I am living in a Pakistan Village and have cyocera K-6030. I am facing an error on control pannel C3300, I would be most grateful, if I may be informed only that in which part of the machine this fault of C3300 is? it solution please. Thanks with regards. my e mail no is [email protected] and [email protected]. If some one here can show me its solution, because my e mail is also not opening. thanks. my name is ghulam muuhammad
Defective DP main PWB. Device damage of EEPROM.
not so good fault this one - if you are an engineer prepare for the main PWB replacement and calibration that follow ( you could try as a last resort re-writing the firmware/ replacing the eeprom chip and re-writing)
if you are a customer- suggest you upgrade your printer to something else as it will be the cheaper option. Sorry for the bad news
According to the above results, doubt the fuel pump problem,use BMW ICOM to check.The vehicle road test and read data.May the fuel pump is insufficient, resulting in high pressure fuel pressure is too low, resulting in engine fault light
I used a generic scan tool on a v6 sprinter and it gave me fault code p1955 as a current code. I hooked up the factory scan tool (star diagnosis) and had no fault codes. Looked up the mercedes benz obd codes and this code does not exist. What symptoms do you have with your sprinter?
