Question about Aiwa Audio Players & Recorders
MY TAPE PLAYER IS DRAGGING I HAVE CLEANED THE HEADS BUT IT DID NOT FIX MY PROBLEM
  • 1,056 Answers
Try cleaing the rolers too. Thats what pinch the tapes. If that don't work the rubber belt that drives it maybe worn. The whole mechanism in a tape player is removable as a whole. All you got to do is remove it and change the rubber belt. They are fasten by screws. It takes a little mechanical ability.
Posted on Jun 30, 2009
Video tape gets stuck when playing
Did you also clean the rollers and other spindles where the tape also runs? It is not only the heads that will get 'sticky' & grab the tape.
Good luck.
Dec 18, 2012 | Samsung VR5607 VHS VCR
Insert a VHS tape, hear sound, no picture? DVD working fine, both sound & picture. What am I doing wrong?
Likely a damaged video tape got in the unit and blocked the video heads--once blocked no picture but sound will be the case---the heads can be manually cleaned if you know how---The real issue will be to locate which tape was in the unit when this happened--clear the heads and put it back and right back to no image......
Cleaning tapes are only slightly effective--most shops (if you can find one who even works on this gear) will not charge much to clean the heads.
Nov 04, 2012 | Samsung DVD-V5500 DVD Player/VCR
I have a couple VHS-C tapes that drag
This may be caused by a faulty adapter. 1. try playing in the camera. 2. try a different tape. 3. try a different adapter.99% this is a problem with the adapter or the tape. It really sounds like the tape isn't turning freely, which can be caused by a brake sticking, or spindle in the tape or adapter.
Mar 16, 2012 | Televison & Video
Tape is locked inside and cannot eject it. We took to a local camera shop and they said it would cost $200-$250 to help us get it out. I don't need to fix it if that is the case. I just need a player that...
The reason your tape wont come out the camera is because you may have not cleaned the record heads of late, they get tacky, grab your delecate tapes and twined them round the capstan and heads, then yes your little tape is well and truly stuck, trapped like a rat in a cage.
I have managed to get tapes out within a few minutes with a small screw driver and small pin, so I cannot see why they told you that stupid amount of money.
May 25, 2010 | Sony Handycam DCR-TRV340 Digital Camcorder
2001 Tahoe cassette tape cleaning
I think you need to remove the unit and have it repaired, it is faulty.
Jun 07, 2017 | 2001 Chevrolet Tahoe
No picture when playing in VCR mode
have you cleaned the heads recently?is there sound?check the tape you played to see if the machine is chewing up the tape and blanking the picture...good luck
Aug 02, 2009 | Samsung DVD-V4600 DVD Player/VCR
I think the actual tape cassette is the problem not the player. olde tapes play very slowly, dragging, distorted sound. New tapes are fine. What can I do to re-vitalise the old draggy cassettes?
Actually the tape player itself is likely to be causing the problem. Cleaning the pinch roller and tape heads with a qtip and a small amount of rubbing alcohol should do the trick
Feb 26, 2009 | Audio Players & Recorders
No more audio
Have you tried this tape in another machine? Your audio and video heads could be getting clogged. A head cleaning tape may fix it or you may need to have them hand cleaned.
If the tape has been stored where it is potentially warm and humid the tape could have degraded.
Unfortunately even the best quality tapes will eventually degrade as the oxide is slowly removed with every pass of the heads.
If a head clean on your player doesn't work, the best way to attempt to retain those memories is to take it to a professional video duplication place and have it transferred to DVD
Jan 23, 2009 | TDK 10 Pack of P6-120 8MM Tape 8mm Tape
Sylvania srd3900 error 2
Found no info in manual but cleaned tape heads and able to watch tapes. I don't know if this completely fixed problem because tape watched was not best quality.
Nov 30, 2008 | Sylvania SRD3900 DVD Player/VCR
My cat peed on the tape, i put it in camera went nuts. took it out, cleaned the tape, cleaned the heads,  now only plays blue on another tape where i know there is picture.  what can i do to use the...
Use video head cleaning cassette to clean camera's video heads. I also suggest you not to use this dirty cassette any more because it will clogge again camera video heads.
May 30, 2008 | Sony Handycam DCR-TRV17E Mini DV Digital...
121 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
