Question about Pioneer 2 Handle Satin Nickel 6" Rain Head Shower Faucet+Valve....
Relacing hot and cold water faucets and spout on a 50's sink
The faucet and stem are located pn a vertical wall in the sink
  • 297 Answers
Discribe your faucet and stem on vertical wall problem?
Posted on Jul 31, 2009
How do I fix leaky faucet?
Sounds like your water supply lines under sink where they connect to faucet unit are loose oo they didn't apply plumbers putty under the faucet unit it self
Nov 21, 2014 | Plumbing
Had new water heater installed. Ever since, there is very little water flow from both hot and cold faucets of both (dual) sinks in 2nd floor bathroom. Faucets are Moen 9000 M-PACT type. Could air be t
check the aerators on the faucets. i know after i change a hot water tank there is always some crud that comes through the lines and gets stuck in the aerators, they are the part that holds the screens in place on the spouts.
Aug 14, 2012 | Moen Plumbing
Faucet leaking at tee where hot and cold connect to spout
The designs of the Kitchen Sink Faucet mainly exhibit differences in its handles and spouts. Differently curved spouts and handles diversify the range of products. Some have long spouts and some are with short ones. The spouting of water may also give different flow patterns with the external fixtures. The handles are mainly in single or double.
source Best Kitchen Faucets
Feb 03, 2012 | Kohler Fort© Widespread Lavatory Faucet...
945 Kitchen Bridge Faucet - Swivel Spout, 9-1/2" (no Han) Brand: Newport Brass NB945-26 Series: 900 The stem moves up and down slightly when I turn on/off the water pressure. It does not leak but...
There is a good chance that if you remove the handle there will be a retainer of some sort. The retainer's job is to keep the stem/cartridge from pushing out due to water pressure. It may be in the form of a nut or a clip. Be careful removing the handle because if the retainer is completely disengaged then the stem/cartridge may shoot up. Turn the hot and cold water off at the valves located under the sink and relieve the pressure by turning the faucet on. If it's a loose nut it will spin freely. Tighten it. If it is a clip you may need to play with the stem/cartridge to align it properly before the clip will move into place..
Jul 15, 2011 | Newport Brass Plumbing
My kitchen sink will not let me turn the hot water off, it just keeps running. The cold water shuts off fine just not the hot side.. I turned the knob under the sink and the hot water turned off but now i...
Hi hi--
You'll need to rebuild or replace your hot water control stop--that's the valve on the faucet body. If it's a single handle control, you'll need to replace the control cartridge. If the faucet has two knobs, you'll need to locate whatever stem pieces are needed within the hot valve. Sometimes, on two knob faucets, you can get away with simply replacing the rubber pieces inside the control stem. If that is the case, your local hardware store should have manufacturer-specific rebuilding kits available. Be sure to locate the faucet's model name first! That should be written somewhere on the above-sink portion of the faucet body itself, and you should be able to see it without taking anything apart.
--Hope this helps.
Sep 27, 2010 | Plumbing
The swing mixer handle has become very stiff. how do i get it off to clean it/
The first solution is of course correct. However I found it almost impossible to remove the spout assembly. It was very stiff and it was difficult to get any leverage to force it off without damaging the finish to the tap as a whole or damaging the sink.
What I found was that if you poured boiling water over the tap/faucet it eased the stiffness and having done this several times - ie about 5 kettle loads of hot water, I managed to remove the spout. It helps if you reconnect the hose directly to the outlet under the sink (ie not via the faucet). THis allows you to run cold water through the tap whilst pourung boiling water over the outside of the tap. The cold water shrinks the copper/brass components whilst the hot water expands the spout assembly.
Once off, it is possible to clean the inside of the assembly to remove corrosion or calcium deposits to say nothing of old "O" rings.
I also used a kettle descaler between dousing with boiling water in the hope that some of it would seep down within the assembly.
It took me three attempts to do this. I was almost going to spend UK pounds 430 or US dollars 670 and buy a new unit. So do not give up and I hope this helps.
It swings backward and forward now perfectly.
Aug 27, 2010 | Blanco Classic Single Handle Faucet with...
Kitchen Faucet Replacement
Option 1 ; Cap off the sprayer.  Option 2 ; Relocate the air gap as high as possible under the sink but then you have no drain under it in case it backflows (it is really a vacuum breaker ,  one way check valve) Option 3: Take back the faucet and get one of those that the spout is also the sprayer.
Jan 30, 2009 | Danze D316440RBT Fairmont Two Handle Wall...
Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
  1. Turn off water to faucet.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
Dec 04, 2008 | Price Pfister Marielle Kitchen Faucet with...
Kitchen faucet Remove
All faucets have a hot and cold line input. The single handle units have a mixing valve within the handle. Aside from removing the water lines there is usually some type of connecting bolts for the base plate as well that will need to be removed prior to removing the faucet. Do not forget to turn the shut off valves off at the wall before you remove the water lines.
Good Luck
Dec 03, 2008 | Plumbing
Water kitchen sink
I would check the strainers on the intake and the faucet spout. It is possible that sediment has built up and now is impacting thermostatic flow from the faucet... if one side is clogged its hard for the faucet to balance... try the stainer on the spout and any other strainers that may be on the supply hoses, valves, intake, etc...
Nov 23, 2008 | Moen 3175 Legend One Handle Shower Faucet...
Pioneer 2 Handle Satin Nickel 6" Rain Head Shower Faucet+Valve.... Logo
116 people viewed this question
Top Pioneer Plumbing Experts
Tom Chichester
Gil Shultz
Are you a Pioneer Plumbing Expert? Answer questions, earn points and help others
