It most likely is due to the rollers that will feed the envelope. Try changing the rollers. We had that problem ALL the time at my office and we noticed that it was due to the rollers not have any threads or being worn down.
Quick fix.... take out the rollers... put some soapy water on them.... let it dry and it should grab the envelopes. But this is again a temporary solution.
Was this helpful?
Yes
No
Popular Solutions for Canon PIXMA MX310 All-In-One
I recently tried to print a document on my canon mx310 printer and it says that i have no paper in...
(More)
I recently tried to print a document on my canon mx310 printer and it says that i have no paper in there, but there is. I used it a few days ago and nothing was wrong with it.
i have canon mx310 three in on printer fax copier. when printing anything off computer my print size...
(More)
i have canon mx310 three in on printer fax copier. when printing anything off computer my print size is way to small how do i make print larger
when i on the printer, it shows check printer on the printer's screen. Can't do anything now. Wat is...
(More)
when i on the printer, it shows check printer on the printer's screen. Can't do anything now. Wat is the problem and what is the solution?
my printer canon MX310 doesn't want to print, the paper goes down a little but then it stops...
(More)
my printer canon MX310 doesn't want to print, the paper goes down a little but then it stops completely. then it says remove jammed paper ; i keep lookin gbut i cannot find any jammed paper. WHat can i do???? Please help me because i need to print my essay asap!!!! thank you
I have a Canon Pixma MX310 that had a Paper Jam problem. It would show paper jam even though there...
(More)
I have a Canon Pixma MX310 that had a Paper Jam problem. It would show paper jam even though there was no jam. I found a spring loaded switch, which was suggested on this site, and just toggled it. This cleared the jam error. But now it jams on every piece of paper it tries to print. What do I do?
