So with less power from the APC backup/surge protector, the motor moves very slow and may not fuser the toner to the page correctly and can cause permanent damage over time. So I plugged into the wall directly instead and the grinding noise went away immediately even when printing 10-15 pages right after plugging into wall, but then the noise came back when I printed a bigger job. So for now I'm letting it cool down for a couple hours and crossing my fingers that the damage is not permanent. So... answer is plug it into the wall directly for maximum power and hope that your printer is not permanently damaged. By the well, Dell support chat was awesome.
Mar 11, 2014 | Dell, Inc Dell Color Printer C1760nw -...
HP Color Laserjet 8550 - Loud grinding noise near fuser
Hi Harden,
Thats an issue with the fuser assembly,try to check the teflon condition/ teeth gear might have worn out.
Jan 30, 2014 | HP Color LaserJet 8550dn Printer
Grinding noise in copy mode?
The Grinding Noise has something to do with the scanner not the Printing Part, I think the scanner could have something stuck on the moving tray....!!!!!!
Apr 18, 2013 | Lexmark X8350 Print, Scan, Copy and Fax...
Lexmark C510 is making grinding noises while printing large jobs
I found another posting stating that the culprit was the black toner cartridge. Sure enough I changed our black cartridge and the grinding noise has stopped. No wonder the grinding noise was not happening all the time only when the black cartridge got low. Thanks for the help!
Oct 15, 2009 | Lexmark C510 Laser Printer
HP Deskjet 1320 printer makes grinding noise and stalls before it prints
I think the noise is normal for hp deskjet. When starting up, the printer read the head existence, and do cleaning. is it the first replacement cartridge? Disable ink status monitor.
May 29, 2009 | HP Office Equipment & Supplies
Printing noises - no ink transferring
Sounds like you may need to replace the developer drive assembly. This is the motor and gear assy that drive the color developers. it is located on the right side middle, 3 screws hold it in place. be careful when replacing to not over tightened screws.
Apr 09, 2009 | Dell 5100cn Laser Printer
Loud noise
If your also encounter prints that have a roller/crease at the right and slight crinkling at the left then your fuser should be replaced.
Nov 19, 2007 | HP Color LaserJet 2600n Printer
Printer makes noise while cleaning heads
Grinding noise is most likely caused by the carriage lock getting stuck and holding the print head at the home position. The noise is caused by the toothed belt that pulls the head back and forth, skipping over the splines on the motor drive wheel. If you have been able to print since the problem occurred, chances are that it has freed itself up and will be fine. Regarding the loss of cyan & magenta output, follow the solution given in my previous posts to complete a manual under-head cleaning cycle. This should get you going. Check this previous post for cleaning info: http://www.fixya.com/support/t137335-problem_print_outs_from_printer
Jul 05, 2007 | Epson 1000 ICS All-In-One InkJet Printer
Epson Stylus CX9400 Photo Printer Logo
93 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
