Question about Tascam DP01FX All-In-One Recording Package Microphone
Tascam dp-01fx system 50 error
I can record but when i start to master the song
a message says system 50 error shut down power.
  • Anonymous Dec 04, 2007
    You need to reformat the FAT file area. I just did it and it fixed the problem.
  • Jace Bruton
    Jace Bruton Feb 01, 2014
    I have the tascam dp-01 fx/cd and am getting "media error: 0 please power off". Anyone know what that means?
What the above guest said is exactly what you need to do. Make sure of course there is nothing on your FAT(previously exported songs/masters) because they will be erased. just go to menu->disk->fat reform, then press enter
Posted on Dec 18, 2007
  • Slimstersqua Jan 13, 2011
    Dude, your help saved the album I'm recording. Laid down vocals and guitar solos for the last 3 songs, went to put them on the computer and got the error 50 message. I took your advice and am now listening to my music with a smile on my face. Thank you so much.
Hi I'm running XP pro SP 2 on a MS9121 motherboard and when I shut down my PC, alomst everytime, the system reboots and starts again. The only solution consists in turning off the back switch and I...
This issue may occur if the following conditions are true:
  • You have "automatically restart" selected.
  • The Roxio Easy CD Creator 5.0 or Direct CD 5.0 program is installed on your computer.
uninstall Roxio Easy CD Creator and install again without Direct CD.
Second Option:
Have you turned off APM? If not, right-click desktop, select screen saver tab, click "power" button under monitor power, select APM tab, uncheck "enable APM support." I did that and the system shuts down no problem.
Third option
  1. Right-click My Computer, and then click Properties.
  2. On the Advanced tab, click Settings under Startup and Recovery.
  3. Clear the Automatically restart check box under System failure, and then click OK. The error message should remain on the screen so that you can record the error information.
Jul 11, 2011 | MSI E7505 Master-LS2 (MS-9121) Motherboard
Tascam dp-01fx system 80 error It says " No CD
hey mate i got no solution for yah but if yah work it out e mail me man i got the same problem
da_monk_bomberman@hotmail.com
if i can get some info on it ill contact yah ok
Dec 08, 2010 | Tascam DP01FX All-In-One Recording Package...
Ikeep getting an error message when i go to mixdown/matering.it says that my tracks are too short,change outpoint. How do I change outpoint and to what do i change it to?Song is 4 mins. 23 secs long.
The 2488 requires a start point and end point in order to master down. The start point, by default is zero (the beginning of the song) so you will NOT have to create one, HOWEVER, you MUST provide an end point. The end point is wherever you wish the song to end, so, roll the BIG wheel to the end of the song, then, press LOCATE SET and OUT simultaneously. You have just now marked your out point and thus it will master the whole song. NOTE: If your song is 4:23, then the out point will be/should be a bit longer (a second or two- or even more- that's up to you) than that depending on where the song/music actually begins after the zero mark, therefore, make SURE you roll the BIG wheel enough to encompass the WHOLE SONG. The counter will reflect the time/length as a result of how far you roll the wheel. I hope this helps. One last note, do ALL this at the MIXDOWN prior to MASTERING.
Feb 22, 2010 | Tascam 2488 Portastudio Multitrack...
I have a Tascam DP-01fx/cd that after powering on it reads sreset error :12 please power off. How do I fix this so I can use the machine again?
Jan 02, 2010 | Tascam DP01 All-In-One Recording Package...
"unable to open audio recording device. Device may not support..
sorry its a software every time when you recieved a fetal error its came from software's corrupted dll file
Aug 30, 2009 | Edirol UA-4FX External Sound System
I finished one our ago my first recording i don't understand how to do to for pre mastering, because i want to do ace and evry time i read track too short, set out point... ?? give me how to do.a
Congratulations on your first recording! Mastering and pre-mastering is covered in much more detail in the manual (page 59 in the original 2488 manual) but I'll provide a brief explanation here for you.
First you need to enter pre-mastering mode. Do this by navigating through the menus to the 'audio CD' menu and then choose 'pre-master'. You'll see the word 'Mastering' appear in the LCD screen to indicate you are in mastering mode.
Basically you need to then set the 'out point'. The 'in point' is always 00:00:00.00. So just play your recorded song to the end (or where you want the master to end) and press 'shift' and 'set out' to set the out point there. A master has to be at least 4 seconds long which is whay you are getting that error message.
Next press record and play and the master will be recorded on two internal stereo mastering tracks (left and right). Master recording will automatically stop at the 'out point'. You can redo the master, undo a master, or copy the master tracks to any other two available tracks to preserve a copy and then go ahead and record another master. All effects, mixer settings, and fader movements are recorded as part of your master.
Best of luck.
Hope this helps.
Jun 15, 2009 | Tascam 2488 Portastudio Multitrack...
I want to know how to set up a master on my tascam dp02
first set the in and out points of song make sure your holding down the shift key while setting in and out points.then pres shift key holding down on it pres master key it should start flashing.then pres record play.good luck
Jun 11, 2009 | Tascam Music
Master Track too big to export.??
Im having exactly the same problem as you have/had..I cant Export the Master Track..It says "Too Big", have you been able to solve it?
Best Wishes
Steve
Mar 30, 2009 | Tascam DP01 All-In-One Recording Package...
1,186 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
