Question about Canon NP 6551 Black and White Copier
Canon NP 6551 When putting paper in the
Canon NP 6551 When putting paper in the carrier/feeder and push start it says place the originals again?
  • cupocoffee Sep 11, 2010
    what is error code E504??
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 118 Answers
A sensor in the adfeeder could be contaminated by dust if you have the blower try to blow the whole feeder unit check also if there a two tongue like black plastic that is coming out on top of the originals when pressing the start button.if this thing will not come out the machine will tell you to put the originl again
Posted on Jul 05, 2009
Read out says remove the jammed paper from the duplexing unit. where is the duplexing unit?
the duplexing unit is under the fixing feeder frame unit..... have only worked on one NP before and it was much like the IR5000 all you need to do is pull out the tray under the fixing frame assemble
May 18, 2010 | Canon NP 6551 Black and White Copier
Enter copies into the feeder (Canon 210S). It
This is one of the worest designed feeder from Canon. Have you had the feeder rebuilt recently? If not that will improve it greatly. I would also, go into the user settings and turn the fax exit to recurite late doc. As I said, it is a bear to take this feeder apart if you have not done it before... Good Luck
Mar 05, 2010 | Canon imageRUNNER 210S Copier
Cannon NP 6551 (Danka A50) Touch Screen Lost Brightness
SOMEONE TURNED THE CONTRAST BUTTON ON YOUR DISPLAY, YOU JUST NEED TO READJUST BY PRESSING AND TURNING TO DESIRED CONTRAST
Apr 03, 2009 | Canon NP 6551 Black and White Copier
Canon NP 6050 Paper Feeder won't feed
Seems the wheels on the left side of the feeder maybe slipped or something, I turned them 1/2 way over so the gray rubber part shows, then they were able to grip the paper and feed it into the copier. That worked for a little while, then it did it again, I turned them again and it worked. Maybe I just need to make sure they have a little traction to solve the problem. Thanks for your website.
Apr 01, 2009 | Canon NP 6050 Copier
Error message - re insert unit 1
GO ON LINE AND TYPE THE FOLLOWING:
CANON NP 6551 B/W RE INSERT UNIT 1
ENTER
WHAT IS CANON NP6551 B/W UNIT 1
ENTER
CANON NP 6551 B/W SERVICE MANUAL
ENTER
ROD
Feb 17, 2009 | Canon NP 6551 Black and White Copier
Canon Np 6551 e502
that error is a communication error between the copier and the sorter unplug the sorter then turn the copier on should go away. probably loose connector or bad sorter board
Dec 19, 2008 | Canon NP 6551 Black and White Copier
NP 6025 printing Crooked
yes ther is ! first clean the glass with Mr Sheen(which is a spray on furniture polish) the glass needs to be slippery so the paper slides nice and easy over it.Then if that doesnt help,where the feeder attaches to the machine are 2 hinges one of which you should be able to adjust. Hope this helps.
Aug 19, 2007 | Canon NP 6551 Black and White Copier
Canon NP7161copier ( Indicates 8z and stops copying)
Dark shades on both side of the paper? Drum cleaning blade or fuser assembly. Check the upper fuser roller and the drum for build up.
Jul 16, 2007 | Canon NP 6551 Black and White Copier
Canon NP 6551 Black and White Copier Logo
150 people viewed this question
old marine
old marine
