Question about Neff B1421 Electric Single Oven
Broken screw of Light bulb stuck in Neff Oven
I've easily changed  the bulb before on this 8 yr old Oven. This time the glass part of the bulb came away leaving the screw part deeply entrenched. Very difficult to access! If this were a light fitting i would expect to dismantle the whole thing.
Neff say its safe if the glass cover is over it.
  • Anonymous Mar 30, 2014
    the mounting that holds the oven light has broken and is loose
    The holder for the oven light is broken
  • 417 Answers
Hi,,
make sure the power is OFF. get yourself a flashlight and a small flat blade screwdriver. okay you have to make a small bend in the old light bulb screw area so you can get a pair of needle nose pliers in there to get that out, you need to get right in between the threads of the socket and the old light bulb, just enough room to get a pier of needle nose to turn the old bulb out, be careful take time
J
Posted on Jun 29, 2009
The thread part of the oven light bulb is stuck. How can I remove it?
uNPLUG FROM POWER. WITH A SMALLISH, NARROW STRAIGHT SCREWDRIVER, ATTEMPT TO GET THE TIP BETWEEN THE BULB SCREW AND THE BOLDER AND ,GENTLY BUT FIRMLY ATTEMPT TO BEND THE SIDES OF THE BULB SCREW TOWARDS THE MIDDLE.WHEN A FEW BITS OF IT ARE DEFORMED THAT MAY ALLOW YOU TO UNSCREW IT.BE CAREFUL NOT TO APPLY TOO MUCH FORCE,YOU DO NOT WANT TO DAMAGE THE SOCKET OR SNAP IT OFF.
I have assumed that the glass part of the bulb has snapped off?
GOOD LUCK WITH THIS
Jun 14, 2015 | Neff Ovens
Removal of interior oven light
Most require a simple 1/4" nut driver to remove 2 screws that hold the glass housing over the bulb. Then just unscrew the bulb and install new one.
Sep 06, 2014 | Neff B1421 Electric Single Oven
How do i remove the light bulb in oven
Try using a thinnish sink spong to get a better grip on the bulb, which screws out anti-clockwise but can be very tight (as you've now found!). You should also wear a protective glove in case the glass breaks when gripping it. If it does break it will then be necessary to use some needle-nosed pliers to get it to turn for removal. Good luck in getting it out.
Mar 11, 2012 | Neff B1641 Single circotherm super...
Shelf fitting slot broken off
Use the link http://www.neff-eshop.com/eshop/neff/gb/prodlg.htm?x=0&y=0&Maktx=Neff+U1721&eshoptype=Aenter the FULL enr from the rating plate, don't just pick the nearest one if the enr is U1721N0GB/75 that's the model you need to check as parts from one model to another can vary. This will open a diagramatic breakdown of the oven and you can search for the relevant part (and buy if online direct from Neff). Couple of things to remember, make sure you have the right oven (ie top or bottom) and whether it is the front or rear holder as one is like a keyhole and the other is a keyhole on its side.As this is a build under unit, it does make changing the part a little easier (depending on which one is broken, hoping for your sake that it's not the back top oven one..Argggh!!) You will need to get the oven out and I find it easier if it's on it's side with the faulty holder at the top. The side panel needs to come off (or at least be loose if it's a front holder) as the holders are held in place by a retaining clip behind the cavity wall, or if it is a screw in type, the screws comes in from behind the cavity wall. I suggest you order and get the parts first and this will give you an idea what you're dealing with. Let me know how you go and post any comments or problems you have whilst doing the repair (anything I've forgot to add) as this will help anyone else looking for a solution to a similar problem.Ps. If you are sensitive to fibreglass, wear a pair of gloves.
Nov 23, 2011 | Neff U1721 Double circotherm Electric Oven
I am trying to replace the bulb on my Neff B1422NOGB oven. The instructions say to unscrew the glass cover anticlockwise. However, the cover only turns by a small amount (maybe just 5 degrees) and...
A common problem with this manufacturer I'm afraid. The screw thread of the glass almost welds itself to the metal casing it screws into.
It will turn and you can remove it however, the easiest way is to get leverage on the glass. This is best done by using a Baby Boa Strap Wrench, which you can pick up for a few pounds in a DIY store. I have removed many apparantly stuck round glass oven lamp covers in this way.
Aug 26, 2011 | Neff B1421 Electric Single Oven
How do you cget the cover off the light in the oven in order to change the oven bulb?
If it is a round glass cover, then all you need to do is grip it firmly, and unscrew it anti-clockwise.
If it is a square glass cover in the side, then it may be held in place with a screw or spring clip.
Hope this helps.
Dec 16, 2009 | Neff B1641 Single circotherm super...
How to change the light bulb
unscrew cover glass to gain access to bulb it unscrews normal thread very easy if glass stiff heat up oven for a few minutes and try again
Dec 10, 2009 | Neff B1421 Electric Single Oven
I have a neff oven, cannot remove glass cover to change bulb. Was advised to buy strap wrench, no good. Advised to heat oven, no good. Cover moves about quarter inch, when heated , nothing. can you please...
Having tried several ways to get the glass cover off, there is one other thing you can try.
Spray some WD40 around the glass cover,and keep trying to tighten and then unscrewng it, and tighten again.
If this does not work, then the last resort is to break the glass cover, which is what I have had to do in the past,. but make sure you can get a replacement cover first.
Please rate my solution.
Thanks.
Nov 24, 2009 | Neff U1721 Double circotherm Electric Oven
Change Bulbs in Neff U1661 Oven
You don't need to slide the oven out, just remove the glass covers with a flat bladed screwdriver and then unscrew the old bulbs. Replacement is the opposite.
Bulbs available from Homebase, Wickes, BandQ etc etc.
Apr 27, 2008 | Neff U1661 Double circotherm super...
Change light-bulb
You need to remove the whole oven from its cabinet (after switching off the electricity supply). Removing the doors first; (see http://www.youtube.com/user/Apart4u for videos of this) then remove the facia, which allows you access to the two restraining hooks near the top of the sides of the oven. With these slackened off (screws at the front) and pushed back, the oven can be slid out of its housing - be careful, it's heavy - onto a similar height workbench in front of the oven housing. Removing the wiring hatch (2 screws) and the rear panel (6 screws) gives access to the screw in bulb. Hope this helps :)
May 17, 2007 | Neff B1421 Electric Single Oven
Neff B1421 Electric Single Oven Logo
1,067 people viewed this question
Top Neff Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
Are you a Neff Oven Expert? Answer questions, earn points and help others
