Question about Eagle EKB-2020 Key-2020 Key Box w/ Mortise Cylinder
I would like to install a used mortise lock in an old door which has the cut out for a smaller mortise lock. I am hoping to use a power tool and not a chizel because the door is a 100 year old hard wood species and am affraid it might crack. Is there a drill bit which can act as a router bit for a mortise lock cut out? Thank you!
    Problem Solver:
  • 18 Answers
Can't think of a bit which will do what you want but you could stitch drill it to the desired size then chisel the holes square this should reduce any chance of cracking
Posted on Jul 09, 2009
Change a non mortise storm door to mortise
You are presumably referring to the type of latch or lock?
If it isn't already fitted with a mortice lock and the fitter chose to use a rim lock or night latch there are a few possible reasons.
It is possible the fitter chose these because they are easier and much quicker to fit and don't require the precision a mortice lock needs.
It is possible he had these things in his van.
It is possible the guy who gave the instructions wouldn't pay the extra.
It is also possible the storm door isn't physically thick enough for it to be worthwhile fitting a mortice lock, maybe this also applies to the frame. The main reason for fitting a mortice lock is greater security and so the frame should be substantial and the door at least an inch and threequarters thick and of solid construction. Interlocking steel hinges or hinge bolts should also be fitted.
Filling the hole left by a nightlatch is quite difficult so they are better left in place but the smaller hole left after a rim lock has been removed is fairly straightforward to make good.
Mar 19, 2018 | Building Materials
I am looking to buy a mortise "sager" lock for an antique door. The only number that I can find on it is 670?? Any clues or suggestions? Thanks!
Try using Google images to search for "Sager Lock" and see if any of the pictures look close to what you want.
Also, try all the antique shops in your area, and I mean ALL of them. If the people who built your house built other houses in your area at the same time, there may be other homeowners who have "modernized" and sold their old door hardware to local antique dealers. Old locks are not popular sales items because new ones are more secure, so not many antique shops will have them, but there is often 1 or 2 who will make the effort.
Be prepared and wear leather work gloves to protect your hands when searching through boxes of old locks. If you don't have a sample lock, then get some scrap lumber and cut a copy of the mounting hole in it so you can take that and not the whole door with you.
If you do have a lock that does not work, and you want a DIY solution, you might be able to work with a locksmith or a hobbiest to repair it. Sometimes it's just a broken spring that prevents a lock from working, but sometimes it's a missing part. That is not as much of a problem as it used to be. Nowadays a 3D printer can make trial prototype parts, that you can tweak until you get it right, and then take the working plastic part to a local metal foundry to cast into brass or cast iron.
Oct 06, 2013 | Ilco Key blank, Sager NP
Our back door (double glazed with locks at top, middle and bottom) has become permanently locked from the inside. It would appear that the lock at the top has bolted shut. (We have safestyle doors and...
Hi, W/D here.
Easy fix. Your upper locking bar has slipped. While someone is holding the door handle in the open position, you'll need to push the upper lock bolt back far enough to get the door open. You can slide it back carefully with a screwdriver or knife, a little at a time, while holding slight tension on the door with the handle. OK, door's open. Remove the inner door lock cover plate. The lever and locking knob will come off with it. Remove the mortise cover plate, on the edge of the door. Insert a small, thin bladed into the upper alignment slot in the lock behind the mortise cover plate, and loosen the upper allen screw behind the inside lock cover plate. Use the screwdriver to engage a slot in the locking bar, and raise or lower the bar until you have it level with the alignment slot. Tighten the allen screw.
Sometimes, the bar is so far out of alignment that you will have to gain access to the other end of the bar, in order to raise or lower it. This is done by removing the plastic cover on top of the door, and using needle nosed pliers to move the bar.
This should fix you up.
Best regards, --W/D--
Jan 28, 2011 | Locks & Locksmithing
Lost instructions for plastic hinge jig
This is a home owner's jig for mortising **** hinges, It will not do production runs , that's for sure. It has to be layed out to start, but great for cutting one door. Do you have the router guide for it? Your hinge sticks out of the door on the side that it swings on, and it leaves about 1/4 inch of door on the other edge, the top and bottom are measured from the top and bottom of the door and you have to figure the thickness of the guide and make a test run on a scrap. The depth should be flush with the hinge. The standard way of measuring is, 7 from the top, 11 from the bottom and center in between the 2, they don't do that anymore, they just slap them in a pre-hung jig that mortises upside down, backwards, up, down, doesn't matter. all the same now days, only problem is you can't get a punch under the hinge to pop out the hinge pin if you have to. The card you have might have the dimensions on it for holding off the line. Hope this helps.
Oct 17, 2010 | Porter Cable 59370 Door Hinge Template
Remote will lock and unlock all doors except drivers door.
then you have a defective driver door lock actuator motor, to change this u must remove the door panel, drill out the rivet and remove the old motor and pop rivet the new one in place, this requires a special jumbo size river gun and a rivet head cutting tool.
Mar 30, 2010 | 2000 Lexus RX 300
Fuse box diagram for 1990 olds 98 i want to cut
Review this Wiring Schematic about Olds 98 ('89, '90 & '91):
1989 1
1989 2
1990 1
1990 2
1991 1
1991 2
I really hope help you with this (remember rated this help). Good luck.
Oct 21, 2009 | 1991 Oldsmobile Ninety Eight Regency
Installing a deadbolt in a steel door. need to find the best/easiest way to get the plates recessed. using a cold chisel is a huge pain. hopefully thats not the only way. unless i'm doing it wrong.
A really, really, REALLY sharp chisel can be used to pierce the steel door skin enough to form the mortise you need for the bolt plate. Do not use a wood chisel unless you never ever intend to use it on wood again or have the means to completely renew the cutting edge. Cutting the opening for a plate in a metal door jamb is another issue since it is probably too thick to yield to a chisel. If the jamb is 1/8 to 1/4 inch thick you can just drill a hole in it to accept the extended bolt. it will be just as strong as a plate (maybe stronger.)
Jul 29, 2009 | Kwikset Brz Sgl Cyl Deadbolt
MORTISER VERY HARD TO PULL DOWN WHEN IT COMES IN CONTACT WITH THE
I believe it is an adjustment you need to make. It is covered in the manual as you go through the setup.
May 06, 2009 | Delta Machinery 1/2 Hp Hollow - Chisel...
Purchased Delta Mortising tool for delta drill press
go to youtube, get to expert village type in how to run a mortising tool, watch the vidio , you can learn a lot about power tools there.
Apr 11, 2009 | Delta Mortising Attachment
Baldwin 6321 mortise:when locked can open from either side
It sounds as if the lock is installed backwards or more specifically in inside mechanism. The inside lever/handle when turned should retract the deadbolt (safety feature). If yours does not currently switch around.
Feb 02, 2009 | Hardware & Accessories
Eagle EKB-2020 Key-2020 Key Box w/ Mortise Cylinder Logo
Top Eagle Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Eagle Electrical Supply Expert? Answer questions, earn points and help others
