Question about Maytag Dryers
My 15 year old Maytag Dryer is starting to squeal from the drum rubbing metal to metal up front. The Belt is in good shape. What else could be problem?
    Scholar:
  • 116 Answers
Time for a new one I think, but here goes.
The drum guide rollers at the rear or the guide pads at the front will be worn out, due to the age parts may be difficult.
To inspect:
Electrically Isolate the machine, at the joint between the front panel and top panel insert a flat blade 4" from each side to release the top catches and tilt the lid back to open, remove the front panel internal screws and remove the front panel.
The drum and machine internals can be seen.
Remove the drum belt - note the belt path direction around the motor and belt tensioner.
The drum removes by rotating and easing forward, there will be pads or rollers that support the drum, check these as they are the most probable cause.
Posted on Jun 29, 2009
How do I stop my GE dryer from squeaking
Check belt look for location of noise and look for items in that area you should locate with process of elimination .
Mar 03, 2016 | GE Dryers
Dryer runs but makes loud screeching noise like a fan belt or similar. Does some drive belt need to be replaced?
yes most likely it is the drive belt. pretty easy replacement. go to repairclinic.com or appliancepartspros.com for very good videos to show you how this is done. good luck
Jul 11, 2015 | Dryers
My Maytag pye2200ayw has been working great until today when a horrendous squeak started. I've taken the front off but am still having trouble locating the origin of the noise. The two pads supporting...
remove the drum a look at the rollers, here is a website to assist you, Tim:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Mar 06, 2011 | Dryers
My Maytag dryer (model # MDE4806AYW) makes a grinding sound all of the sudden. Sounds like the cylinder drum is scraping on something. The dryer is only a couple of years old. What do you think needs to be...
Could be your front glides on your drum housing. They are just Teflon pads that the front of the drum rides on. If they wear down you will get a metal on metal rubbing. The part number is 40116501. The other possibility could be your rear rollers going bad but they usually will make almost a squeak usually. They are what support the rear end of the drum.
Hope this helps _MJ_
Jan 29, 2010 | Maytag Dryers
Rubbing noise metal to metal
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the roller with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve you noise problem.
Good Luck,
I hope this helps
Oct 11, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
The dryer squeals (metallic sound) while drying clothes.
check wear pads around front of drum or rear depending on brand. Ge's are particularly prone to scraping sounds, but still one of my preferred brands. IF a ge, did it get any dents around the sides or back? The drum is close to the sides and a dent in right place will do it. Also the rear panel can push the drum forward rubbing in front.
Ge - wear strips in front, plastic bearing in rear center, replace both, inexpensive.
Whirlpool- felt pad and wear strip in front, felt seal in rear with roller support. check rear seal lube rollers
Maytag -roller in front and rear with front and rear felt seals. some designs have front drum support posts with wear pads. ck these.
Frigidaire (include some sold under GE name) rear bearing cup (plastic)-lube, front feltpad with wear plates if plates gone get new pad/wearplate asm.
Maytag and ge nomenclature tags are in rear .
Jul 19, 2009 | Dryers
Rubbing noise
Try checking the glide's under the front of the drum, the drum rest on the glide's to help it spin with little or no friction.
Apr 06, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My dryer squeeks when running
Hi, I've had a similar problem (I think) on my MDG7400 dryer. There was a cyclical squeak, metal against metal. It turned out to be the screw that holds the drum paddle to the drum. It had worked itself loose and was scraping against the inside wall of the dryer. Remove the front door lift the top, and tighten 'er up. Hope that helps.
Nov 19, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag atlantis dryer squeals very loudly when running
you have answered your own question! The belt will have become loose due to age/stretching. You hear cars making the same squealing noise when thgey rev up. Its a real squeal/screech. It may possibly be the drum rubbing on the chassis due to beariing failure, but doubtful.
So on some machines the motor is on adjustable brackets that let you move the motor away from the drum pully by loosening the bolts/nuts and then re-tighten. Don't leaver the motor down and then lock off the nut/bolt as this will make the belt too tight, and cause the belt to fail or the bearing to fail over time Take the back cover off the machine and all will be revealed.
best of luck it's a simple fix if your diagnosis is correct
Nov 13, 2008 | Dryers
Drum roller support
You can try some very light oil on it to see if it helps. Also check the heating element housing and mounts. Sometimes you will get some sheetmetal squeeks as things heat up and cool down causing the sheetmetal to loosen and rub against each other.
I am sure you can get the parts locally, if not you can order them off the net or from Sears.
Post back to let me know what you find out.
Oct 27, 2007 | Maytag MDE2400A Electric Dryer
Dryers Logo
130 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
