Question about Necchi Sewing Machines
Machine Necchi Model 3355 does not keep a good stitch I wonder if I am threading it correctly but my manual is misplaced ad I just need a picture to check and see if I am threading it correctly.
dupina
  • 110 Answers
SOURCE: stitching to loose
There are many websites from were you can download manuals. Just type "sewing machine manuals" in gooooooogle and they will list them. The cheapest option is 10 US dollars in pdf. format.
Your looper tension is not correct. Make sure the cotton is between the tension disks by pulling down on the thread when you thread the machine.
Regards
Dupina
Posted on Dec 12, 2007
  • 12 Answers
SOURCE: thread constantly wraps around spool pin
Cut a round curcle of fabric the size of the spool from a piece of felt. Put a hole in the middle and put it under the spool of thread. If this does not work you can purchase a small net that fits over the spool. It is designed to keep the thread from coming off the spool except for being pulled through naturally.
Hope this works.
Zelma
Posted on Jan 19, 2008
bargainbox
  • 1388 Answers
SOURCE: Machine not sewing
Make sure you have threaded the machine from right to left, it sounds like the needle thread is trapped under the lower looper thread and cannot form a stitch.........start the threading over from scratch like this:
  1. Lower Looper
  2. Upper Looper
  3. Left Needle
  4. Right Needle
Is there a diagram for how to thread on the inside of the door ?
Follow that slowly and carefully to make sure you have not missed any thread guides on the way, as each one needs to be followed through to ensure correct tension and thread progression.
If you are certain that all threaded correctly, did you have a fabric jam and pulled it loose ? If so, the timing may well be affected.
Post an update and we'll get this right.
Bargain Box
Posted on Feb 03, 2008
bargainbox
  • 1388 Answers
SOURCE: My bottom thread is loose when sewing a straight stitch
Please TRY the solution BEFORE giving your considered rating.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
Posted on Jul 24, 2008
SOURCE: Necchi 4575
I've found that my machine doesn't like Coats & Clark thread; I have to feed it Guterman
Posted on Aug 04, 2008
Hi. I have a Necchi MOD559. For some reason the stitches on the bottom stay too loose, so that I get little string hooks and not a clean tight stitch. From the top it looks great. Advice anyone?
Yep, It is called bird nesting or thread nesting. The number one reason is that the top thread is not seated completely in the top tension disk.
Install a brand new needle.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning. Confirm the thread path is correct.
Now recheck your machine stitching.
Remember if the thread issue shows under the fabric, it is a top thread problem. If the thread issue shows on top of the fabric, it is a bobbin problem.
If the top thread still shows on the underside of the fabric, you may need to tighten the top thread so it will pull the bobbin thread up.
What causes Bird Nests Superior Threads
Sewing Machine Thread Bunching Up Here Why
May 24, 2017 | Necchi Sewing Machines
My Necchi Silva maximatic is not stitching eg one small stitch and the next is a massive and the thread is puckering - lost my manual so cant work out what needs to be adjusted
The first step when experiencing stitching problems is to completely re-thread your machine. Without a manual this can be difficult! There is a diagram with some threading details for your machine at:
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Necchi_Sewing_Machine_Threading/Necchi_584_586_threading_Diagram.htm
There is also a complete manual that is written in Italian but the pictures are much better here:
http://www.ornato.it/wp-content/uploads/2010/04/Necchi-Silvia-Maximatic.pdf
The 2nd most likely problem would be with your needle: dull, bent, chipped point, etc. Try a new needle!
Like most problems, try something, test, try something slightly different, test, repeat until successful. Good luck!
May 06, 2016 | Necchi Sewing Machines
How to thread a NECCHI royal series machine 3204FB
How to thread a Necchi model 535 FA sewing machine [now ...
? 8:52
https://www.youtube.com/watch?v=CEGuA6kZG4A
Jan 8, 2012 - Uploaded by Wren Paasch
How to thread a Necchi model 535 fa sewing machine. I'll make a separate video to show how to wind a ...
Necchi 3215 Sewing Machine Demonstration - YouTube
? 0:40
https://www.youtube.com/watch?v=ulo4kvnj3PU
Aug 9, 2011 - Uploaded by GoldCoastSewVac
... explains what the Necchi Heavy Duty Sewing Machine can sew and ... How to thread a Necchi model 535 FA sewing machine [now with ...
How to Thread a Necchi Sewing Machine (with Pictures ...
Dec 14, 2015 | Necchi Sewing Machines
Necchi sewing machine
There are a number of things that could cause this.
Needle installed with flat in the wrong direction.
Excessive thread tension,top or bottom.
Lack of lubrication. If the machine can do anything more than a straight stitch the mechanism can gum up and not move the needle correctly.
Here is a link to threading directions.
Necchi 3537 Sewing Machine Threading Diagram
Aug 03, 2014 | Necchi 3537 Mechanical Sewing Machine
Hi. My name is Sue. Could you please let me know if our Necchi sewing machine has a blanket stitch or not? The model number is 4825. Thank you
Hi Sue,
I found that the blanket stitch is also called a "whip stitch" or a "crochet stitch" and looks like this:
I tried to look for instructions or a manual on the web for your machine, but there's little to find. I did find a picture of the stitch selector - and it looked to me that the RED "D" or "F" :
was as close as that machine was going to get to it. I'm not a sewing machine person - so that may not be correct.
Mar 03, 2011 | Necchi 4575 Mechanical Sewing Machine
I don't really have a problem, but cleaning. I would like to clean my Necchi Model 3355 myself, but don't know where to start. Help
I also have 2 necchi sewing machines,, here's what I do
keep a check on the needle to make sure it not bent,blunt
clean under the needle plate where the feed dogs are for lint--if you sew alot every week--if once in awhile once a month
also clean the bobbin area for lint or loose threads
keep a cover on the machine to keep out dust
Nov 26, 2010 | Necchi Sewing Machines
I broke a needle and when I replaced it my nice stitching disappeared. Thread is very loose in the top of the machine. I misplaced the manual in a move, so I may not be inserting needle correctly.(?) I...
the flat side of the needle goes to the back of the machine
I also have the same sewing machine, if you will send me your email address thru a comment & I will copy pages of the operation manaul & send them to you
Oct 15, 2010 | Necchi 4595 Mechanical Sewing Machine
I need a manual for a Necchi Royal Series, #4795FA. Threading Diagram and Instructions to set the correct tensions on the Thread and foot
Hi! I found your manual at http://www.sewusa.com/Sewing_Machine_Manuals/Necchi_Manuals/4795_Instruction_Manual.htm
Happy Sewing!
Robbie
Mar 14, 2010 | Necchi 4595 Mechanical Sewing Machine
Where can i get my sewing machine fixed? i have a Necchi sewing machine, and it does not work. i bought it two years ago and it was working perfectly. i've tried everything it said in the manual, but it...
make sure you have it threaded right and picking up thread at bobbin
brfore sewing i have seen a lot of people put the thread the wrong way through the needle and it will have this problem
Dec 31, 2009 | Necchi Sewing Machines
Thread jamming, wont feed material, sewing in one place
Try moving the stitch length dial to 4 or 5 - check the manual. You may have it in the position for very close together sewing. I had to do a lot of trying with my 4795 to get it to work right. I found that very thin thread, polyester kind, broke at the needle after a couple of stitches. I switched to coats & clarks thread and a Singer ball point needle and it works fine. Be sure your needle is inserted with the flat top toward the back of the machine. Good luck!
Nov 04, 2007 | Necchi 4595 Mechanical Sewing Machine
Sewing Machines Logo
95 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
