Question about Craftsman 26 Hp 54" Deck Yard Tractor
CH6 OIL code
How do you reset the code once the oil & filter have been changed? There appears to be no switch or button; the manual does not even mention the code system; I disconnected the battery - that was no help either
  • mark_j_powle Aug 25, 2009
    I had come to that conclusion. Once the time reached 103 it reset. I had not bothered to update this post as it appeared no-one read it in the first place.
    Thanks
    Scholar:
  • 138 Answers
It should reset itself automatically after about an hour running. it is just a reminder to change the oil and doen't affect operation
Posted on Aug 25, 2009
If I just changed my oil and filter on yardman 20 hp 725cc why is it blinking ch6 oil and red light is on
ch6 Oil code
What you are actually getting is Chg Oil (change oil). This is preprogrammed in, as a reminder for you to service the engine. It will go back to the hour meter mode after about 1 hour of additional runtime. If you have changed your oil and filter, there is nothing else to do. The oil and filter need to be changed regularly. If the oil breaks down in your engine, it will lose it's lubricating properties and the engine will seize up.
May 30, 2017 | HP Garden
Tip
Pontiac service light 1983-01
Firebird
1998-01
To reset the "CHANGE OIL" light, press and hold the "TRIP/OIL RESET" button on the instrument panel for 12 seconds. When the light flashes and goes out, the system is reset.
Grand Am
1999 -01
To reset the Change Oil light, open the driver's side instrument fuse panel and turn the ignition on. Press the "RESET" button and release. The light will flash. Press the button again and the system will be reset.
Grand Prix
1999-01
Driver Information Center If Equipped). Turn the ignition to ON without starting the engine. Fully press and release the accelerator pedal three times within five seconds. If the CHANGE OIL SOON indicator flashes two times, the system is resetting. Turn the ignition key to OFF, then start the vehicle. If the CHANGE OIL SOON indicator comes on and stays on, repeat the procedure. To reset the OIL LIFE indictor if equipped with a Trip Computer: Press the trip MODE button until the light appears next to OIL LIFE. Press and hold the trip RESET button until the oil life percentage changes to be 99 percent.
Grand Prix
1997-98
To reset the oil life indicator, press the "MODE" button until the light next to "OIL LIFE" is lit. Press and hold "RESET" for 3 seconds until oil life percentage is 100%.
Grand Prix SE
1997
Turn the ignition on, but do not start the vehicle. Within 5 seconds, push the accelerator to the floor 3 times. Turn the ignition off. Start the car and the Change Oil Soon indicator light will be reset.
Grand Prix
w/ Trip Computer
1988-93
To reset "CHANGE OIL", "CHANGE OIL FILTER", or the mileage of either on the Trip Compute, continually press the "SERVICE" or "SYSTEMS CHECK" button until the item appears with the mileage below it. Then press the "RESET" button and the mileage will be reset to the maximum value. If you want to reduce this value, hold the "RESET" button down and the mileage will count down. Release the button at the mileage you would like to observe.
Bonneville,
6000
w/ Driver Information Center
1983-91
To reset "CHANGE OIL SOON" or "OIL FILTER" or to adjust the mileage on the Driver Information Center, continually press the "DIC" button until either message appears with the mileage below it. At this point, hold down the button. In 5 to 10 seconds, the mileage will count down. When it passes 0, it will cycle back to a maximum figure. Release the button when the mileage gets to the service interval you'd like to observe. If "CHANGE OIL" or "OIL FILTER" already appears, just hold the button down to reset the mileage. "CHANGE OIL" and "OIL FILTER" are reset separately.
on Dec 07, 2009 | Pontiac Grand Prix Cars & Trucks
HOW TO PULL CODE ON 2012 HARLE
1- Turn motorcycle ignition switch to OFF & Run/Stop switch to RUN.
Push odometer reset button in & hold.
Turn ignition switch to Ignition and release odometer reset button. Background lighting will illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word "diag" should then appear.
Push the odometer reset button once and you will see the selection menu "PSSPt" with the first P flashing.
2- Push odometer reset button in & hold.
3- Turn ignition switch to Ignition and release odometer reset button. Background lighting will illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word "diag" should then appear.
4 - Push the odometer reset button once and you will see the selection menu "PSSPt" with the first P flashing.
5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.)
P = ECM/ICM (Electronic Control Module [EFI] / Ignition Control Module [Carburetor])
S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
SP = speedometer
T = tachometer
6 - To get the DTC in an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC's the code will be displayed or the word "none" will appear if there are no DTC's. Push the odometer reset button again to view additional codes if they exist.
7 - Record the codes.
8 - If DTC's are not to be cleared, Press and release the odometer reset button. Part number of module will be displayed. NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC's again by repeating steps 1 to 9. If the code is current it will reappear.
9 - Press and release the odometer reset button to continue to the next module.
10 - Turn Ignition switch to OFF.
On models not equipped with a tachometer "No Rsp" will appear when the tachometer identifier is selected.
"No Rsp" will also appear if the run/off switch is in the off position when doing this procedure.
The actual error codes will appear (format) as "P0374", for example.
Sep 30, 2014 | Harley Davidson FLHTCUI Electra Glide...
2005 Harley Davidson road glide When I throttle up the check engine light comes on When I hold a steady throttle the check engine light goes off I have replaced the fuel filter fuel hoses with factory...
Pull any error codes.
How?
1 - Turn the ignition switch to off & run/stop switch is to run .
2 - Push odometer reset button in & HOLD .
3 - Turn the ignition switch on and then release odometer reset button. The background lighting should illuminate & the speedometer needle should sweep it's full range & indicator lamps ( battery , security , low fuel , check engine and cruise ) should illuminate . The word "DIAG" should then appear .
4 - Push the odometer reset button once and you will see the selection menu "PSSPtb" with the first P flashing .
5 - Each letter represents a area of the diagnostics module. The module that is flashing is the one you are going to check . To move from one letter to the next you must push the odometer reset button one time . ( from P to S to SP to t to b and back to P , ect ect )
P = ECM
S = TSM/TSSM/HFSM
SP = speedometer
t = tachometer
b = ABS codes
6 - To get the DTC code in a area of diagnostics you should PUSH & HOLD the odometer reset button in for 5 seconds and the release . If there are any DTC's the code will be displayed or the word " none " will appear if there are no DTC's . Push the odometer reset button again to view any additional codes if they exist .
7 - Record the codes .
8 - If DTC's are NOT to be cleared , press and release the odometer reset button . Part #of module will be displayed .
9 - If DTC's are to be cleared for that module , PRESS & HOLD the odometer reset button until " clear " is displayed .
10 - Press and release the odometer reset button to continue to the next module .
11 - Turn the ignition switch off to exit the diagnostic mode.
Once you have any codes, look them up, or post here (I have a manual that translates the codes), to find out what they mean.
Jan 01, 2014 | Motorcycles
I have a 2001 LS Lincoln. No owners manual. The dash has a couple of codes on an led type screen for "change AC filter" and "change oil" messages. I did the work but the messages still...
Look for the Information Center panel above the Audio controls.. There should be 4 buttons labeled Fuel, Setup, Reset, and Status. With the engine running, press the Status button until the change oil required message appears, then press and hold the reset button until the message appears that says oil life restored to 100%. Do the same for the a/c filter.
Feb 26, 2011 | 2001 Lincoln LS
I am looking for what an error code is: B with a 12 under it.
Code B12 is your 10,000 miles check up:
B: oil & filter change
1: tire rotation
2: engine air filter, cabin air filter change
Reset Meter:
1: turn car to ON (II)
2: press sel/res button until oil life % is displayed
3: press & hold sel/res button until oil life blinks (10 seconds)
4: release button
5: press & hold sel/res button until oil life shows 100 (5 seconds)
Hope this helps (remember to rate this answer). Good luck.
Feb 23, 2011 | Honda Odyssey Cars & Trucks
How do you reset the service engine light on a 2006 525i
In 2006 BMW developed what they Condition Based Service (CBS), this means even when you change the oil and filter, the only way to reset the service indicator is to take it to the dealer, to be hooked up to thier computer. I have the same problem, I am waiting for some aftermaket code breaker to be developed to fix this problem. Hope this helps, let me know.
Aug 09, 2010 | 2006 BMW 5 Series
I have a cub cadet lt1550 and the oil light is blinking and a ch6 code is flashing. checked the oil and it is full. just wanted to know if something is wrong or that is a reminder to change oil and if it...
The mower is programmed to remind you to change the oil every 50 hours. It will continue blinking for 2 hours. It will begin blinking again at 100 hours and every 50 hours after that. There is no manual reset.
May 20, 2010 | Briggs & Stratton Garden
Just changed oil and filter rinsed around oil filter with brake clean and now engine light is on my bike year model is not listed 2008 road king classic
first off, using any cleaner around your oil filter is a no no......just use a little oil on the seal. try letting your bike warm up for about 10 minutes........check oil level. make sure its not too low.........that should take care of it
Dec 20, 2009 | 2004 Harley Davidson FLHRCI Road King...
Craftsman 26 Hp 54" Deck Yard Tractor Logo
1,032 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
