Question about Garden
Stalls, with oil runing out the exhaust
I have a 1 year old 42'' troy built rider. I used it about 5 times last summer and then parked it in the garage. I started it this summer and it ran for a few minutes, blew out white smoke and stalled. It will start, run for about 15 seconds and stall. After continuous atempts oil started driping out of the exhaust. Aside from a damaged ring is there any other posablities
  • Dwain Pippen May 11, 2010
    Have you checked your oil? Does it smell like gas? Is the level higher than it was?
  • 127 Answers
You have a valve that is stuck in the open position head will need to be removed
then spray valves with wd40 and turn engine over a few times watching to see both valves open and closing,once that is working install head with new head gasket.this is caused by not properly storing the unit. gas should be drained at the end of every season and then ran to burn all gas off from carb and fuel lines once it quits remove sparkplug shoot a tablespoon worth of oil in the cylinder crank engine over for 10-15 seconds to distribute oil on cylinder walls and valves then re install plug now your unit is winterized ready for the next season
Posted on Jun 30, 2009
What type oil dose a troy built 42" zero turn mower take
It depends on what engine you have fitted, the Briggs engines are normally sae30, Honda and Kawasaki tend to use a multi grade oil sae10-30
Jul 04, 2018 | Troy Garden
Two problems-dont know cause or if related or not. #1 engine backfires,stalls spits hesitate like not getting fuel
This is definitely a carburetor issue... when your rider needs more fuel and air to suffice the engine, it's not getting it. How old is the unit? When is the last time it's had the carburetor removed to he serviced...
Start there....
Nov 01, 2015 | Garden
Why does my 1991 Ford Laser GL keep stalling?
possibly the vacuum hose from the top of the rocker cover or near that exhausts the fumes from the oil to the carbie is disconnected or block...or if it is automatic it could be that the transmission needs servicing.ie new filter and gasket kit bout AUD$20 and clean new transmission fluid AUD$40.. just drop the pan one side at time. catch the old fluid. when its empty remove the entire pan with care. then clean the pan and remove old filter. then insert new filter and o-ring. then line up new gasket on pan and bolt back in to specific tension. pour new fluid in to specification.warm engine in park to runing temp then check fluid level... this is all to remove the possibilty that it is the transmission and not the engine AUD$60 and 2 hours of your time..
Feb 20, 2013 | Cars & Trucks
There is gas in the oil in my troy built 13AN689G766
Replace the inlet needle and seat in the carburetor and change the oil. As long as you didn't run the engine with diluted oil the engine itself should be fine. If your machine has a fuel shutoff valve between the tank and the carburetor, use it. Close the valve every time you store the machine or leave it parked and not running.
Aug 08, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
John Deere LA110 riding mower has gas in the oil
Try stripping it down and having alook sounds like the piston ring has snapped and is pumping gas into the oil that would explain why the oil is coming out the the exhaust the black smoke is just oil burning up ou also might want to clean the carb alittle too.
Mar 19, 2012 | John Deere 22HP Hydrostatic 42" Riding...
What is the oil capacity on a honda Valkyrie Rune 2005 bike?
I have a 2004 Rune, I changed oil last year with Mobile 1 Synthetic 5-30W. The bike is running great. Added 4 quarts.
Sep 20, 2010 | 2004 Honda Valkyrie Rune
Troy-bilt TBP6040 4-cycle stalls out after about 10 minutes. Started doing this the 2nd time I used it. After it stalls out it will not start until it completely cools off. Fresh fuel in it. Arrestor...
I have the same model from Troy-Bilt. I have only had it about 4 or 5 months. Mine has started using a LOT of oil. I noticed a significant increase in temperature compared to my old Husqvarna 2 cycle. Mine does not completely stall, but it does start to sputter when it gets hot. I am going to take mine back to Lowe's where I bought it. So far I am VERY unhappy with the TBP6040.
Aug 24, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Tiller starts then stalls
The air filter should be replaced. Also remove the old gas and put in new from the gas station. Finally, if you didn't change the spark plug from last seaon, do so as it is a small amount of cash for a lot of easy starts.
Apr 24, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
Garden Logo
253 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
