SOURCE: allis chalmers 912 hydro belt diagram
I also have the same tractor but i have what your looking for so my email address is [email protected]
SOURCE: Spindle on 6060 keeps breaking are the front ends
There are other AC tractors with heavier spindles that can be substitued as long as the kingpin diameter is the same. I believe the 6070 may work. But then you might also need different bearings and wheels. But the biggest problem is to not force the steering wheel when you are not moving. Spindle breakage is always driver error.
SOURCE: I have an Allis -Chalmers 416 tractor with mower
There are 2 holes at the front on the frame you need to put a pin and cotter pin through each side to hold the front of the mower. Then there will be a hangin piece of straight metal about 2-3 inches long with a hole in it that you need to hook up the chain to also with a pin with a hole in it and a cotter pin. This will allow you to raise and lower the deck with the electric lift. If you need pics let me know i'd be happy to help.That's all there is to it besides putting the belt on.
