Question about Bose Wave Radio
How do I dim and brighten the display on Bose radio. Sometimes it's bright and sometimes it is so dimI can't see what time it is at night
SOURCE: Wave Radio-dial face,display very dim.
Our Bose did the same thing after a power outage. This one doesn't have a CD button, so we tried holding down the Clock button and used the volume control and that seems to have fixed it.
Posted on Oct 29, 2008
  • 6 Answers
SOURCE: Bose Wave radio humming noise
Actually the problem was caused by a bad 470uf cap, that was used to filter the powersupply for all the analog amps. Replaced the cap the unit works like new.
Posted on Apr 06, 2008
  • 1894 Answers
this is a power problem.
leave the unit unplugged for one night and then try switching ON
Posted on Oct 01, 2008
SOURCE: Why does the CD function on my Bose Wave Radio/CD
Hi, when the lens of the CD player is weak, it can keep on spinning and not play. what you will need to do is to get a lens cleaner and clean the lens(instructions are on the lens cleaner.
If after cleaning and it still did not work, that means the lens is to weak to perform well. It will need to be changed to a new lens.
Take care.
Posted on May 27, 2010
tunde007
  • 2382 Answers
SOURCE: My Bose Wave is doing
Hi.
This is a common problem with this model.
The LCD has a dimmer circuit that can be responsible, in some case it is not the dimmer regulation, but the LCD control circuit itself. In that case you have no LCD backlight and the display is almost unreadable. If that is the problem, changing dimmer settings with procedure below will not help.
Most of the time the problem is dimmer regulation.
About dimmer regulation:
Try disconnecting the unit power cord for ten minutes and connect back.
Try holding down CD or CLOCK button and pressing at the same time the volume buttons. This procedures regulates Bose dimmers setting in a scale from one to 9. The dimmer has separate settings for medium and low brightness. Set both to 5 if you want to disable dimmer settings.
Posted on Dec 10, 2010
Why is my Bose radio is too dim?
The Bose Wave Radio has two brightness levels: Bright Hi (with a range of 8-15, and default of 10) and Bright Lo (1-8, default 4). The radio automatically goes from Hi to Lo when a room is darkened so the display doesn't interfere with sleep.
On recent models you can reset the defaults to make the display brighter or dimmer in both Hi and Lo levels.
1. Press and hold the Alarm Setup (Menu) button on your remote until -setup menu- appears in the display.
2. Then press the Tune/MP3 button until Bright Hi- appears. Use the Time - or Time + buttons to change the settings.
3. Go to Bright Lo- and adjust that setting too if necessary.
4. Press Alarm Setup (Menu) again to exit setup, or simply wait 10 seconds.
You're done! Note that if you set both Hi and Lo to 8, the brightness will stay the same all day and night.
Aug 21, 2014 | Bose Wave Radio
How do you get the display light on a bose radio to stay on
Do you mean keep it from going dim in a dark room? The settings menu has "Bright Hi" and "Bright Lo" adjustments you can make in ranges from 1-8 (Lo) and 8-10 (Hi). Check your manual under the heading "The setup menu" for very clear instructions.
Jul 03, 2014 | Bose Wave Radio
How to keep the radio light on?
The sensor behind the plastic readout window needs to be exposed to a sufficient amount of light to alter the display brightness from dark room mode to bright room mode (dimmed display, bright display). Be sure sufficient light falls on the digital readout display when desiring the display to be at its bright mode setting.
Apr 26, 2014 | Bose Wave Radio Am/fm Awr1-1w Remote...
I have an original Bose Wave radio. The clock digits now do not brighten during the daylight hours or when a light is turned at night, as they used to. If I look very closely, the digits are lit, but...
If you look closely you will find a light sensor on the outside - it looks round and has some squiggly red waves on it. It's probably bad and needs to be replaced. Its' purpose is to sense the ambient light, send a signal to the processor and vary the brightness of the display. Check also to see if it's blocked.
Feb 19, 2011 | Bose Wave Radio
My Bose Wave is doing fine except that the brightness of the display in the front goes dim and bright, sometimes flickering. Most of the time it is dim and not readable. I did change out the 9V battery...
Hi.
Dec 09, 2010 | Bose Wave Radio
My Garmin nuvi 1300 brightness problems
I spoke to Garmin Support about this issue. There are 2 settings for contrast on the nuvi 1300. You need to set the contrast while it is plugged into the vehicle, and also while it is unplugged from the vehicle. The reason for the 2 settings is to save the charge of the battery while it is not plugged into the vehicle or power source.
Sep 14, 2009 | Garmin nuvi 1300 Car GPS Receiver
Lcd display very dim
My clock display is extremely bright, is there a way to dim it? thanks Natalie natalie1959@gmail.com
Jun 18, 2009 | Bose Wave Radio
Mar 23, 2008 | Bose Wave Radio
Bose wave radio/cd
Found this in the manual:
To adjust the display brightness -
The display dims automatically to medium or low brightness, as appropriate for low light room conditions. You can adjust the brightness setting of the display for both strong light and lowest light environments, but not for the medium light setting. Turn the system off before setting brightness levels.
• In a strongly lit room, hold down CD Mode and press Volume up or down to adjust the setting between 5 and 9 (it is preset to 8).
• In a barely lit room, hold down CD Mode and press Volume up or down to adjust the setting between 1 and 5 (it is preset to 2).
• If you do not want the system to dim automatically, set both levels to 5.
Feb 25, 2007 | Bose Wave Radio
Bose Wave Radio Logo
263 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
