All burners will flux between clean blue flames to half yellow tips from day to day.
SOURCE: Ge Monogram Gas Cooktop - won't boil water - burners seem like they are starved for gas
Bret, lets give this a try. 1st look at the regulator. There is an arrow on it that has to point towards the cooktop. Put is on backwards and very little gas flow. I always advise this first as I have seen people tell me it is correct and when I got out there it was reversed. 2nd was this used as a live demo unit on Propane? If you are on natural gas, this will also happen. The 3rd thing I also check for in something in the gas line on the cooktop side. I had a unit that got some packing in the line and at 5 wc for natural gas, it doesn't take much to restrict. Hope this helps.
SOURCE: one burner requires a match to light
had same problem. Used fine sandpaper on the little head (just above the white ceramic) that creates the spark. over the years the edges of the littel metal ring had gummed up but a 1 min sanding got it down to shinny metal and it sparked nicely.
SOURCE: Burner flame on GE 5 BURNER cooktop (JGP637) is orange
You have trash, corrosion or a mis-aligned part.
Check and repair these and you will be fine.
SOURCE: The flame is too high on my GE Profile gas cooktop
I had the same issue on my jgp975 and sadly I had to purchase a different unit. I use simmer frequently and I made the assumption that low was simmer. Wrong. I believe a true simmer is 450 btu and my unit did not go that low. I had to check the fine print/specs page and on some units the manufacturer had to be called. I did replace with another ge profile that did have the low setting.
SOURCE: GE Monogram gas cooktop electric ignitor will not
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
