Cycle finished and door won't open
SOURCE: my bendix washing machine door
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
SOURCE: i cant open the door
Hello, Welcome to FixYa.
Hopefully the info below will supply you with the assistance to get the door open, but first
**The door typically won't unlock as a result of the unit failing to drain due to a pump or filter obstruction, excessive suds, but the pump failing can cause this as well**
**Unplug the washer from the wall or turn off the breaker before attempting any repairs...safety first**
This is generalized info regarding most front load washers which differ from other models. I believe it will resolve the issue with yours.
Start by following this guide for accessing and cleaning the pump filter...
The next step is as follows,
That should resolve the problem, As I also alluded to before there is a small possibility the pump itself is faulty, but not likely.
Thanks for choosing FixYa and good luck. Let me know if you need further assistance or if any of this is unclear.
Regards,
Macmarkus :)
