Question about Dometic Rooftop RV Air Conditioner
Ac not blowing cold after outside temp reaches 98 degrees
Ac work great blows nice and cold until outside temp rises into the hight temp outside 100 degrees. When it cools down outside ac blows cold again 11000 btu penquin pulling 15.5 amps could this be run capacitors? Or?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 127 Answers
Sounds like you have dirty condenser coils. Remove the upper shroud and check the condenser for clean. Take a water hose and gently spray out the coils paying special attention not to bend the coils over with too much pressure. This will allow more air movement through the coils and give you better cooling efficiency.
Hope this helps,
Jeff
Posted on Jun 29, 2009
KF9000e. Why has it stopped blowing cool air?
Depending on the age of unit either filter blocked needs cleaning or freon low is fan blowing do you have outside of unit clear of obstacles these are all things to check also remember if it's 100 outside AC will only drop air temp 20 or so degrees
Aug 17, 2015 | Amcor Heating & Cooling
Unit alternates cold, warm, cold, warm etc..
in high temps AC units undergo whats called thermal inversion. This is when it blows hot inside and cold outside. I do not believe there is a fix for this. Maybe it is not properly sized for you room? If your unit is too small, it may be working too hard and inverting.
Jul 30, 2014 | Kenmore 75184 Air Conditioner
2000 nissan altima blows cold until outside temp reaches 90 degrees then blows hot
2000 Nissan Altima Heater Air Condition Section HA 76 pages Here is factory service repair manual for your vehicle . Do you know how to do testing on these system ? Automotive electrical system testing ? How to read a wiring diagram ? When hot outside is the inlet pipe to evaporator freezing up ? Do you know where this is , under the hood in the engine compartment at the fire wall . What are gauge readings , Is the compressor engaging ? Were any switches replaced ? Ambient temp. , thermal transmitter switch . pressure etc...
Apr 25, 2017 | 2000 Nissan Altima
Olds aurora 95 ac -- freon good. starts good in am. runs great. ac blows ice cold 60 degrees ( using a lazer temp gauge) out side temp 77 degrees -- ran for 2 hrs. ice cold. Then outside temp over 85...
About the only thing that it could be is a dirty coil,or some one over charge the system, I have seen just a layer of dust cause the compressor to cycle off to its thermal over load. Clean the coil.
Jul 08, 2011 | Heating & Cooling
I have a Lennex heat pump unit which was installed in 2008. Our area (Savannah, GA) has experienced some abnormal cold temps lately. Yesterday, I noticed the outside of the unit had frost on the unit. ...
Heat pumps are the same as an A/C unit only it works in reverse. Instead of blowing cold air inside and hot air outside it blows hot air inside and cold air outside. The heat being blown inside is extracted form the cold air outside. Its called Latent heat Latin for hidden. Believe it or not even though its 20 degrees outside there is still heat in the air. Example if you want to drop the temperature of a freezer from 20 to 10 degrees you have to remove heat .I know your getting unusal weather and that is the problem. Heat pumps can only work no lower then around 20 degrees outside.Heat pumps are never used above the freeze line. With your unusal temperatures thats basically where you are now. Ride it out. When your temps rise a little your be fine. Im in Chicago.
Jan 15, 2011 | Heating & Cooling
Carrier Air Conditioner- not reaching set temperature
if it is set to 76 degrees and its 78 in the house its working fine it is suppose to shut off once it reaches 76 but sometimes there is a 1 or 2 degree differential built ini would keep you filter clean and as long as it blows out cold air i wouldnt be to concerned most airconditioners need yearly cleanings though
Jul 14, 2009 | Carrier 38CKC036 Air Conditioner
2001 bmw 325i AC blows warm
PROB NEEDS 2 JUST BE RECHARGED. BUT STAY AWAY FROM THE DEALER. IT IS ALWAYS 3 TIMES MORE THAN A PRIVATE SHOP
Mar 30, 2009 | 2001 BMW 325
2002 gmc van overheatig
It has a leak. Fill up the radiator and the coolant tank. Then restart it and check for leaks.
Mar 13, 2009 | 2002 GMC Savana
Dometic Rooftop RV Air Conditioner Logo
551 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
