Question about Iwill KK400 Motherboard
The small fan does not want to run, it runs for a few seconds and stops, my computer keeps rebooting
  • 54 Answers
When the fan stops 2 things are happening 1 the bios sences no rpm speed from the fan or the processor heats up to quickly and the safety in the bios will shut it down. try moving the fan connector to the case fan connector then go into the bios and change the fan settings. this is only a temp fix the fan stopping tells me that the onboard cpu fan regulator is going out and this is a precurser to more problems to the board going out. also just to be certin check the power supply 4 years ago i came across this in a gateway it was weird.
Posted on Jun 29, 2009
  • 80 Answers
This problem can be solved by replacing the ram, after you replace your ram,, this problem will surely solved, this problem occurs because the ram has gone bad,,thank you., pla dont forget to rank me...
Carrier apu blows cold air for twenty seconds and fan quits engine keeps running and fan starts again but only blows cold air for another twenty seconds
Have you tried rebooting the system? Just turn off the breaker for a few minutes.If you need more questions for your Air Conditioning Repair needs, check us out online.
Jul 07, 2017 | Carrier Heating & Cooling
I just moved the fridge to a new house and now the fridge and freezer won't get cold. It had been sitting in storage for over about a year, but worked perfectly before that.
Its possible that during storage a few things may have happened. There is a small fan under the back that keeps the compressor cool while running. Its possible that during moving something shifted or bent the fan area and its not running. Could also be a small critter built a nest in that same area stopping the fan from running. Without that fan--- the compressor will run a very short time and then cycle itself off on the heat safety when it gets too hot. It will keep short cycling off the heat overload until the fan runs again. It will not run long enough to get to proper temp. Just guessing but check this first.
Jun 18, 2015 | GE Profile PFSS6PKX Bottom Freezer French...
Machine just keeps rebooting a a few seconds after start-up
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions EIDE SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty
computers need power and data to travel through every working device and to have a finishing point to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as faulty fan and the fans electrical lead can cause this problem
if this fails to fix the problem
another possible reason could be a memory dump you might be running to many programs at the one time placing to much strain on the CPU also you might not have enough RAM random access memory
try uninstalling a few unnecessary programs or add more ram
hope it helps you
Oct 09, 2011 | Computers & Internet
My laptop toshiba satellite A300 , restarts and reboots when using internet and playing games , and also when power adapter is plugged in it and when any other process runs on like playing music and video...
The fan is blocked up and is not able to keep the cpu cold, if it over heats your computer will shut down to prevent damage to itself then restart, to stop this from rebooting you will need to take it apart and remove the CPU thermal module that is attached to the fan and clean it, by doing this help the laptop and keep it running smoothly. Kronoguy
Aug 13, 2011 | Computers & Internet
I recently had a fan installed in a small bathroom (5x8). The mirror and windows still fog up even when I take a brief shower. A few minutes after the water stops running, the moisture does seem to clear...
On the assumption that your bathroom is 8 ft high, then the volume of air in the bathroom is 5x8x8 or 320 cu ft. Even if your fan is 80 cfm it would take 4 minutes to completely exchange the air. Leaving the door slightly ajar would assist.
To overcome a similar problem, I installed a second fan with a push button 10 minute timer so the fan runs for a few minutes after I leave the bathroom.
Sep 24, 2009 | Dryers
My computer is turning on and off continually
download memtest and burn the iso to a cd and boot from it to test your ram, it usually only takes a few minutes to see if your ram is bad or not, otherwise ive had computers with bad system boards (blown capacitors) that reboot themselves, and also computers that are overheating reboot themselves, check to make sure all air vents aren't blocked and that all of your case fans run well
Feb 19, 2009 | Gateway GT5220 PC Desktop
Trouble shooting
OC failure = over clocking failure. Make sure the CPU fan is clean, free from dirt & dust. Check CPU fan plug is connected correctly. If the CPU fan still stops after a few seconds replace the CPU fan.
It's harder to find just a fan to fit your heatsink, which sits on your CPU. It is easier to find a new heatsink \ fan combo for your Intel. Use your manual to find what Intel chip is on your board. Use that information & search google for a heatsink & fan combo. Pay close attention to how your current heatsink is mounted to the Gigabyte board.
Mike
Mar 24, 2008 | Computers & Internet
Cpu fan starts then stops
Replace it and let us know if it still happens with the new one.It shut down because of overheating, I hope it didnt mess up your CPU.
Jan 06, 2008 | Biostar GEFORCE 6100-M9 Motherboard
Computer keeps rebooting
try to check if your IDE cable is plug-in correctly. insert it correctly. try to restart your computer.
Aug 10, 2007 | IBM TravelStar 60GH 60 GB Hard Drive
Iwill KK400 Motherboard Logo
119 people viewed this question
Top Iwill Computers & Internet Experts
Alun Cox
David
David
wahidmeer
wahidmeer
Level 1 Expert
Are you an Iwill Computer and Internet Expert? Answer questions, earn points and help others
