I have the 381 error "Open uper cover. 381 error: paper jam" permanently, but there are no one paper piece into the printer. The problem apeare after paper is stretched haft, the error accurd, and i dragged it in back. What can i do whit this problem? Thanks a lot for any help!
SOURCE: My oki printer b430dn is flashing 380 paper jam
Hi
You have to look under the cover remove the black plastic cover, Remove in the left side by sliding the litte plastic tab in to the mittele and gently pull up, when it is loose in the left side slide it on to the mittle and it will go of in the right side too, Now remove the next black plastic cover, it's all black with at little "sharkfin" i the center, Just pull genltly upwards, and under there is the "380" It is at little tab, just wrikele it a few times. Now just assemble the printer an you are good to go
SOURCE: I HAVE PROBLEM. THE PRINTER
Take out the InkJetPrint (The big black thing that gives the black inc) and reinsert, should clear up.
SOURCE: OKI mono printer mod B431d
The locking lever may have dislodged (was not properly locked down).
Check the locking lever and firmly lock it down.
