How do i remove the stand?
Just done it. it's a two person job in my opinion.
put it face down on a soft surface and remove ALL the screws form the back of the tv including the little ones near the components - 20-ish in all. some of them are hard to see/get at.
don't lose them.
prise back of tv off gently but with some force.
remove 3 /4 screws near the stand on the tv part facing the carpet and easily remove the stand.
then put the tv back together again. we ended up with one screw left!
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Disassemble procedure to many popular brand TVs are given with illustrations.
SOURCE: Panasonic Viera TH-42PV30 No picture & Stand-by light flashes 4 t
I would guess a power board failure. The blinking light is an error code.
SOURCE: How do I remove the stand from a panasonic tv. model TX - 32LXD70
The stand is held on by four screws. Lay the tv face down on a flat surface. Cover the surface with a blanket first. Use a regular phillips screw driver. (If you have a users manual see page 7)
The screws are the set just above the stand on the back of the set. The stand will then slide out.
SOURCE: Viera Link not work between two brand new Panasonic devices
You need to select setup from the TV menu then switch the Viera link on. I think retuning must have switched it off.
This worked for me
SOURCE: i have a plasma panasonic viera TH-42PV60A stand
Not power supply,it the backlight video board it dead.
Testimonial: "cool thanks alot"
SOURCE: viera link pop up problem...ANNOYING
You need to (either or both) change from Shop setting to Home, and turn off Viera Link demo.
Go into the menu, choose set up and re set to shipping settings.
