Incomplete bottom of the line. seems that it's missing ink
SOURCE: black ink from new cartridge is missing lines
Try doing nozzle cleaning, hope fully this flushes the air bubbles trapped in the cartridges. Or try using this template which sometimes flushes out the inks.
SOURCE: When I print/copy it is missing lines of ink and
Sometimes it requires several head cleaning passes to fix missing lines. Make sure the test pattern after cleaning has no gaps. Print the test page. If test page is bad and you have replaced all ink cartridges, then junk the printer or call Epson for a replacement. Even if out of warranty, the may give you a great deal.
SOURCE: I have an Epson NX400 printer but the yellow and
Try to print something that is pure yellow and pure black. Set it to BEST PHOTO. If you see gaps or missing lines, your print head could be clogged. You will need to use a cleaning solution to remove the clog.
SOURCE: even after all maintenance checks and repairs there are still nozzle problems
Sarah McHugh:
Just a suggestion: I would go to the Epson website and download an updated version of the printer driver for your machine... the problem may be with your software, not the printer!
