Question about Gigabyte GA-EP45-DS3L M-b- P45+ICH10, DDR2 1200, 1600 MHz FSB, PCI-E 2.0, SATAII, GbE LAN, 8 Ch... Motherboard
Hi, hopefully you could help me, I am having second SATA hard drive go south with this mother board(GA-EP45-DS3L). The first one was 160GB Western Digital, the Second one was Seagate 500GB ? I am having the F10 BIOS. What could cause that, I am getting tired of buying new drives...
    Champion:
  • 205 Answers
Is the hard drive heat sinked or mounted with screws. It sounds like the harddrive is over heating.
Posted on Jun 29, 2009
I have a GA-81PE775-G motherboard, will a WD5002AALX (sata-3) be compatable with this
Hi, I have reviewed the Gigabyte Motherboard that you have mentioned. It has SATA (Serial Advanced Technology Attachment) supporting 150 MB per second. Which means that the Hard Drive of Western Digital (SATA 3) which you want to connect is compatible with the SATA port of your Motherboard.
However, the SATA 3 of your Hard Drive supports 3 Gb per second. Hence it will be working in 150 MB per second when you connect to your Motherboard.
Aug 09, 2011 | Gigabyte GA-8IPE775-G (818313002198)...
I have a GA-P35-ds3l mobo that hangs at boot for
Had a similar problem. Eventually my SATA drive failed. Had to rplace & re-install. Now boots fine. Suggest you try another boot drive to see if you have a similar problem.
Sep 10, 2009 | Gigabyte GA-P35-DS3L Motherboard
Mouse
HI
Try disabling and re enabling the mouse. Else reinstall the mouse driver. If it still fails you may need to reinstall your OS or get the ports checked.
Oct 17, 2008 | Gigabyte GA-EP45-DS3L M-b- P45+ICH10, DDR2...
Hard Drive
Hi Patrick,
ATA and SATA are basically the same. The SATA drives won't work with the machines that are designed for IDE, so you're stuck with IDE on the I-series. Check out pricewatch.com for buying hard drives. You'll be able to get them for half the price Bestbuy sells them for.
I'm not sure what's involved in getting the fingerprint device to work, if it's just a driver or a combination of driver and software. I've never worked with or had one before. I'll look into it. Have you read any of the forums at IBM's support site on this?
Aug 07, 2008 | Western Digital (WD1000VE) 100 GB Hard...
Hard Drives -ATA and SATA
Yes, they can coexist.
May 17, 2008 | Computers & Internet
Installing SATA WD 160 GB Hard Drive
You may not have a SATA system - Western Digital has the other type of hard disk drive available.
Apr 07, 2008 | Western Digital Caviar SE WD1600AAJS 160...
Acer hard drive
Hi, the problem is one hard drive ie the 1/3 one is a SATA hard drive, the other is IDE.
to set them both up you need to do this,
Connect the IDE Hard Drive using the IDE cable like before.
With the Acer Hard Drive you need a Sata cable cost about a £1 from any shop.
You connect the sata cable from the hard drive to the motherboard, but on the motherboard you are looking for a small red connection same size as the cable, SATA is on most motherboards for machines that are just over a year old.
Hope it helps.
Have a nice christmas
John
Dec 10, 2007 | Acer (91.AB033.041) 73 GB Hard Drive
My Mother Board Does Not Detect My Hard Disk
Hi, I will assume that you are referring to the "Mother Board Does not detect 160GB SATA Hard Disk" when installing Windows. You need to press F6 when asked if you want to install other driver and follow on screen instructions. Good luck and post back how things are or should you need further information.
Aug 22, 2007 | Intel Motherboard
Gigabyte GA-EP45-DS3L M-b- P45+ICH10, DDR2 1200, 1600 MHz FSB, PCI-E 2.0, SATAII, GbE LAN, 8 Ch... Motherboard Logo
88 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
