Question about SanDisk Sansa e260 MP3 Player
Sansa e260 My sansa 4 gig wont play any mp3s and it has a bunch of files that arnt really there and they say there is 36 GB of them how is this possible and it says any song i put on there is a bad song file but they work on other mp3 players like my psp etc how do i format it?
I had this Mp3 player aswell doing the same problem. Try formatting the device itself, and if that doesn't work take it back to the store where you purchased it or contact the company. This Mp3 did the same with me and created multiple files at large sizes I did not create myself, and i've had around 3 of these Mp3's. If your purchasing a new one I'd suggest a Creative or Apple.
Posted on Nov 08, 2007
  • 626 Answers
You can format the device in My Computer>Device Name (e260)>Right Click and select format.
If that does not work, change the mode on the device Settings>Mode or USB Mode and ty again.
Best of Luck.
Posted on Nov 07, 2007
SanDisk Sansa e260 (4 GB) MP3 Player MP3 and Digital Media i have a e260 sansa mp3. when i plug it into my Answer i have a e260 sansa mp3. when i plug it into my computer it wont charge what should i do
There is a trick to charging the battery in these small mp3 players. It wont charge if it is turned on, and it won't charges if it's turned off. Here what to do...
1. plug the payer into your USB port. or wall charger
2. switch thje palyer on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
Jan 30, 2010 | SanDisk Sansa e260 MP3 Player
My Sansa e260 can't read sdhc cards
From what ive found the max expansion card it supports is 6gb they might offer support for higher capacity cards with a firmware update but as of right now no they don't
Nov 05, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e260 installed with rockbox doesnt play video.
Sans e200 support:
http://www.sansa.com/support/sansa_e200/faqs
Manual for Sansa e200 series:
http://www.sansa.com/sites/default/files/downloads/e200_userguide_en.pdf
1. Using the Sansa media converter for preparing videos to make them
suited for the player as you are doing is just fine.
2. Page 22 [19 in written manual] of the pdf file shows how to make playlist(s) using Windows Media Player 11.
2.1 First create a playlist
2.2 Save the playlist
2.3 Synchronize the required playlist onto the connected player
Sep 09, 2009 | SanDisk Sansa e260 MP3 Player
It's hit-and-miss whether my Sansa will register transferred mp3s
first try using windows media player to sync.. it tends to work a bit better if not
try this...
1 connect your sansa to comp via usb cable
2 right click start on windows desktop go to explore
3 scroll down to your sansa's drive rifght click it go to properties
4 go to tools tab and click "check now" under error checking will take awhile and will erase your memory on the sansa but it will probably work again
I hope my post was helpful let me know!!!!
Mar 13, 2009 | SanDisk Sansa e260 MP3 Player
Copying
if you have a pc you should try syncing with windows media player
Jan 16, 2009 | SanDisk Sansa e260 MP3 Player
Computer(s) wont recognize sansa e260
i have the same SANSA e260.....and the same problem....its easy just turn on your sansa then push the menu botton, slide the wheel in the center and at the end of the options say USB enter there and change usb mode from MTP to MSC mode.....and ready
Jan 02, 2009 | SanDisk Sansa e260 MP3 Player
Cannot get my computer to recognize my sansa e260 player
I cannot get my desktop to find a driver for the e260, but if you use the SD microdisk you can load stuff to the microdisk if you have a card reader. You need to buy the full size SD card with the micro SD attached. Then sync the stuff you want to load and when you boot up your player, it will refresh the data base and you can play the stuff on your card. Seems a shame to waste 4 gigs of hard drive on the player, but I do not know anyone who has found a driver for the e260 that works with XP service pack 2. If you do please send me an email me.
Dec 09, 2007 | SanDisk Sansa e260 MP3 Player
Sansa e260r\
your music is taking a lot of space
Nov 24, 2007 | SanDisk Sansa e260 MP3 Player
Sansa e260 4 gb mp3 player
You could reinstall the firmware (what makes the sansa work). Its pretty easy to do, no need of downloading/installig, its already all in the sansa. You just need a computer How do I restore the firmware Firstly, place the e260 in restore mode. To do this, follow these steps 1. Push the Hold button on top of the e260 to the right. 2. Hold in the record button 3. Press and release the Menu button 4. The device will now go into Restore Mode. If you have not already connected the USB cable to your PC, it will direct you to do so. 5. The root directory of the device will open up on the PC screen. Now drag and drop the two files Firmware into into the e260 root directory. You will find a copy of the two firmware files zipped up elsewhere on these forums 6. Push the Hold button on the e260 back to the left 7. Unplug the USB cable from the PC. The e260 will now reboot, writing the new firmware images to the correct location. 8. This process will have wiped all your music files. You will now need to re-synch.
Jun 28, 2007 | SanDisk Sansa e250 MP3 Player
Sandisk E260
some movies cannot go on mp3s because they will not fit...its according to how many gigs you have, like a e260 for instance its only a 4 gig.a movie can be way more than 4 gigs.maybe even 20 gigs.so movies might not be a very good thing.it will take alot of or all of your space.but you can put video clips on on one like that...
Dec 26, 2006 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
50 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
