Brother P-Touch 1180 Label Printer Logo
Posted on Jun 29, 2009
How do I print vertically? - Brother P-Touch 1180 Label Printer
Chitownbarb
Level 1:
  • Contributor 21 Answers
  • Posted on Jun 29, 2009
Chitownbarb
Contributor
Level 1:
Answers
21
Questions
0
Helped
17638
Points
57
  1. Type the text for the label.
  2. Press the "Function" key.
  3. Press the "Left" or the "Right" arrow key until STYLE is displayed.
  4. Press the "Return" key, which is the key with the broken arrow pointing left.
  5. Press the "Left" or the "Right" arrow key until VERTICAL is displayed.
  6. Press the "Return" key.
  7. Press the "Print" key.
I’m happy to assist further over the phone at https://www.6ya.com/expert/barbara_87cfe34e34050f26
1helpful
Why is my printer Kyocera Ecosystem P3045dn producing vertical mark on printed sheet?
If your Kyocera Ecosystem P3045dn printer is producing vertical marks on printed sheets, there could be a few potential causes for this issue. Here are some troubleshooting steps you can take:
  1. Check the print cartridge: Inspect the print cartridge for any damage or defects. Ensure that it is installed correctly and securely in the printer. If the cartridge is low on toner or nearing its end of life, replace it with a new one.
  2. Clean the print head: The print head may have accumulated dirt, debris, or dried ink, which can cause vertical marks on the printed sheets. Refer to the printer's user manual for instructions on how to clean the print head properly. Use a lint-free cloth or recommended cleaning materials provided by the printer manufacturer.
  3. Check the drum unit: The drum unit could be dirty or damaged, leading to the production of vertical marks. Remove the drum unit according to the printer's instructions and inspect it for any signs of damage or wear. Clean the drum unit using a soft, lint-free cloth. If the drum is damaged, consider replacing it.
  4. Inspect the paper path: Check the paper path for any obstructions or debris that might be causing the vertical marks. Look for torn or wrinkled paper, as it can leave residues on the print path. Remove any obstructions and ensure the paper is loaded properly in the tray.
  5. Adjust print settings: Ensure that the print settings in your computer or printer driver are correctly configured for the paper type and print quality. Adjust the print density or quality settings to see if it affects the appearance of the vertical marks. You may need to experiment with different settings to achieve the desired result.
  6. Update printer firmware and drivers: Outdated printer firmware or drivers can sometimes cause printing issues. Visit the Kyocera website and download the latest firmware and drivers for your printer model. Install the updates according to the provided instructions.
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
How to print vertical
Vertical printing is one of the 9 styles of print available. To select a print style:
Hold down the CODE key.
Press the STYLE key once. The display will show the current style.
Still holding down the CODE key, press the STYLE key again. The available style will appear in order as you press the STYLE key.
When the VERTICAL style appears release the CODE key.
Vertical alignment
Usually this is asked when the printer is using more than one page of paper to print what the word processor shows as 1 page. This is fixed in the word processor program print set up module that opens when you click Print.
If you really want to change the vertical alignment of the print heads, then you need a different printer.
2helpful
2answers
Brother MFC 7220 prints vertical line from top to
The photosensitive drum needs to be cleaned or replaced. If after cleaning it the vertical line continues, the printer may need maintenance.
1helpful
2answers
MY PROBLEM IS MY 230 PRINTER VERTICAL PRINT IS NOT
I have problem while printing colour photos and I would like to know how to print back to back i.e. even and odd pages
Anoterh Vertical Line Problem!
So many questions Vertical lines suggest [you do mean vertical do you - up/and down?] is new one to me try www.fixyourownprinter.com Printing CD's is not a 2200 thing, it is the province of the R series. Printing lables is easy purchase CD labels and suitable CD print software - A kit including labels software and label applicator is available at many computer stores Other labels- download the Avery-Dennison free lable software.
Norman Weimar
Norman Weimar
k24674
