Hi Friend, this is Z. Thank you for your post!
Typically error code F10 indicates that your Frigidaire range (FFES3025LSA) has detected an issue with the runaway temperature (overheating). Let's attempt reprogramming your range by either unplugging it or flipping the household circuit breaker off. It is best to wait roughly ten minutes and then turn on your range. Usually this will clear most false error codes. If issue persists, at this moment I would suggest contacting a professional to proceed further. Most likely the RTD Probe (Resistance Temperature Detector) or the EOC (electronic oven control) will need replacing. Hope this helps!
Good Morning mark, thank you for your post!
Based off the information you have provided your Frigidaire range is displaying an error code of "F10". An "F10" error code normally stands for a runaway temperature (overheating). This could be an issue with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would recommend performing a reset on your oven and you can do that by flipping the household circuit breaker off for ten minutes. If you continue to experience an issue with the "F10" error code I would recommend having a professional technician out to your home for proper diagnosis and replacement of any electrical components. This will help you avoid any unnecessary part purchases. Hopefully this information has been helpful. -Matt
