Question about LG enV2 EnV-2 VX-9100 VX9100 Premium Pink Magenta Silicone Rubber Skin Case Cover
EnV2 shutting off when closed
My LG EnV2 shuts off everytime I close it, I have no knowledge of its actions when I put it into my pocket. So, when I get it out to check the time it would be at an off position. Normally I have it on loud so I can hear calls and text messages come in but I never hear it shut off. Its starting to be frustrating. I am only 15 years old and I paid 200.00 for a piece of ****! What should I do?
I have the same problem, only randomly, even with two key lock on. I read on here where someone said he discovered that pressing on the battery real hard (as if in your pocket) shuts the phone down. I tried and it did. I cleaned the terminals (don't scratch them--use Q-tip DAMPENED in 91% alcohol, or rub with soft cloth--don't get white paper circle with xxx wet!). Afterward, I could no longer shutdown phone by pressing battery. Solved? Time will tell. You can also go back to Verizon and they will swap it for a certified used one within the first year.
Posted on Sep 11, 2009
My ok , * ,0 , # keys won't work . is there anything for me to d besides taking it to the local store ?
Posted on Nov 22, 2009
What's your problem?where is switch located that shuts off NV52 when lid closes
go to control panel /appearence personisation /system security go downtoo power optionsedit plan settings (change when comp goes to sleep /change advanced power settingsbox will open power options work way down to power buttons and lid open that up + on battrey open lid close action you will see do nothing open that up and press shut down
that will shut down youre comp when lid closes
Jul 16, 2012 | Gateway NV5215u Notebook
Cold storage door will not stay shut
all of the refrigerator has a spring if there has no spring it will not open and close!
Apr 14, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
LG ENV2 shutting off
I just got mine a few weeks ago and it does the same exact thing (I didn't drop it, there is no water damage, I didn't understand the cause of it). I took it back to the Verizon store and I was told that the random shutting off like that is caused by having the phone outside being exposed to heat. He reset my phone back to factory settings and that did the trick for awhile (its hard for me to go to the pool and not have my phone exposed to the heat). There is no charge for them to reset the phone. Mine has started the random shutting off again back up
Jun 03, 2009 | LG enV VX9900 Cellular Phone
LG Env2 randomly turns off
I had the same problem, I took it back to the Verizon store and told it was caused by heat exposure from being outside. He reset my phone and the problem stopped (until I had it outside at the pool again)
May 31, 2009 | LG enV2 EnV-2 VX-9100 VX9100 Premium Pink...
Lg ax8600 shuts off when i close it
Check your settings to see if that is an option that when you close it it shuts down.
May 26, 2009 | LG AX8600 Cellular Phone
Hi all...
This was happening to me with my env2 but a friend helped me fix the problem, which is caused by bad contact between the battery and the phone.
Remove the battery from the back.
At the bottom of the recess in which the battery sits are the 4 gold contacts.
First, clean these contacts with a pencil eraser and be sure to clear any eraser leavings fromt he recess.
At the top end of the recess (opposite the gold contacts) you'll see the holes where the posts from the battery pack insert.
For this next part, you'll need a business card or some paper. I've found that a double-layer (single fold) of business card works, so probably a triple or quadruple-layer of paper will do as well. Cut the card such that it is just short enough to fit lengthwise between the post-holes, and wide enough that when folded lengthwise it will fit into the recess. Position the folded piece against the top "wall" of the recess between the post-holes and then insert your battery.
The card/paper pushes the battery downward just enough to make solid connection with the gold contacts. I did this about a month ago, and the phone has never sinced turned off on its own (it was doing it a few times a day prior to that).
KDS63
Apr 05, 2009 | LG enV2 EnV-2 VX-9100 VX9100 Premium Pink...
ENV2 Keyguard Lock problem
When your phone is closed, hit OK for the menu, then hit 6 for Keyguard Settings. There, you can not only change the time it takes for the keyguard to automatically go on, but ALSO change the keyguard unlock options from One Step Unlock (just hitting ok) to Two Step Unlock (hitting ok then clr). It's not a 4 digit code, but it's a lot better than just hitting ok, and much more time efficient than locking your phone every time you put it in your pocket.
Oct 21, 2008 | Verizon Communications enV2 Cellular Phone
Phone turns off when clamshell is closed
This phone sucks. Everytime I shut the cover, it would shut off (not so much anymore). NOW I have the blank white screen issue. So annoying :P
-Hana
Sep 17, 2008 | LG VX8300 Cellular Phone
LG Dare & LG ENV2 BOTH DEAD
i was talking on my phone yesterday and i just shut off. i plugged it in and it has a full battery but every time i turn it on it only gets to the "registering apps" it shuts off. what is wrong with my phone?
Sep 03, 2008 | Cell Phones
LG enV2 EnV-2 VX-9100 VX9100 Premium Pink Magenta Silicone Rubber Skin Case Cover Logo
478 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
