Question about Craftsman 26 Hp 54" Deck Yard Tractor
Steering the steering whell keeps slipping when I turn it on my dgs6500 riding mower
  • 138 Answers
There is usually a shear pin near the base of wheel, punch out and replace it.
Posted on Jun 29, 2009
Why does steering slip turning left?
broken teeth on the steering gear (attached to the steering rod) or the steering plate (the one that turns the wheels) follow the steering rod from the steering wheel down to the frame, if it goes THRU the frame look underneath the lawnmower and youll see which one is messed up, just replace the one that has the broken/worn down teeth, hope this helps
Jun 02, 2015 | John Deere Garden
Steering gear slips
You have the steering shaft the pinion gear on the end of the shaft and the stationary gear at the bottom on the frame. Either the gears are worn out or the steering shaft has too much play in it causing the gears to slip.
Aug 04, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
What would cause right steering handle to not function properly?
belt slipping/broken, oil level low in hydraulic pump (ck seals) , dirt in steering valve body ?
May 18, 2014 | Toro TimeCutter MX5060 50" 23HP Lawn Mower...
Steering is loose and slips on my John Deere LA140 is it hard to fix
The steering gears are striping out. There are two gears that mesh to steer unit.
May 06, 2014 | Garden
I have a 42" craftsman tractor... when you turn all the way to left the wheels get stuck... can I adjust anything?
What happens when you turn right? Does it turn as sharp as it used to? Almost sounds like the steering gear teeth have slipped and now it is steering to far to the left. You'll have to check the steering sector gears at the bottom of the steering column.
Oct 24, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
John deere 68 riding mower steering column won't turn wheel assembly via arced toothed plate. Wheel assembly OK and greased. Some minor play when rotating steering column with steering wheel, but appears...
Just had same problem with my craftsmen. There is a very inadequate little nylon bushing supposed to keep that shaft stable. When worn out it allows that shaft to move and puts the gears in a bind. It is located on the end closest to arced gear where shaft hooks to drag link. Its a pain.
Sep 27, 2010 | John Deere Garden
Friend's yard craft riding mower does not steer when steering wheel turns. What needs to be replaced or fixed?
Usually there is a gear on the bottom of the steering column. A roll pin or a cotter pin keeps it from spinning on the shaft. Check that linkage.
Dec 04, 2009 | Garden
John Deere riding mower SRX95 - Steering wheel is sticking
You need to replace your Ball Joints! On the front steering rods There are two sometimes three !
May 08, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Craftsman 26 Hp 54" Deck Yard Tractor Logo
87 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
