Question about GE Refrigerators
My refrig. normally maintains 34-35 degrees. it is pushing 40 degrees - i cleaned the coils and noticed that the fan is not running. does this mean that the fan is bad, or could there be another problem?
  • 2 more comments
  • marlin1974 Jun 29, 2009
    temp is pushing 40 degrees and fan is not running. couldn't this be something other than a bad compressor?
    as i was asking for advice, the fan kicked on and the temperature has dropped .6 degrees. my gut tells me that there is nothing wrong with the compressor.
    advise please
    I appreciate the time you took to answer my concerns, and I do accept your solution and advice, unlike the other "so-called" tech (Kamal1984) who, in less than 25 words, was posaitive that the compressor was low or bad. To me, this was obviously a person who was more interested in spending my money than taking the time to fix the problem. Again, I thank you and recommend that Kamal1984 be removed from the tech. list.
    thanks mgprice for taking the time to help me.
    Kamal1984 appeared not to care or lacks necessary knowledge.
    President:
  • 744 Answers
Hello, your condenser fan does not normally run all the time and would not effect the running of your refridge it's primary function is to evaporate the water in the defrost tray and keep the compressor cool...Your problem is going to be 1 of 3 things...1st thing to do is remove the panel at the back of the freezer compartment...does your evaporator look like an ice block? if so melt the ice and check the defrost heater, If defrost heater bad replace it if working replace defrost thermostat. If the ice build up is not too bad check the evaporator fan, if it is fixed to the panel in the freezer conpartment take the screws of lean it forward to where you can see the fan and take a look over the period of a half hour..if it does not turn on in this time replace it. basically your problem is your refridge not getting cold air either because the evaporator is a block of ice and there in no airflow or your evaporator fan is not running. Hope this helps, if you have any further questions or concerns please feel free to comment again. Good luck!
Posted on Jun 29, 2009
  • Mike Price
    Mike Price Jun 29, 2009
    As previously stated the tepm problem is not going to be with the condenser fan, if temp iis dropping leave alone and check in a couple hours..if temp still does not drop to desierd temp the check the parts in my previous solution :) good luck
  • Mike Price
    If you are not happy with another tech's diagnosis you are able to rate his and my solutions with the little hand widgets below...people who recieve bad ratings do not last on here and are taken off the expert list. from the diagnosis he gave you he has no experiance in this field...sorry you had problems :)
    President:
  • 1,383 Answers
You need to repair your compressor or change it.
check gas in comperessor is not empty.
  • kishor
    kishor Jun 29, 2009
    It should be compressor problem.
    There is no issue with other .
The strip between freezer and refrig become hot then cools off. It's like it is going thru a cycle. We cleaned the coils underneath, but it is still getting hot and then in about 15 minutes, it's...
When you cleaned the coil underneath did ya notice that their was air being blown out their by a fan,having clened the coil was a good start but if the fan by the compressor isn't running that divider between the ref/freezer will be hotter than normal( its normally warm and thats ok),so check that the condenser fan is running and that it seems to running at a good speed.
GENE
Sep 23, 2011 | Whirlpool GC5SHEXNS Side by Side...
I have a Kitchenaid S x S KSCS25INSS00 refrig/freezer. We lost power for 30 hours, it worked fine before the outage, now it won't cool the fridge below 48 degrees, or the freezer below 43 degrees. ...
Try replacing the circulating fan first. If it's not turning, it's more than likely bad. However, the fan might not be your only problem. The problem may lie with the icemaker. The icemaker is essentially the brain of the unit. It tells when to cool, when to defrost and when to maintain temp. Your icemaker may be stuck in defrost mode.
Sep 04, 2011 | KitchenAid Superba Architect KSCS25INSS...
Freezer in the gararge redfrigerator quits working when outside temps get real cold
hello. this is a common problem. The thermostat for a refrigerator/freezer is in the refrigerator part. Normally the refrigerator is kept at around 40 degrees. The compressor turns on as required to maintain this tempearture. The evaporator coils are concentrated in the freezer side, so that the freezer stays at around 0 degrees while the fridge side is held at 40.
If the ambient temp is around 25 degrees, the refrigerator compartment will get below the setpoint of 40 degrees, and gradually continue down towards 25 degrees. The compressor will not have to run at all to maintain this. In fact, the compressor is designed not to run, once the refrigerator compartment gets below the setpoint, for fear of freezing the contents of the fridge.
The lack of circulating refrigerant due to the non-running compressor means that the freezer compartment will gradually warm up to 25 degrees.
If the unit were just a freezer, it would work fine in the unheated garage. If it were just a refrigerator, it would not run in these conditions, and the contents would eventually freeze, but it is otherwise OK.
Regards, Joe PS kindly rate my answer. Thank you.
Jan 19, 2010 | Refrigerators
My freezer temp registers 28 - 36, I cleaned out coils, I notice that there is a fan in the back bottom right side, not sure what should make that run. My Ice is slowly melting. I had the freezer setting...
That fan behind the refrig , is the fan that cools the compressor . It should be running any time the compressor runs . If not running , replace it . The center divider between the fridge and freezer ( front strip ) should be getting hot to the touch if the fan is not running .
Sep 11, 2009 | KitchenAid Superba Architect KSCS25INSS...
Gets to 35-40 degrees then doesn`t maintain till is shut down and started over again.
This can be caused by the drain hole below freezer coil being blocked by ice. You MUST remove all ice in drain under freezer coil. Use turkey baster to squirt hot water into hole and use hairdryer to defrost. Possible defrost thermostat is defective. Unit never goes into defrost, ice forms on coil and in floor of freezer. After defrosting may work OK for a week or two but gradually gets warmer because ice is blocking ports where cool air gets to refrig. May also have water in refrig box. Can also be caused by defective defrost timer.
Aug 21, 2009 | Refrigerators
Runs constantly to maintain 40 degrees, requires highest setting
Not sure how old it may be, but you can check a few things to see if it's defrosting properly. Also clean the condenser coils under the refrigerator to insure good circulation of air over coils. In the picture below you will need to check out three things until we find the problem. Defrost timer, defrost heater, and defrost thermostat. Let me know when your ready, Sea Breeze
seabreezehvac@yahoo.com
Apr 20, 2009 | Refrigerators
I have noticed that fridge seems to be running alot lately I did all routine maint. cleaning coils etc. and it still seems to be running alot. model number is afd2535dew top fridge french door. Is there an...
not really sure as far a swhatconstitutes ruining along time, you are doing the right thing by keeping it clean for sure, refrigs now run for as long as they need if it never stopped running youd see hte effects of that in 2 ways, either all your food would be FROZEN solid( cause it never shuts off), or your food would be spoiling quicker hat n usual, in which case your refrig is trying to run all the time to maintain temps! the noise that you hear running might just be the evap fan motor running( circulater fan, sure its gonna run to circulate, but the compressor wont be running all the time.. check and go by your dairy products, ice cream too hard or too soft, and in refrig check the milk and butter.youll never know how cold you leftover is but youll know right away if the milk it too warm
Mar 19, 2008 | Refrigerators
Refrigerators Logo
53 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
