Question about Acer Computers & Internet
Acer b233 hu monitor re-awakening issue
Acer b233 hu monitor won't come back up after going into monitor standby.
This is not a solution. When reviewing the problem more we found out that the monitor and the computer are behaving normally under a user with administrative rights. The problem emerged when a basic user tried to put the monitor to standby.
Posted on Jun 30, 2009
Won't go into sleep mode
Which operating system ?
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work.
This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation.
Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money!
Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow.
The Shut Down menu appears.
Point at "Sleep" and click on this option.
Your Windows 7 computer goes into sleep mode.
Wake your computer from sleep mode by jiggling the mouse.
There may be a delay of a few seconds before your hardware powers on.
All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode.
Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time.
Click "Start" and select "Control Panel." Click "System and Security."
Click "Power Options."
A menu opens.
Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode.
If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity
Your Computer in sleep mode
First, save all of your work. Information in computer memory is not saved while your computer is on standby.
From the Start menu, select Settings, then Control Panel, then Power Management.
Click Standby Beside When I Push the Power Button.
Push the Power button.
Automatically Putting Your Computer on Standby
Save all work before leaving your computer.
From the Start menu, select Settings, then Control Panel.
Double-click Power Management.
Set the times that you want your system to go on standby, to shut off the monitor and to shut off the hard disks.
Click OK. Your computer will go on standby according to the schedule you have entered.
Putting Your Computer in Hibernation
Double-click Power Settings.
Click on the Advanced tab.
At the When I Push the Power Button On My Computer screen, click Hibernate.
Click the Power button.
Hope this helps.
Nov 25, 2012 | Dell Factory Refurbished 4700-HH79N81...
Acer p241w stays standby
CHECK IN BIOS MODE ,THIS PC NOT GOES TO STANDBY SO PROBLUM IN YOUR OS .FORMATE PC NOW CHECK .
Aug 31, 2017 | Acer P241W 24 inch Monitor
Acer x193 monitor went into standby overnight. I have it set not to do this. Now, it has a hissing noise when turned on and it flickers and is dimmer, regardless of the settings.
It's actually not in standby, the power supply on the unit has failed. This is a common issue with those monitors. The first thing to check is to see if it's still under warranty. Acer monitors have a 3 year parts & labor warranty from date of purchase. If you can't find your receipt check the label on the back of the unit for mfg date. If it's within 3 years then contact Acer corp. If your monitor is out of warranty then you can open it up to do the repairs. The usual problem with them is the capacitors on the power supply board overheat and bulge causing them to prematurely fail. You can replace the capacitors and the monitor will be just like new but with better parts in the power supply. That model normally uses the Darfon B092-*** 27-D021635 power supply board which is the same board that's in the Viewsonic VX1962 monitor. Here is a link to a repair guide that will show you what goes out and how to replace the parts to get it back running again.
http://www.ccl-la.com/blog/index.php/viewsonic-vx1962wm-monitor-repair/
I hope this helps, if so please rate our solution.
BuddyMc
Sep 23, 2011 | Acer X193W LCD Monitor
Acer AL1917W blinks off in a split-second, twice
remove power to your monitor; then remove the monitor's back cover and, front cover;
when you can see the circuit board check for a buldged can capacitor or, two; replace these by unslodering them and, resoldering the new ones in place digikey.com sells the capacitors (don't forget the position of the capicitors they go in only one way
Jul 22, 2010 | Acer AL1917W LCD Monitor
Al2416w acer monitor comes on says acer then goes black
dose the standby button go orange, if it dose then the screen is going back in to standy, its possible that your graphics card is having problems, maybe if you put some more informationt about what happens then you could get better help.
Mar 17, 2009 | Acer Al2416WD LCD Monitor
Acer x223w issues- freezes
I think it could be an issue with resolution. Since the monitor is so big, some video cards, I noticed, can't support the high resolutions that the monitor can, if that doesn't work try 16-bit instead of 32-bit.
Feb 25, 2009 | Acer 22" X223w LCD Monitor
Can u help me? - Fujitsu-Siemens 900P LCD monitor burned out
Hi..there,
It's seems you got busted capacitors. Replaced all 5 capacitors in right handside with( 5*c8) in the 3-jpg photo power/inverter board.
Feb 03, 2009 | Computers & Internet
My acer computer will turn on but wont come out of hibination mode
Some laptops have issues with Windows XPs hibernation mode. To get the computer back up again you should just hold the power button down until it shuts off completely. Some laptops won’t shut off even if you do this. When this happens you have to take the battery out to get it to turn off. Make sure it is not plugged into the wall when you do this otherwise it wont work.
Once you get the computer back running again you may want to disable hibernation if it seems like its going to keep happening. Go to Start, Settings Control Panel or Start, Control Panel and go to the Power Options icon. Change the hibernation section to never. You may want to try standby as an alternative. Standby saves all your running applications and documents into RAM while hibernate saves them to the hard drive. Hibernate uses less power from your battery, but it will take you considerably longer to get the computer back up. If you always plug the computer in then you may want to disable standby and hibernate since you really dint need them while plugged in.
Let me know if this works.
Aug 16, 2008 | Acer Computers & Internet
Wavy screen
Try using a different refresh rate. I've found that when you change it down to 60 hertz that the issue usually goes away.
Jan 07, 2008 | Acer AL1715 (Black, Silver) 17" LCD...
Computers & Internet Logo
110 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
