Question about Whirlpool MH7140XF Microwave Oven
Whirlpool microwave over oven fan noise
The micro comes on then the fan kicks in and makes a loud buzzing noise. can I just replace the fan motor or ???
  • William Miller
    William Miller May 11, 2010
    It may be a shorted high voltage diode or magnetron, not the fan. Try cooking for about a minute at power level 1 or defrost and see if the buzzing goes on and off as the high voltage section switches on and off or if it stays on continually while you are cooking. And please reply back with your brand and model number so we can help you better.
jsrock516
  • 5911 Answers
SOURCE: Microwave won't heat/Makes buzzing noise.
The symptoms you are describing are typical of a magnetron that has gone bad. Continuing to attempt to use the oven in its current condition can cause further damage. So, I would recommend not using it. Microwave ovens are considered dangerous and repairs should not be attempted by anyone that is not electronic saavy. The High Voltage Network inside the oven has voltage potentials of 14,000 volts and higher. If you feel this is something you wish to attempt, the Magnetron part number is 1156751 and costs approx. $158. Keep in mind, if the magnetron has been arcing and making a burning smell you may have burned the protective coating that lines the walls of the waveguide. If the waveguide is damaged it is not repairable. I do not know if this is a replaceable item on your model microwave. Double check your warranty information and/or owner's manual. In many cases the magnetron is warranted for several years beyond the limited warranty that comes with most appliances. Post back with comments and let me know if you want me to assist you further. In addition, if you provide me with your EXACT model number (located along the door opening) I can narrow down parts a little better. I know this all sounds discouraging, but I do hope I have been able to help you.
Posted on Jan 15, 2008
bestdarngood
  • 3037 Answers
SOURCE: whirlpool microwave oven model gh5184xpq
Models: GH9177XL GH5176XP GH5184XP GH6178XP GH6177XP
KHHS178L KHHS179L
Microwave will not operate (cook). F7 error code
appears on the display.
Electrical circuit interruption between L1 and Neutral in
the microwave inverter circuit.
Possible reasons:
1. Check door, hinge and cavity front alignment and adjust
as needed.
2. Check the operation of all interlock switches.
3. Check over temperature protector for the magnatron.
4. Check all Cavity Thermostats for closed circuit.
5. Unplug the oven for at least 40 seconds. If this solves
the problem
A. Check the Cooling Fan for proper operation or
blockage
B. Check the resistance of the magnetron thermostat.
It should be 0 Ohms, replace if necessary.
6. Check that the control cable to the 1100 watt inverter
is properly connected to plug P2 on the display PCB
& Adjust or Reconnect
7. If interlock switches operate correctly, replace 1100W
inverter.
8. If problem persists, replace control assembly.
Please let me know if you need any more help or have further questions about anything that I have posted. I would be glad to help
thanks
Posted on Apr 27, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: have a Whirlpool microwave oven, model MH3185XP. Just stopped wor
In some Whirlpool models, there are more than one fuse, and two or more thermal devices which can interrupt power to the oven.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Please write back with more details if you need further help.
Posted on Mar 02, 2009
  • 64 Answers
SOURCE: Have a GE microwave spacesaver oven/Model
call a pro. these units run at a deadly high voltage. simply not worth your life!
Posted on Jul 02, 2009
  • 117 Answers
SOURCE: loud buzzing noise with Whirpool microwave oven
The loud buzzing you hear is the sound of the magnatron tube.That is what emits the microwave radiation and buzzing should be normal. The mag tube may be nearing its end at witch time you will hear no buzzing and hence no heating of foods. Replacement can be costly depending on the model so most people just opt for a new one. Hope this helps
Posted on Jul 30, 2009
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
Microwave occasional loud buzz
make this test and fix it. God bless you
  1. MagnetronIf your microwave is emanating high pitched or growling noises during operation, the magnetron could be going bad. Normally a nearly silent part, the magnetron uses high voltage and induces the frequency required to cook food. Although normally not a safety hazard to operate, this is a sign that the magnetron is failing and will need to be replaced as soon as possible.
  2. Exhaust fan motorIf your microwave is making a very loud humming noise during operation, it could possibly be the exhaust fan motor. If defective the part will need to be replaced to silence the appliance once more.
  3. Stirrer motorAnother leading cause of a noisy microwave is an expired stirrer motor. With use this part becomes worn and makes a loud grinding noise, which is usually a leading indicator that the part needs to be replaced. The stirrer is a metal blade that is slowly turned by the motor. This action disperses the microwave energy in a random pattern, which heats the food evenly. If the stirrer motor is determined to be nearing expiration, it should be replaced to halt the grinding noise.
  4. Turntable motorA very common cause for a noisy microwave is a worn out turntable motor. This is a relatively easy repair and will put an end to the noise once replaced.
Nov 14, 2013 | Jenn-Air JMV8208AAS Microwave Oven
GE microwave occasionally buzzes loudly.
Nov 14, 2013 | Microwave Ovens
Buzzing noise
follow this steps and fix it. God bless you
Oct 23, 2013 | Panasonic Microwave Ovens
Coleman EB15A - Buzzing noise from transformer area, no heat or fan
see this causes and proceed. God bless you
Magnetron If the microwave is loud or noisy only when cooking, the magnetron tube might be defective. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. Under normal circumstances the magnetron is nearly silent. However if it is damaged or nearly burned out it can begin emitting high pitched or growling noises. It's not normally dangerous to use a microwave oven when it makes these noises, but they are an indication that the magnetron is almost dead and will need to be replaced.
Exhaust Fan Motor If the microwave is loud when running the fan motor might be
Stirrer Motor If the microwave is loud or noisy the stirrer motor might be worn out. The stirrer is a metal blade which slowly turns around, deflecting the microwave energy in a random pattern inside the microwave oven. As the motor nears the end of its useful life it begins to make grinding noises. The microwave will not heat food evenly without this stirrer, the motor should be replaced.
Turntable Motor If the microwave is loud or noisy the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Oct 18, 2012 | Microwave Ovens
GE Microwave (JVM1860CD001) control board buzzes.
see this causes and fix it. God bless you
Oct 10, 2012 | GE Microwave Ovens
When the Whirlpool microwave oven is on the loud fan noise is unbearable. It is not effected according to the power level, in fact when it stops cooking the noise remains until it automatically is switched...
The fan motor is going and it involves bad bearings or the lubrication in the motor has dried out. The fan is responsible for cooling the magnetron while it is running and is critical, I suggest replacing it as quickly as possible.
Mar 07, 2011 | Whirlpool MH7140XF Microwave Oven
Whirlpool micro wave making loud humming noise fan and light works
Some micros when they get older make more noise. as long as it works I wouldnt worry about it
Jan 12, 2010 | Whirlpool MH7140XF Microwave Oven
Whirlpool microwave makes loud buzzing noise
When your microwave oven won't cook your food, and, you hear a loud buzzing sound, it’s normally caused by a faulty (a) diode (b) high-voltage capacitor (b) magnetron.
The diode would be the most likely culprit of the three components. It’s also by far the cheapest!
Sep 21, 2009 | Whirlpool MH6140XK Microwave Oven
Loud buzzing noise with Whirpool microwave oven when it comes on. All lights, heating and fan seems to work but not sure why loud buzzing. What is the problem?
Jul 30, 2009 | Microwave Ovens
Whirlpool MH7140XF Microwave Oven Logo
403 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
