Question about Microtek CX6 Multimedia Projector
Problem1. CX6 - white line runs across on the left side of the screen when movie is showing. Can't figure out what the issue is. Problem 2. - Biggest problem: Project will not show any picture when I connect any high definition player. Last week, I decided to buy PS3 so I can use the blue ray disk that comes with it. Connected the unit to it, project recognize the video source and then went blank. No picture will show on the screen, although it says that its connected to a DVI source. I really need to get help on this, otherwise I will have to return the PS3. Mind you, I also bought an HDMI upconverter DVD player. Same problem. No picture is NOT showing on the screen, although it recognize the HDMI to DVI source.
  • 3 more comments
  • Mr. Bons Jun 30, 2009
    already tried this solution before your suggestion. Did not work. How about Problem 2. I can live with problem 1, but I need to help solving problem 2.
    Thanks.
    bons
  • Mr. Bons Jul 01, 2009
    Does not work. tried both. Nothing works. I can live with Problem 1. But I really need help with
    A/V receiver with HDMI when connected to the projector reports - "HDCP error". Call manufacturer they told me its because my DVI input does not support HDCP. I am wondering if this is the problem why the PS3 does not work too, although it does not show any error message.
    Any thoughts will be appreciated.
  • Mr. Bons Jul 02, 2009
    Your suggestion.
    "If you want to use DVI LCD monitor or TV to play PS3, you may try a
    kind of gameswitch box, it is used for this kind of situation and also
    build in the function of switch to another DVI interface computer. You
    may see www.green-box.com.tw for more intro. Hope this will help."
    Checked this website. Their gameswitch does no have HDMI to DVI. It has 4 HDMI to 1 HDMI or 4 DVI to 1 DVI. But no cross over between the two.
    Thanks.
    Does not work. Thanks. Problems still there.
    Thanks. so basically I have to toss the DVI projector? Hmnn!
    Thanks..
  • 749 Answers
There is a problem with the projector you will need to get it repaired.
Posted on Jul 02, 2009
    Sergeant:
    Novelist:
  • 198 Answers
I've seen a forum that tackles the same issue. You may want to look at this post:
http://forum.ecoustics.com/bbs/messages/5/128361.html
If you want to use DVI LCD monitor or TV to play PS3, you may try a kind of gameswitch box, it is used for this kind of situation and also build in the function of switch to another DVI interface computer. You may see www.green-box.com.tw for more intro. Hope this will help.
Posted on Jun 30, 2009
  • Niqui Itliong
    Niqui Itliong Jul 02, 2009
    This presents a good explanation: http://www.practical-home-theater-guide....
    Similarly, you cannot
    use an HDCP/HDMI enabled A/V receiver to switch an HDCP source to a
    non-compliant display via HDMI (or DVI). The only possibility to connect an
    HDCP/HDMI source to a non-HDCP one is simply by stripping away the HDCP
    encryption and then sends a bit-perfect copy of the original signal to your
    display device - either through a component video connection, or through a
    non-HDCP DVI or HDMI port. In this manner, you will be re-creating an exact
    restriction-free replica of the original high definition content. This is
    exactly what HDCP strippers do!
    How do HDCP Strippers
    work?
    An HDCP stripper box is placed between your playback device (e.g.
    HD-DVD or Blu-ray player, etc) and your non-HDCP compliant display. It then behaves in a
    similar manner to a secure device. In order to achieve this, HDCP strippers
    use the same HDCP chips built into high definition displays. The
    HDCP source will see a compliant device, so after the authentication
    process, it will simply proceed to deliver its signal to the HDCP stripper,
    which will then create the non-restricted copy to forward to the sink device.
    This means that an HDCP
    stripper can effectively enable HDCP sources like HDTV, HD DVD or Blu-ray
    Discs, to work at full high definition resolution with equipment using
    either analog or 'unprotected' DVI and HDMI
    inputs.
    Are HDCP Strippers
    legal?
    Strictly speaking, HDCP Strippers are in reality encryption
    countermeasure devices. Whether all that the user is doing is just removing
    the digital rights management from the original signal in order to be able
    to view it on his or her non-HDCP compliant HDTV is another story, yet we
    cannot see how these devices can pass the Digital Millennium Copyright Act
    (DMCA).
    Are
    HDCP strippers freely available on the market?
    Probably, the first
    company that came out with such a device was the German company Spatz-Tech,
    with its DVIMAGIC HDCP stripper. This HDCP stripper was selling online at just under $500 US. It
    first appeared some time in mid-2005 and was sold and marketed as a DVI
    amplifier, yet its main attraction was its application as an HDCP
    stripper.
    The DVIMAGIC HDCP Stripper
    did not come cheap, but then legal issues apart, $500 is just a small price
    to pay for a working display!
    It seems that the DVIMAGIC
    is no longer available (all product links seems to have been removed from the
    company's website). However, whatever is the case, we are sure that as long
    as there is a demand for these boxes, other electronics manufactures will
    come up with similar solutions as well.
    President:
  • 1,383 Answers
There is dispaly resolution problem.
Set proper diplay resolution.
Also resert all settings to defaults.
Posted on Jun 29, 2009
Westinghouse tv screen issues
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Nov 05, 2016 | Westinghouse Televison & Video
Diagonal lines at 45 degree angle from left top to right bottom of screen
db:: 4.31::Diagonal lines on tm2 screen? fz - Hivmr
www.hivmr.com/db/fzap9jk8dp87mcjk3cc9jsp7fzxk7pz1
There are faint 45 degree diagonal lines covering my brand new tm2 LCD ... with some static looking diagonal lines going from bottom left to top right. .... DB:3.01:Dv6113 Us - Computer Freezes Showing Diagonal Lines On Screen aj ... Also there arediagonal lines that run across the screen at about a 30 degree angle.
3M Privacy Filter for Laptop diagonal-14.1" viewing screen ...
www.amazon.com/3M...diagonal-14.../B00006B8A9
Amazon.com, Inc.
Rating: 3.8 - ‎1,617 reviews
Amazon.com: 3M Privacy Filter for Laptop diagonal-14.1" viewing screen ... Premium 14.0 Inch Privacy Screen for Widescreen Laptop or Computer Monitor .... 3M™ Privacy Filters create a 30-degree cone of vision so on-screen data is .... You'll also notice a large "3M PF14.1W" printed in the top right hand corner of the filter.
FZ190: Faint Diagonal lines on screen? ' NotebookReview
forum.notebookreview.com > ... > VAIO / Sony
Jan 27, 2016 | Computers & Internet
Wavy horizontal lines across the screen
It sounds that the main power supply section to your TV has the fault. The horizontal thik lines that appears crawling down across the screen should be of video 'HUM'. Have you replaced the main filter capacitor at the power supply section? If not, replace it along with the main rectifier. The AC power is rectifed by a bridge and applied ot this main filter capcitor. It will have a capacitance value between 120 to 350MFD 450VDC. Check this section. Measure the rectifed DC voltage acorss this main filter capacitor. It should be around 350VDC, if your home power supply line is 220VAC. If it is 110AC, this DC voltage will be around 165VDC; and it should be. If rectified DC voltage found lower than the input AC voltage, replace the rectifier bridge. In some sets, this bridge section have four diodes. Some other circuits, a bridge rectifier stalk may be used.
May 20, 2012 | JVC AV-27050 TV
The screen has a box that says : 1:Analog input Self Test Feature Check Red (line across) Green (line across) Blue (line across) White (line across) if you push the menu botton you get a other screen...
The issue is that the monitor in not getting the signal. This tells me that the video adapter ( or on board video) has went bad. Try another video card if all your doing is social media and surfing you can pick one up for around 20.00
Oct 27, 2017 | Dell Computers & Internet
KP57WV700 - Blue Lines Across The Screen
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 26, 2009 | Sony KP-57WV700 57" Rear Projection HDTV
Line across screen
scane for virus and reinstall the operating system
May 30, 2009 | Computers & Internet
Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Green line
sharp is very aware of the panel and main video processor problems.They should give you no problems on the repair.It sounds most likely you have a main video processor problem.
Mar 13, 2008 | Televison & Video
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
White lines across the screen
Sometimes if the resolution is set too high, white lines will appear.
Dec 12, 2006 | Toshiba TDP-T9U Multimedia Projector
122 people viewed this question
Top Microtek Office Equipment & Supplies Experts
Alun Cox
Tony
Are you a Microtek Office Equipment and Supply Expert? Answer questions, earn points and help others
