Question about Maytag Ovens
My oven will not heat up, at best it may get warm. Please help
    President:
  • Maytag Master
  • 1,922 Answers
One of three possibilities: a hotspot in element(check for pitted discolored area in element)where current cant get thru/defective thermocouple(controls oven temp cycling) bad oven temp control(control you set for temperature
Posted on Jul 29, 2009
  • daniel  hendrickson
    daniel hendrickson Jul 29, 2009
    one of three possibilities: a hotspot in element(check for pitted discolored area in element)where current cant get thru/defective thermocouple(controls oven temp cycling) bad oven temp control(control you set for temperature
My Frigidaire dual fuel oven wont get hot. Both heat elements and temperature sensor have been replaced and it still only gets warm. No error codes are displayed.
Thank you for your post, Chrissie!
I understand that your Frigidaire duel fuel oven is not heating properly. I see that you have replaced your temperature sensor and heating elements and your oven is still not working. This could be a possible issue with your control panel or wiring harness. Since it could be anyone of these underlying issues I would recommend having a professional technician out. This will help you avoid any unnecessary part purchases. Hopefully this is helpful information. -Matt
Jun 01, 2015 | Frigidaire Ovens
OVEN ONLY HEATS TO WARM YOU CAN TOUCH THE INSIDE OF OVEN IS THIS THE ELEMENT? IF SO HOW DO YOU CHANGE IT? AS IT IS HIDDEN
i doubt that it is the element as it gets warm
I suspect a faulty thermostat or oven switch
best have an electrician check it out.
Apr 09, 2015 | Ovens
Upper oven will not heat up in any mode. "Pre Heat" and "On" come on for a few seconds, then go off. I checked the elements, all between 15 and 30 ohms. Every now and them it will...
Hi n664v,
This sounds to me like a Thermostat problem. If it is an electronic version Oven, then it will be the Sensor or PC Board Module controlling temperature. Please let me know what Make and Model your Oven is, so I can better assist you.
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Aug 17, 2011 | Ovens
Main oven light works fan runs but oven doesn' get warm
ROSIERES Oven not heating? How to replace a ROSIERES fan oven element
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. You searched for ROSIERES element How to Repair Home Appliances
May 23, 2010 | AEG U3100-4 Electric Double Oven
My oven won't warm up. I was cooking some oven chips last night when the electrics tripped in my house. I reset the electrics, however my oven lost its heat and started to cool down. I turned it off and...
The problem will be the oven ele3ent has failed, a very common event.
It is located at the rear of the oven behind a removeable cover.
Make sure you have the power off.
Please rate my solution.
Thankyou.
Feb 03, 2010 | Whirlpool Ovens
Need heating element for oven of 1950's Frigidaire by GM stove
Fixya is unable to identify parts sources.
Jan 23, 2018 | Ovens
Fan oven on zanussi electric cooker does not heat up
From symptons, I would say the fan oven element is faulty, more so if the fan is working. Remove inner rear panel of oven and see if element gets warm, let it run for a minute, switch off and feel if element is warm, if not, then replace.the element.
Plz rate this solution.
Thanks.
Dec 26, 2008 | Zanussi ZHQ575 Electric Double Oven
GE 24" Oven
THE TEMP IN THE OVEN IS CONTROLLED BY A THERMOSTAT.IT GOES FAULTY IN TWO WAYS.IT EITHER OVER HEATS OR UNDER HEATS IN YOUR CASE ITS SOUNDS LIKE ITS UNDER HEATIN.BEST YOU GET A TECHNICIAN TO CHECK IT AND CHANGE IT FOR YOU.GOOD LUCK.MOHAMED
Sep 12, 2008 | Ovens
Ovens Logo
63 people viewed this question
Top Maytag Ovens Experts
Carmen Mikulic
Oloyede Monsuru
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
