Question about Dell Computers & Internet
I bought a dell opti flex 260 from auction, started installing the operating disc, computer became un plugged and when I tried to continue installing the operating disc to finish, it says error loading operating disc and just stays there.
  • orlanthial Jun 29, 2009
    I'm not good fixing computers.. please hepl me understand what it means to (go into the bios and set the first boot device to the CD/DVD rom)
    I've tried that lots of times. Sometimes the error message comes on when I first turn on the computer or it will do that after I select for cd rom, press enter and then the erroe message will appear, any other suggestions? Thanks your assistance is greatly appreciated!
  • Dell Master
  • 4,806 Answers
You will have to start from scratch again because of the power outage, if you go into the bios and set the first boot device to the CD/DVD rom you should be able to reinstall the operating system no problem.
Regards
Posted on Jun 29, 2009
  • Lee Hodgson
    Lee Hodgson Jun 29, 2009
    When the Dell logo appears, press the key to load the Boot Menu. If the menu does not appear, restart the system and tap several times at the Dell logo screen.
    When the Boot Menu appears, highlight the CD/DVD
    drive (listed as "CDROM", "CD/DVD" or "CD/DVD/CD-RW") entry from the
    list and press .
    Then you can proceed to install the OS
I recently bought an acer m1800 intel celeron computer but it needs operating system - does each brand have its own driver??? eg i have vista for dell machine can i use those discs?
operating system which is on your Dell machine is vista but please check the disc which you have got is an factory restore disc that is the image whcih is burnt on the DVD and you can take your computer to the factory setting that disc would not work on this computer. but if you have got the VISTA disc with you then you will be able to install the OS on to this computer.
Dec 20, 2010 | Acer Computers & Internet
I have a Dell GX 260 optiplex desktop it was working fine all along - when i switched it on the other day, the power light stayed on amber, the monitor didn't come on, the desktop fan was on and it was at...
I have a Dell GX 260 optiplex desktop, when I connect the power to the computer, the computer turn on and off repeatedly, so the HD doesn't have the chance to spin up or the monitor to come on. Whyy, please help
Oct 12, 2010 | Computers & Internet
I have a dell gx 260. orked great for 1 month when
Hello there:
It looks like to me that your bios is not recognizing the harddrive or is not set up properly like user settings or default settings
I would first go into bios and make sure that the bios is set to the harddrive that is installed.
And also in the boot sequense look on this and see if the harddrive is listed there if it is make sure that it is the top one and not the bottom one than save and reboot the computer when it boots back up it should tell show your harddrive and cd rom if connected properly than if all is good now just continue with your xp[ installation or what ever you were doing ok
I hope that this is very helpful for you
best regards righard
Nov 16, 2009 | Computers & Internet
Dell Opti 270 I cannot start
That error definitely indicates that your system is overheating. Get a can of compressed air and dust out the interior. Check the fans to make sure that they are not bogged down with grime and dust. Make sure all internal fans are working properly.
If this continues to shutdown after cleaning and you are sure that all the fans are in working order you might try peeking at the heatsink/fan area (inside the case) and look at the cylinders that are marked by an X on top. Are any of these bloated or do they appear orange on top? If so, this is your problem.
I believe that the capacitors on this particular model were manufactured incorrectly and if this is the problem then you will need a new motherboard...
Jun 04, 2009 | Dell (4T274-DE) Motherboard
Adobe won't load properly
Try un-installing Adobe Flash Player through Add/Remove Programs in the Control Panel.
After it is completely removed, reboot your computer and then go to the Adobe site to re-install the latest version of Adobe Flash.
http://get.adobe.com/flashplayer/?promoid=BUIGP
Mar 16, 2009 | Dell OptiPlex 260 PC Desktop
My Dell won't boot up when I have my external LG disc drive on
is it that you are not able to boot up when the external drive is plugged in or not at all...
if it is the first case then it is mostly probably because the external disc drive at first when it starts functioning it takes close to 1A of current but the allowed current for maximum current allowed to be drawn as per usb protocol through usb port is 500mA... Linux doesn't care about this over current but windows very much does....
Nov 21, 2008 | Dell Red Hat Enterprise LINUX WS Version 3
Dell inspiron 1525 not enough memory?
hi jerry.... its not the problem with charger cord... and it should not be the problem with mother board too. its probably due to more programmes installed on C drive and computer is trying to load more programmes into memory while startup...
switch on the computer and keep tapping F8 key continuously on keyboard.. (stop tapping when you look at advanced boot options)..
select the option safe mode... and hit enter.. you will reach to desktop in safe mode... then
start -> run -> type msconfig and enter
select startup tab -> click disable all..
and apply. ok. then try restarting computer.... even if it exists.... go to safe mode again... and try un-installing un necessary softwares which you dont require.....
Oct 11, 2008 | Dell Inspiron E1505 Notebook
Belkin adapter became yunplugged and when tried to plug in it requested program disc because of new hardware. Lost program disc for wireless adapter. How can I get another one?
Your computer should haver the drivers installed if you had it installed before. If you need the drivers you can go to the Belkin site and look up the make and model number and they should have the drivers. Make sure you download the latest driver for your operating system.
Jun 03, 2008 | Belkin Computers & Internet
Deell opti-plex wont boot
try inserting your recovery disk. and make your cd rom your first boot device then press any key when you re-boot.
Jan 10, 2008 | Dell OptiPlex 260 PC Desktop
Computers & Internet Logo
52 people viewed this question
Alun Cox
