Home | Dell | Dimension 2400 PC Desktop | Low battery warning
Dell Dimension 2400 PC Desktop
Problem for Dell Dimension 2400 PC Desktop
Low battery warning
By eastmafe on Jun 29, 2009
I receive a "low Battery" warning on my PC whenever I boot up from off mode. It doesn't report this from sleep mode.
Best Solution
posted on Jun 29, 2009
Helpful)
micromatikal
Rank: Wiz
Rating: 84%, 212 votes
That is correct, sleep mode does not utilize / see the CMOS battery upon waking up. However when it's booting from off mode it does check the CMOS battery. I would recommend getting it changed, however it you don't the worst thing that will probably happen would be that you will have to reset the clock any time you completely remove power from the computer.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Helpful)
Imaginex
Rank: Guru
Rating: 88%, 161 votes
That is because while a computer is in sleep mode, it is still using power to keep the memory. The battery is only used when the computer is turned off. You should replace the battery as soon as you can in order to keep your computer running properly.
Was this helpful?
Yes
No
Solution #3
Somewhat Helpful)
vlayne
Rank: Master
Rating: 68%, 10 votes
Please replace the battery when you have a chance. This will not only help you to remove that warning... but also to keep your system date current.
Was this helpful?
Yes
No
Popular Solutions for Dell Dimension 2400 PC Desktop
Questions and Unsolved Problems for Dell Dimension 2400 PC Desktop
Do you recommend Dell Dimension 2400 PC Desktop?
Answer
Answer
down load drivers for mother board uli ali m1573
Answer
I want to down load drivers of uli ali m1573audio and ethernet connections
Answer
When I open the Arc-Soft software, it will show my face in the video screen for a second then switch... (More)
Answer
I forgot to say in my last post that I do know about using Cntrl-+ or scroll to enlarge type size on... (More)
Answer
Hi there, Thanks for using fixya. What is the operating system running on PC? Since when you are... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dell Dimension 2400 PC Desktop:
Top PC Desktop Experts
Rank: Guru Guru
Solutions: 499
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more PC Desktop Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
