Question about Kenmore Dryers
Kenmore Elite electric dryer not producing heat
We have a kenmore elite dryer, model # 110.82826101, that runs but doesn't produce any heat (on any setting....one setting, Heavy duty, i thought there was a little heat coming out, but not sure). We already replaced the heating element thinking that would fix problem, but it didn't. Old heating element was really dark/burnt looking? Noticed the two relay switches? or sensors, could these be the problem?
catriver
  • 878 Answers
SOURCE: Kenmore Elite Heavy Duty King Size Capacity Quiet Pack II Dryer
cutiepie, I've seen this many times on these dryers. You need to replace the door hinge. Not really a hard job to do. Post a model number (inside door) and we'll get you a part number...Catriver..post back.
Posted on Feb 19, 2007
IFIXALL
  • 868 Answers
SOURCE: Kenmore Elite gas ddryer model 72062--No heat
Check the glow coil ,if its not glowing run a test for voltage when its heating ,should be around 117 volts.check thermal fuse.
Please Rate This !!!!
Posted on Aug 11, 2008
  • 17 Answers
SOURCE: My Kenmore Elite HE3 Dryer is not drying.
It may not be your heating element. Your dryer lint vent pipe out the back of the machine or maybe out the side may be plugged. You have to pull the machine out and clear that pipe or rebuild it out to a soffit vent or static vent if it is in the attic, or out through your crawl space. This will make a huge difference. If that hot air and moisture doesn't get out of the machine it just goes back into your clothes.
Good luck!!
Posted on Mar 25, 2009
blueextc3221
  • 15935 Answers
SOURCE: hAVE A MODEL KENMORE ELITE He4 ELECTRIC DRYER. IT
Check the burner tube and clean it out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore elite heavy duty king size quiet pak 1
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#$^&
Wont produce heat
U need to check the device responsible for generating heat - if electric it is the heating element(s) - if gas make sure the pilot is lit and there is gas going to the unit.
Aug 09, 2015 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore 100.85081400 no heat
check the thermal fuse on the blower housing if its open some units wont heat,also check the heating element if heated electrically,or the ignitor on gas fired units,by the number you provided i believe you meant its a 110.85081400 instead of the 100.85081400 (and is electrically heated) you provided which is produced by whirlpool for sears (kenmore) also there is a control board located inside behind the control panel that may be a culprit,but check the first two things i suggested at the top
Jul 23, 2012 | Kenmore Elite HE4 Electric Dryer
Kenmore elite model 11062952100 My dryer will not heat I replaced The thermal cutoff and high limit thermostat the dryer produce heat briefly but is not producing heat again.
There is a high limit switch (looks like a button with two wires hooked to it) on the bottom of the vent frame. When the vent fills up with lent at the bottom it gets hot. For safety, this limit switch will turn heat off. Remove the vent frame and clean it out and check the continuity of the switch. Also, make sure both heater elements are working properly.
Jun 19, 2011 | Kenmore 63942 Dryer
No heat-Kenmore (Whirlpool) Elite He5 Steam 110.8775
Check that there is 240 volt at the plug as sometimes a breaker will be weak on one side and only produce 120 volts which will let the drum spin but produce no heat
Mar 20, 2010 | Kenmore Elite 45986 Front Load Washer
My Kenmore elite dryer is not producing heat
if not heating at all the heating coil could be burned out.
Dec 19, 2009 | Kenmore 62602 Electric Dryer
My Kenmore Elite (Whirlpool) HE3 elctric dryer is no
A dryer not heating usually means that either the heating element is burned/broken (open circuit); a thermal fuse in line with the heating element is blown or; a thermostat is faulty.
Dryer needs to be partially disassembled to diagnose with a multimeter.
Charlie
Sep 29, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
HAVE A MODEL KENMORE ELITE He4 ELECTRIC DRYER. IT
Sep 26, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore elite dryer will turnover, produce heat, but will not dry clothes and after 70 min, lots of moisture in dryer
Sounds like the dryer is not venting. Check to see if the vent tube is kinked or the end is covered.
Sep 23, 2009 | Kenmore Elite HE4 Electric Dryer
Aug 10, 2008 | Dryers
Kenmore dryer (electric )
NOT ELITE HE4..... Model 96595400. Replaced thermistor and Hi-Limit Stat. Probably the thermistor.
Jun 28, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
118 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
