Home | Dell | Dimension 8100 PC Desktop | Dell 8100 Dimension wil...
Dell Dimension 8100 PC Desktop
Problem for Dell Dimension 8100 PC Desktop
Dell 8100 Dimension will not find the Hard Drive or CD Rom
By herb921 on Jun 29, 2009
Upon Power on, the Dell 8100 Dimension will not detect either the Hard Drive or the CD Roms. I tried a known good drive.
Comments:
Jun 29, 2009
- I have tried all of the above, new Cables, different known good hard drive. the yellow StandBY light is lite on the mother board, and lite D on the rear of the case is yellow, the rest are green.
Solution #1
posted on Jun 29, 2009
Somewhat Helpful)
novafire
Rank: Wiz
Rating: 84%, 19 votes
If the drives share the same IDE cable, try to replace the cable and make certain it is seated properly on the motherboard. Check for bent pins on either drive and on the motherboard IDE connector. Sometimes pins (especially near either end of the 2 rows of 20 pins) will bend under if they are not lined up with the IDE cable. Also check that nothing changed on the Jumper positions on the drives. They should be set to Master if both drives are single and Master (hard drive) and Slave (CDROM) if they share the same cable.
Comments:
Jun 29, 2009
- If you have access to a different computer, you can try the drives in that or try them with an IDE to USB adapter. Also, if you can get a hold of a PCI IDE controller card, you could attach the drives to that device instead of the motherboard.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Somewhat Helpful)
leecom72
Rank: Guru  Dell Expert
Rating: 89%, 2407 votes
Check to make sure the hard drive jumpers is set to master and the CD/DVD rom is set to slave, have a look at this for an idea >>>>
As soon as you have the jumpers in the right place your system should recognize both drives.
Regards
Comments:
Jun 29, 2009
- Does the machine turn on?
Was this helpful?
Yes
No
Solution #3
Not Helpful)
pshinde23
Rank: Wiz
Rating: 81%, 105 votes
Did you open the system and change the cable connections?? This happens due to wrong/disturbed cable connections, reconnect it to the proper working slot, if you do not know the right place try all the slots one by one and find the correct position, make sure you connect the power cables too.
Check if the memory chip (Ram) is inserted properly into the slots, Also in the BIOS setup always keep the device detection to "Auto Detect" unless you are pretty sure about the configuration.
Was this helpful?
Yes
No
Popular Solutions for Dell Dimension 8100 PC Desktop
Questions and Unsolved Problems for Dell Dimension 8100 PC Desktop
Do you recommend Dell Dimension 8100 PC Desktop?
Answer
Answer
down load drivers for mother board uli ali m1573
Answer
I want to down load drivers of uli ali m1573audio and ethernet connections
Answer
When I open the Arc-Soft software, it will show my face in the video screen for a second then switch... (More)
Answer
I love my Dell 530 computer and having trouble getting e-mails when it notifies me that I have mail
Answer
i have a westinghouse laptop model nb-12w2 and i need the recovery disk
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dell Dimension 8100 PC Desktop:
Top PC Desktop Experts
Rank: Guru Guru
Solutions: 494
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more PC Desktop Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
