Question about Sharp Office Equipment & Supplies
Need operator's manual for a Sharp 450U copier
    Scholar:
  • 175 Answers
I think if you go to SharpUSA.com, you can download a copy.
Posted on Jul 02, 2009
Sharp copier mx-2301n code L4-30 i need help
The fan blades are normally the problem, check the fans below the black toner there are 2 small fans. Make sure they are operational.
http://www.manualsprinter.com/manuals/sharp/Sharp_MX-2301N.pdf
the link should help you step by step trouble shoot.
Aug 28, 2015 | Sharp Office Equipment & Supplies
I have an old SHARP M-450U copier. I am getting a L6-10 error code. From your site, it appears that this would be a problem with the laser. In that case it would probably would not be worth fixing. I...
You can use Simulation 61-1 to check the polygon motor. If the motor is bad it effects copying and printing. I am not sure what the price would be to replace one now it's been a couple of years since I have done one but when I did it was about $400 for the LSU Unit.
Aug 19, 2011 | Sharp AR-235 Copier
Need operating manual/parts for Sharp Copier Z-85 III
It is an old model. Good little copier though. The power cord should be no problem as it takes a standard power cord for most printers like HP or almost all computer power cords. If you don't have one lying around you could check about any used computer store.
The operators manual will be next to impossible.
Nov 03, 2009 | Sharp Office Equipment & Supplies
Hello i have copier machine sharp mx-450u,with mx-nbx3.some times when i print document.suddenley stop printing,so i turn it off then it start printing,allways same ****.so i dont know the proplem cause of...
As a general rule, U machines are not designed to be turned into network printers, that's what the MX-M450N is for. You can put an MX-NBX3 on it, it might work properly and it might not.
The NBX3 can only function properly with a hard drive in the copier, otherwise you're outta luck!!
Your driver type may be wrong. If you are currently using PCL6, try PCL5e.
Other than that, try getting a new driver from the Business Copiers section of sharpusa.com. You may have to see which model will work for you. Look for the PCL driver for MX-NBX3, then look for MX-M450U, then MX-M450N.
Jun 17, 2009 | Sharp Office Equipment & Supplies
Sharp AR-275 copier with fax module. Need to edit sender ID
push custom or system setting button, push key operator programs on lcd, type in 00000 from number pad, hit fax settings, fax default settings, own name/number set. hit ok button at top when done then CA button to return to main menu.
Mar 04, 2009 | Sharp AR-275 Copier
MANUAL FOR SHARP ARC270
Here's a link to the manuals download page at Sharp:
http://www.sharpusa.com/products/TypeManuals/0,1083,18,00.html
They don't list an AR-C270, but a C260 is listed. Maybe it will give you some help. You can also try contacting their customer service through the site if you still need more information
Feb 18, 2009 | Sharp AR-C270 Color Copier
41 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
