Question about Panasonic NV-GS230 Mini DV Digital Camcorder
Tape won't come out!
Hi! I bought a NV-GS230 a few years ago and I can't take the tape out of it. I've always taken good care of my camera and I didn't use it in any extrem condition... but now, when I open the tape cover on the camera, nothing happens!!! Can you please help me with this?
Thanks a lot!
Simon
  • 4 more comments
  • simon_benoit Jun 30, 2009
    The power seems to work correctly... When the camera is ON, everything seems fine but I can't record and I can't take the tape out... Could it be stuck? Is there any way I can open it to check it out?
    Thanks!
    I'll have to try this one... I'll keep you up to date about the result!
    Thanks
  • simon_benoit Jul 01, 2009
    HI,
    It may sound strange but I just realized that it's a PV-GS65 and not a NV-GS230.
    The power seems to work. I can use the camera to take pictures and I can look at them afterward. But as soon as I try to look at what's on the tape, I press play, fast forward or anything alse but the tape won't react... no noise or movement around the tape.
    When I try to film, the image appears on the screen and it shows REC but the seem thing happens (... nothing happens )
    Finaly, when I open the the camera to take the tape out, nothing moves...
    Do you have any idea of what it could be? Could it simply be the tape mechanism that's broken? If it's the case, do you know how I can open it to take a look at it?
    Thanks a lot!
    Simon
  • simon_benoit Jul 06, 2009
    Unfortunatly, nothing works... Do you have any other idea? Do you think I should open it take a look inside to see if anything seems to be stuck?
    Thanks
  • simon_benoit Jul 08, 2009
    Hi! I once tried to open it to check if anything could have loossen up but, once all the screws were taken off, nothing moved. Could you please tell me how to check the door latch and the springs?
    Thanks
  • simon_benoit Jul 13, 2009
    Actualy, I sent it to a Panasonic repair center and they finaly told me that the problem comes from the main board which would cost me around 600$ do get it repaired... Unfortunately, I think I'll simply have to forget about this camera (which is as new) and maybe get a new one...
    Thanks for your help!
  • Panasonic Master
  • 3,866 Answers
Well if the tape is not moving then there is something wroung with the motor inside, $600 for repairs there nuts when you can buy the part on ebay.com and put it in yourself for less then that. I think you need a secound opion on the $600 thing and not throw away this camera and look for the part they said went out online you will save your self a whole lot of cash.
I am sure this can be fixed for under $50 bucks as the board on ebay I seen for $35 before. I would do some research before throwing this away.
Rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Jul 14, 2009
    Top Expert:
  • Panasonic Master
  • 81,423 Answers
This problem has nothing to do with whether you took good care of the camera, it is caused by a failure in the very complicated tape loading and unloading mechanism, it is either the drive belt has failed or the mechanism has a broken part, the bottom line is here you will need to send this into a Panasonic authorized repair station, the sooner you realize that you can't fix this at home the sooner you will have the camcorder back in use.
Posted on Jul 08, 2009
  • 11,896 Answers
Check the door latch and springs to make sure they are intact. They may have fallen loose. It also may be a firmware malfunction in the circuit board due to faulty capacitor or just planely the latch needs to be greased.
Posted on Jul 06, 2009
    President:
  • 1,383 Answers
Reset al settings to factory defaults.
Alo remove battery from cammera and meomry card from it.
Then check./
Posted on Jul 01, 2009
Sounds like a battery issue, if not, electronic.
Is the battery charged? Try keeping the power cord plugged in, then turn on the camera. There might also be a LOCK button or switch somewhere. Ensure it is not in the LOCK position. Then try opening the tape cover again.
Let me know how this goes.
Best regards.
Posted on Jun 30, 2009
  • 1 more comment
  • Anonymous Jun 30, 2009
    Just wanted to add, if the above doesn't work, the tape cover might not be fully closed. Try pushing it in further or give it a gentle tap. Then try ejecting again.
    It does sound stuck. Can you try putting the camera into the Play mode (as opposed to record), and push the cassette cover in hard to make sure its closed properly, and then try ejecting while in play mode.
    Not a problem, hope it helps.
    Best regards
    nLinked
I have a NV-DX110B about 11 years old. I'm getting
Your camera appears slightly older than mine so I will do my best for you. Have you tried ejecting the tape with the power off? If I have problems I slide the eject button when the camera is off but plugged in and the tape can be ejected. I suspect the tape mechanism is in trouble. When a tape stuck in mine I had to literally force the cover open. But this is a last resort.
Give my suggestion a try and apologies if you have already tried that...
Sep 11, 2011 | Panasonic Video Cameras
I BOUGHT A FIREWIRE 4PIN END TO END FOR MY CAMERA. CONNECTION FAILED. COMPUTER DOES NOT DETECT MY CAMERA
Open Windows Movie Maker and have the camera set to VCR mode, that's the one thqat replays the tape.
Try again.
Mar 26, 2011 | Panasonic NV-GS230 Mini DV Digital...
Mini DV tape won't play in panasonic nv-dx100 PAL
Have you found any solution to the F01 error? I just got the same issue. Thanks!
Feb 28, 2010 | Panasonic NV-DX100 Camcorder
Panasonic NV-DS30. Camera and VCR works only at
i had same problem and i took out the tape cartridge and found tape hanging out i fixed that carefully then it worked fine
Sep 08, 2009 | Panasonic Video Cameras
Need Driver for Panasonic nv-gs230 Camcorder Software to download
You should be able to just plug a USB into the camera connect it to your computer.
The camcorder should come up as an drive in "MY computer"
Try renaming any video that are named *.moi to *.mpg
if they wont play.
Hope this helps.
Sketchlab.com
Mugshot Collection
May 15, 2009 | Panasonic NV-GS230 Mini DV Digital...
Tape problem
clean the heads with rubbing alchol and a qutip
update software
Feb 12, 2009 | Panasonic NV-GS230 Mini DV Digital...
Black stripes with Panasonic NV GS320
"a little tap on the bottom of the camera solve the problem of the black strips..."
I know for sure a little **** in *** solves definitly black strips trouble, please give a try.
Feb 03, 2008 | Panasonic NV-GS15 Mini DV Digital...
No sound or vision playback of dv tape
From my poin of view cyliner (rotary head) have poor conection or this parts will be replace.
Aug 06, 2007 | Panasonic NV-GS11B Mini DV Digital...
Panasonic NV-GS230 Mini DV Digital Camcorder Logo
123 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
