Question about Fellowes 3011001 Shredder
Paper sensor failure!
The paper sensor is obviously failing !
Is it possible to check this out and/or replace it ? If so with what and from where can it be obtained?
Don T
  • 3,594 Answers
Contact Fellows @ 800-955-3344.
DickyO
Posted on Jun 29, 2009
    Sergeant:
    Champion:
  • 387 Answers
Try this it may work. Take your hairdryer, Hi setting, Blow through the paper slot. Sometimes dust accumulates on the sensor eye. If you are out of warranty it may not be cost effective to repair.
What would cause your car to stop running while driving?
failure of the timing belt
failure of either cam/crank position sensor
immobilizer cut in
battery failure / broken battery lead
blown ING fuse
out of fuel
pump failure
overheated
Oct 11, 2015 | Ford Expedition Cars & Trucks
Check engine light on code p320
Trouble Code: P0320
Ignition Failure Sensor Circuit Malfunction
Possible Causes:
Ignition failure sensor circuit is open or shorted to ground.Ignition failure sensor is damaged or has failed.PCM has failed.
Jan 05, 2013 | Cars & Trucks
It cant load paper
Possible that the INDETECT paper sensor is not working. Sometimes this can be an opto sensor, If so you need to remove and check using a multimeter and replace the component.
It can also be due to a jammed roller, a failed motor drive or a faulty motherboard .
Oct 26, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
Television screen made loud pop and went dark.
If you feel adventurous, pull the AC plug and remove the lower panel in the rear. Using a good light, inspect the area around the circuit board(s) and look for traces of paper and possibly a cylindrical component that has obviously burst.
A part that is prone to explosive failure is the electrolytic capacitor. These are not costly parts but if it is a larger one, there is a chance that it failed as a victim of another component failure, possibly a semiconductor called a rectifier which can be in any number of different packages that a technician is much more likely to recognize than a layman.
Replacing a failed capacitor without doing further troubleshooting is not a good idea; it could just destroy the new capacitor.
Mar 11, 2011 | Toshiba 50HM66 52" Television
Showing Empty on paper, but paper in?
Hey,
Try push the paper to the end of the printer.
Love.
Feb 17, 2011 | HP DeskJet F380 All-In-One Printer
It says it's "out of
Possible that the in-detect switch/optocoupler detect is sensing a fault.
Check on the paper feed section for the in-detect sensor and make sure that it is reading into the paper. If there is no issue in this section the voltage change on the sensor must be checked with a multimeter as the paper is inserted.
if absent replace the sensor or otherwise the fault is in the main board which can be a digital switch failure to the processor..
Jan 03, 2011 | HP DeskJet 3520 InkJet Printer
C-0960 error
C0960 Bypass lifting motion failure. To fix this problem, check that there is a clear paper path. The take-up roller has possible not returned to the 'home' position. Turn off the copier, manually rotate the roller to check that it is free. Turn on the copier, once start-up is completed, check that the paper path sensors are clean. Close the by-pass tray and open again. If this fails to reset the code, refer to your service technician.
Aug 30, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Error code C0202
this is a tray 1 lift up failure code pull the paper tray out and check to see if some torn paper is blocking the lift sensor look around where the paper is fed into the feed plates if not it could be a failed lift motor or sensor and they will need to be replaced
Nov 29, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
I loaded a new roll of paper and can't get the plotter to print. I rebooted and now have 2 error lights, 1 for data, and 1 for cartridges. What to do?
Take out your paper (check if you are loading the roll from "underneath" and not from the front) . Switch off and on. If the machine gives you the same fault again, press cancel for about 2 seconds, it should then go to ready mode. If it does not then you have a carrage sensor failure. In any case the sensor is failing and its finding it difficult to find the paper. Its a bit technical but if the sensor fails you will need to replace your carrage (head) unit
Dave
Feb 23, 2009 | HP DesignJet 430 InkJet Printer
Copier Failure Konica
If there are no obvious paper pieces stuck, you could have either a problem with the dirty or worn rollers in the ADU, a dirty or defective sensor, or most likely a clutch problem in the ADU. Likely will require a service tech on site to repair to no obvious defects are seen.
Nov 05, 2007 | Ricoh FT5832 Copier
Fellowes 3011001 Shredder Logo
259 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
