Question about Samsung SF 5100P Laser Printer
"TONER EMPTY" sign after installing new Cartridge
The toner on my Samsung SF 5100 P ran out yesterday, and I installed a new cartridge which has been in storage with me for over a year. The unit now refuses to print and the "TONER EMPTY" sign is on, I have tried reinstalling the new cartirdge many time, but to no avail. I have opened up the old cartridge and was surprised to see that it has quite a lot of some black powder inside, I presume that there was no need to have replaced the cartridge at all. I will be thankful for some expert advice as to how to solve this problem,I may add that this Unit has been very sparingly used I may have printed a1000 pages (max) since purchasing it a few years ago.
Here is the text of the solution, in case the link does not work:
A. The first step to take is to remove the toner and try putting it back in while the printer/fax is off, then turn the printer/fax back on.
B. Failing the above the next step is to reset the printer, which the steps are below:
i. NOTE: Resetting the printer will loose all pending faxes, preset settings and speed dials etc.
C. To reset the machine you need to disconnect the power from the device
D. With the power disconnected hold down the STOP button
E. While holding down the stop button plug the power back and don’t let go of stop button
F. Once the display screen shows “Australia” you can then let go of the stop button, then press the start/enter button. It will then say clearing memory and go back to normal and it will now no longer display toner empty/toner low.
G. This problem can be due to a non genuine Samsung toner used with the printer.
If you encounter any troubles please don’t hesitate to call our help desk on 1300 362 603 option 1-1-2
Posted on Apr 04, 2008
Hi there, I had the same problem. I reset the printer using steps B-E, which worked.
Sf 5100 - new ink cartridge says toner empty?
take the new cartrige out. you will see there is a fuse on it. take it out and put new fuse any amp. put the cartridge back and close the door for 2 sec. take the cartrige out and remove the fuse. put it back in. it should work.
if not push setup
set up again
you will find under the setup a toner egnore put it on.
and swich unit off and on.
Aug 15, 2011 | Samsung SF-5100 Plain Paper Laser Fax
Wont accept a new toner cartridge makes a very
you have to cleaan all the gears. on the side and use a bit of oil.
this is a commen problem form sf 5100
May 17, 2011 | Samsung SF-5100 Plain Paper Laser Fax
Toner empty, but i have just installed a new toner
if you toner is empty replace it.
if you replaced it and it still say emty do the following
  • menu
  • 1
  • 9
  • 4
  • 3
you will go in service mode.
look for ignore toner put it on.
if it still not working open the fax take out the cartridge. you will see ontop of the cardrige is a fuse. put a new on in put cartrige back. close the door for 5 sec. and take cartrigde out and remove the fuse. it should work then.
Feb 08, 2011 | Samsung SF-5100 Plain Paper Laser Fax
Fax machine Samsung Inkjet Fax SF-360. Ink was finished so ordered the correct ink cartridge and replaced it now on the screen it tells us to install ink cartridge. I have tried severeal times and i know...
If the Toner Low/Empty message does not automatically clear when a new cartridge is installed, use the following to clear the message manually:
1.Press MENU # 1 9 3 4. The machine should display TECH.
2.Press MENU, and ENTER. The machine should display TECH Mode.
3.Press the left arrow < once. The machine will show NEW CARTRIDGE.
4.Press ENTER, the machine will show YES.
5.Press ENTER, there should not be any Toner Low/Empty message.
6.Exit TECH MODE, press MENU # 1 9 3 4. The machine will no longer display TECH.
If Toner Low/Empty message continues, there may be a problem with the toner cartridge or the machine.
Jul 21, 2010 | Samsung SF-5100 Plain Paper Laser Fax
Why toner empty error in samsung sf 565p
I have an SF-555P and have installed numerous cartridges. The last one was a Samsung brand and it didn't have the little fuse taped on the top. I never knew what this was fur until I had problems. When I first installed the new cartridge the "Toner Low" display remained lit. I shook the cartridge and it persisted but it printed well. Then about 100 pages later I got the "TONER EMPTY" and the printer stopped. After researching the issue I found that the fuse is actually a reset for the printer counter and when the new cartridge was installed without the fuse, it never reset.
You will need a 5X20 Fast acting fuse, no greater than 315 ma. You can buy a 4 pack from Radio Shack for about $3 (P N 2701046). Install it with a piece of electrical tape in the slot on the toner cartridge and make sure the contacts are exposed. The printer will blow the fuse and reset the counter. Don't use a bigger fuse, a slow-blow or anything that won't burn open quickly or you will be buying a new printer.
Mar 18, 2010 | Samsung SF-565P All-In-One Laser Printer
Samsung sf-5100 fax toner empty
I have a feeling that it is a re-manufactured or compatible cartridge??
There is a fuse that needs to be replaced on this unit. it blows when the cartridge is installed to reset the machine. If the fuse has not been replaced or is defective the machine will not recognize the new unit.
Mar 05, 2009 | Samsung SF-5100 Plain Paper Laser Fax
Can't receive fax but can send fax
Feb 12, 2009 | Samsung SF-5100 Plain Paper Laser Fax
Samsung SF560 Laser Fax
in the box with the new toner cartridge was there a credit type card to use when changing the toner to reset the toner counter?
read the instructions in the box :p
May 23, 2008 | Samsung SF-560 Plain Paper Laser Fax
Samsung SF560 Message reads "toner empty". Replaced new toner cartidges and still get same message. have change toner in fax but getting message (jam 1) or toner empty it seems pretty common problem as...
Turn off the Machine for safety.
- Try to double check if the toner cartridge is properly installed
- Clean it also if dusty
- Make sure he sensor have no paper or dust.
Apr 15, 2008 | Samsung SF-560 Plain Paper Laser Fax
"toner empty" problem
The samsung sf 5100 toner cartridge has a .05 Amps fuse in it. This gets blowed when you switch on the machine.This is used to reset the page counter and also to inform the machine that you have inserted a new toner. Now this recycled cartriges will not have this fuse and this is the reason why your machine shows TONER EMTY message! If you dont get the same rating fuse, put any fuse of the same size, insert the toner, close the door and just switch on the power and switch off immediately. Then take out the Toner cartridge and remove the fuse. Now your cartridge is ready for use.
Dec 06, 2007 | Samsung SF-5100 Plain Paper Laser Fax
Samsung SF 5100P Laser Printer Logo
298 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
