Question about Kodak EasyShare Printer Dock Series 3
Paper won't feed into printer
The feed wheel for the printer turns but the paper wont feed. Holder is full with a new pack of paper from Kodak, wheel has been cleaned. Almost seems that the paper hits a solid object in the printer instead of going into slot it should. I cant even guide it in when wheel is turning.
    President:
  • 2,976 Answers
Make sure the paper doesn't have a curve in it. Also, fan the pages to make sure they aren't sticking together. Load shiny side up. Try taking about 10 sheets out
Posted on Jun 29, 2009
How to change paper
This product uses 2 1/4in (57/58mm) wide standard thermal paper. Use the feed keys only when changing the paper. Do not pull the paper manually.
1. If prompted during use, or when setting up the printer for the first time, open the printer compartment by lifting up on the tabs located toward the back of the register. This will expose the printers.
2. Depending on each sides needs, use the release buttons to open the paper wells and release the print rollers.
3. Place the paper rolls into the paper well so it feeds from the bottom of the roll towards the front of the cash register (not the back). Pull the paper up and past the print heads towards the front of the cash register.
4. Once done, close the printer arms and use the feed keys to advance the paper.
5. To attach the journal roll to the back of the winding wheel, remove the wheel from the comparment. Put a small fold in the end of the journal roll and feed it under and around the tabs located on the wheel. Spin the wheel manually to take up paper slack.
6. Once the paper is attached, place the wheel into the holder in the back of the printer compartment. The part of the winding wheel with two discs should be on the right side.
Dec 23, 2015 | Royal 29445B Alpha 9500ML Cash Register
Paper wont feed
Paper not feeding in all-in-one printer - Kodak
support.en.kodak.com/.../paper-not-feeding-in-all-in-one-printer
KodakPaper not feeding in all-in-one printer. Published 10/19/2010 04:38 PM ' Updated 09/23/2014 01:38 PM ' Answer ID 19640. What should I do if the paper does ...
Basic troubleshooting - Kodak
resources.kodak.com/support/shtml/en/manuals/.../urg01238c11s1.shtml
KODAK ESP Office 2100 Series All-in-One Printers - Extended User Guide ... If you experience an error with your printer, restarting your printer will ... For wireless connectivity issues, go to www.kodak.com/go/inkjetnetworking. Carriage ... If thepaper is not stacking properly in the output tray, remove the pages as they exit.
[Solved] Kodak ESP Printer Paper Jam - YouTube
? 20:50
https://www.youtube.com/watch?v=jpkitdHmkuc
Aug 15, 2014 - Uploaded by Sabretooth Barnacle
This is probably a common issue amongst all Kodak Printers. ...thanks for the video, these same instructions worked on theKodak 2150! ... What do you thinkthe pproblem is, Kodak offered me another one for ... the printer realises they don't match so rejects the paper until you feed in the size it's expecting.
Paper won't feed on kodak 2150 printer - Fixya
Dec 21, 2015 | Kodak ESP Office 2150 All-in-One Inkjet...
Won't load paper
Clean the paper feed with alcohol and a paper towel by rubbing and rotating the drum. Wait for it to dry completely then it should grab the paper. Also make sure paper is free from dust. Good luck!
Jan 25, 2013 | Kodak EasyShare Photo Printer 500
1) paper won't feed through. 2) Constantly saying paper jam
If it is a laserprinter, your paper can be too dry or humid. Try a new pack of paper. Or turn the paper that is in your tray upside-down.
Jul 17, 2011 | Office Equipment & Supplies
The paper deck is full but wont print. display reads "no paper feed"
The paper feed wheel (located in the front just inside where the paper tray goes) could be missing, broken, or the clutch that drives it could be bad. I'm not sure this will work but try to look at the wheel with the tray removed, and print a page, see if it rolls.
Dec 02, 2009 | Brother MFC-7820N Printer
Paper not feeding not catching on the wheels
-Remove the paper from the paper trays.
-Fan the stack of paper.
-Turn off your printer.
-Remove the power cable of the printer
-Lift the main tray, then remove foreign objects or debris.
-Remove the rear access(back door) cover from your printer, then check for foreign debris the remove it
-Clean the rollers of the printer using a lint-free cloth with small amount of water
-let the rollers dry
-Reinsert the rear access door (back door) cover
-Fan the paper and put it on your paper tray
-Plug the power cable., wait for the printer to initialize
-Do a test Print., If its still not feeding please download your latest Firmware at kodak.com/go/downloads
Now if all the troubleshooting did not solve the issue please call kodak for service and repair Toll Free 1 800 421 6699. GudlucK
Nov 03, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Printer says paper jam, now scanner wont work
you will need to open it to remove this piece of paper.
Aug 14, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Easy share printer dock 3 paper roller soes not turn to feed paper in. It sounds like it wants to turn but nothing happens
Fan you paper to get a little air into the stack..Also, don't put more than 25 in at a time. It packs them in too tight for the rollers to pull them through.
Aug 02, 2009 | Kodak EASYSHARE 300 Photo Printer
My Kodak ESP5 keeps saying "Paper Jam please remove paper jam" But there is no paper in it?
My esp 5 gave me this same message. I'm not an expert but here is what worked for me.
I turned off and disconnected both cables (usb and power) then reconnected and turned on.
At this point it still read paper jam, so I took ink cartridges out and paper out.
I then reinstalled ink cartridges and PULLED OUT THE PAPER TRAY to it's FULL capacity, added about 5 sheets of paper, and on the main menu I chose the allignment function and printed a test page and suddenly....no jam!
Hope this works for someone. For some reason pulling the tray all the way out cleared the "jam" message for me. Now if I could just get the new ink cart to work I'd be all set! Good Luck!
Dec 20, 2008 | Kodak ESP 5 Printer
Paper feed
Feed roller is dirty or worn thin, wipe rubber roller with damp cloth.
Nov 03, 2007 | Kodak EASYSHARE Printer Dock Thermal Photo
Kodak EasyShare Printer Dock Series 3 Logo
595 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
