Question about HP Pavilion zd8000 Notebook
Screen hinges are weak or broken. HP ZD7010US
Screen hinges are weak or broken. The screen has to be balanced upright, it will not stay open. How do I fix it?
  • iamron2 Jun 29, 2009
    Thanks for the speedy reply....
    I found a source for the hinges.
    Will a hinge replacement do the same thing?
  • 375 Answers
The only way to fix it properly is to buy a new chssis or a broken one to use for a donor.
Posted on Jun 29, 2009
  • Z Laws Jun 29, 2009
    It depends on whether it is just the hinge or whether the chassis is cracked as well. If they are a reasonable price, it can't hurt to replace them and see.
Broken hinge
Not that I know of. They are easy to replace, check out these WEB sites.
Replacing a hinge, or both of them, isn't very tough.
http://www.insidemylaptop.com/replace-br... Replacing Display hinges
http://www.laptopparts101.com/display-screen-hinges/
Sep 07, 2012 | HP Pavilion dv9005us Notebook
Oven door not closing properly
If it is a drop down door with hinges on the bootom of the oven door, then it is likely to be weak door hinge springs, the usual solution is to replace both hinges.
If it is a swing open door, then the problem is related to a worn or broken door catch, or worn striker pin.
Apr 13, 2010 | Ovens
My screen won't stay open. i think the hinges are broken
Hi. The hinges are either broken or worn out. It is possible to replace them but it can be difficult to find them. I recommend calling around to a few local repair shops as they may have an old one of your model that they are using for parts. Here is a link that shows you how to replace a hinge http://www.insidemylaptop.com/repair-replace-broken-hinges-hp-pavilion-dv9000-notebook/
Also, here is a link to get actual HP parts http://h20141.www2.hp.com/hpparts/CountryChoice.aspx
Nov 11, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Broken Hinges
you have to change your hinges.Plz visit to your nearest service station.
Mar 14, 2009 | HP Pavilion dv6000t Notebook
Gateway Table PC Cx2620 Screen Wobble
Unplug and remove the battery pack for safety. DOn't want any shorts to happen. With the laptop open, gently pry with a very small blade the plastic cover at the front of the swivel and remove. It is in two pieces...front and back. It is OK to leave the rear half in place. Once removed you must close the laptop again. You will now have access to the screws on the hinges. Use a small Robertson screwdriver to tighten the screws. Snap the cover back in place....Voila!. IF the screws are broken (like mine were) remove all the good screws, gently lift and move the screen slightly forward, remove the broken screws with some needle nose pliers. Reassemble with new screws. I found some screws at the local computer geek shop in his selection of random screws. THey are quite tiny. CHeck Future Shop if they are in your area as they deal and repair Gateway so you may have a better chance of finding some screws that work. Good Luck.
Nov 18, 2008 | Gateway Convertible CX2620 Notebook
Broken laptop screen HP Pavilion ZV6000
I have a HP Pavilion zv6000 laptop too, and I have the same problem. A year ago, the screen was getting loose and finally it just broke. Won't stand up. I've been propping it up against a wall for a year. I can see what is wrong: my laptop has gotten so hot that the back of the laptop where the hinges are has warped and ruined the hinges. Do you notice that? The split in the seem and the actual bend of the plastic? Anyway, the computer itself works perfectly. I was going to buy new hinges and replace them myself, but it was too much of a hassle, and I needed a new laptop anyway. The hinges are inexpensive. And the laptop isn't TOO difficult to take apart (search for the manual. it's easy to find). I took it apart with my Grandpa, and he's old, and I'm a girl. (okay, sexist, gender...ist.) I actually received a new laptop as a gift. Luckily. No solution, other than replacing hinges. I just wanted to let people know I too had the same problem.
Aug 13, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Laptop screen will not stay upright
You may be able to tighten the hinges, but more than like you will have to replace them
Jul 01, 2008 | Dell Inspiron E1405 Notebook
Compaq EvoN600c
sounds like time to replace the hinges. check e-bay, there cheap
2.99 + ship
May 25, 2008 | HP Compaq Evo Notebook N600c
Toshiba Satellite 2450
It sounds like the hinge itself is broken. I have a relative with exactly the same problem, her laptop screen became floppy and didnt stay in the upright position. The hinges for the screen are complicated in that they appear to come as a top/bottom part already joined together, and need to be replaced as such. The metal used for the hinges is really flimy and easily snaps. this sounds like what has happened to yours. The problem is that is appears to be not econimcally viable to repair, and your probably better off scrapping it or buying another with say;.. a cracked screen and doing a swap-over of parts to get one fully working one (thats what I did)
Feb 25, 2008 | Toshiba Satellite 2450-401 Notebook
HP Pavilion zd8000 Notebook Logo
133 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
